Featured What octane gas are you really putting in your car
Discussion in 'Fred's House of Pancakes' started by Louis19, Nov 22, 2022.
  1. Pulse07
    Pulse07 Active Member
    273
    140
    East Bay, California
    2020 Prius
    XLE AWD-e
    You must live in high altitude? Theres nothing lower than 87 here in california. I have seen some parts of the US where high elevations have 85 as regulars. Something due to the high altitude makes lower octane acceptable. I still opted for Mid Grade (89) when I was in those parts near the i80 when I was heading towards the East Coast.
  2. Isaac Zachary
    Isaac Zachary Senior Member
    2,646
    1,362
    Yep. Lived at over 10,000ft for a good portion of my life. Now I've came down to around 7,700ft, but do go up as high as 12,000ft at times.
  3. fuzzy1
    10,579
    Where do you get 83 octane?
    I've never seen less than 85. I can imagine a good market for it on a high Tibetan or Andean plateau, but thought the U.S. places where it would work were too close to "low" areas of just 6000-ish feet.
  4. Isaac Zachary
    2,646
    1,362
    I might be mistaken. I thought there were towns here that sold 83 octane but I can't seem to find them in a google search. The station I go to here in town sells 85, 87 and 91. Sorry for the confusion.
  5. Trollbait
    12,652
    Its the thin air and lower pressures. The ambient pressure is lower at the top of a mountain than at sea level. Then the thin air results in less fuel being burned in the cylinder. That leads to a lower maximum pressure possible in the engine.
    Octane is resistance to ignition by pressure. A lower starting and maximum pressure means lower octane is needed.
  6. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,691
    Somewhere in Wisconsin
    2013 Chevy Volt
    My guess is that you saw 83
    years ago it likely is getting to the point it isn’t a volume fuel and doesn’t save $$$ and this isn’t common
    Isaac Zachary likes this.
  7. hill
    8,894
    In the early 1970s as kids we would drive to Cal's Huntington Beach Airport - buy a bit of 100 octane Aviation gas for our hoped up motors. Wishing now I could get back all those wasted hours - as well as lost. Brain IQ points from sucking in leaded fumes.
