Can't find the setting
Discussion in 'Prime Main Forum (2017-2022)' started by ToeJamFootball, Nov 26, 2022.
  1. ToeJamFootball
    ToeJamFootball Junior Member
    17
    I have a new 2022 Prius Prime. I remember coming across a setting where the audio volume adaptively adjusts the volume depending on car speed. It had 4 settings, off, low, medium and high. The problem is that I cannot remember how to get back to that setting screen. Can someone please tell me how to set this again?
  2. Elektroingenieur
    2,515
    3,287
    Three Touring
    Toyota calls this feature “automatic sound levelizer,” and it’s adjusted on the sound or DSP settings screen.
    For details, if your car has the 7-inch display, see the Multimedia System Owner’s Manual (PDF), page 62; or for the 11.6-inch display, see the Navigation System Owner’s Manual (PDF), page 87.
    BiomedO1 and Tideland Prius like this.
  3. ToeJamFootball
    17
    Thank you.
    Elektroingenieur likes this.
  4. BiomedO1
    4,014
    2,109
    SacTown, Ca
    Learning something new everyday. Didn't know my cheap LE had adaptive volume control. I just set mine to medium; to see how well it works.
    Moderator should probably move this over to the audio forum
