2013 v pump/electrical noise every 10 seconds
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Matt98svt, Oct 20, 2022.
  1. Matt98svt
    Matt98svt Junior Member
    57
    South Carolina
    2015 Prius v wagon
    I’ve noticed in my 2013 v when parked every 10 seconds there is a pump noise that last for approx 3 seconds each time under the dash. I don’t notice it when driving and although the car has always made it I don’t recall it being this frequent. When I just now turned the car off it continued to do it for 30-45 secs after the car was off. What is this noise and is it normal? Thanks in advance
  2. Mendel Leisk
    38,253
    Sounds like the brake booster and/or brake booster pump failing. Someone will be along soon with the right names and better explanation, but basically, the two coconut-sized bits on the firewall controlling the brakes. There are warranty extensions, think they require a code displayed, and there are mile/months limits. might be explained in the attached.
    If outside of the warranty limits, I think you're looking at $2500~3500, having it done professionally.
    FWIW, "every ten seconds" ought to throw a code soon...
  3. rjparker
    7,610
    4,464
    It takes several minutes or a complete fail to throw a pump code. The customer service program for a 2013 expires at ten years or 150,000 miles. If it fails you have dramatically extended stopping distances and no power assist.
    Tim Jones and Air_Boss like this.
  4. Matt98svt
    57
    South Carolina
    2015 Prius v wagon
    Just to add to this I look under the hood and the brake reservoir under the hood is basicly empty. Just had the car serviced about 2 weeks ago at the dealership. Have noticed no puddles under the car or anything dripping
  5. ChapmanF
    15,110
    Ok, how empty is basically empty? Down to L? Below L? Don't see any fluid at all?
    Have you checked the thickness of all your brake pads?
    If the fluid level is well below L, it could be that some air got drawn into the system. There is an extra-special Techstream bleed procedure for getting that air out, and having air in there can produce the rapid cycling you report. So it could be worthwhile to get that fluid level back up where it should be and the air bled and see what happens, before you conclude the $$$ parts need replacement.
  6. CR94
    CR94 Senior Member
    2,642
    1,134
    Northwestern S.C.
    ^^ Yeah, and best find out where the missing fluid has gone, too.
    Air_Boss likes this.
  7. Matt98svt
    57
    South Carolina
    2015 Prius v wagon
    Ok looking at some of the photos and reading about how that accumulator draws in fluid I’m not sure it’s low after all. It’s above min sort of at the bottom of the letters PP/PPE stamped in the plastic. The car has 177k and has always been dealer serviced. They told me last oil service 2 weeks ago it was due for fluid changes because it had been 5 years and also that I would need front brake pads soon. I picked up a thing of dot 3 fluid but not sure if I should add any or not before taking it to the dealer. No lights on the dash yet but I can confirm the sound is from the brake actuator from YouTube videos. I would hate to pay 3k to have it replaced so it might be getting traded in this weekend. A shame because it’s getting 51mpg on the original battery.
  8. ChapmanF
    15,110
    The fluid level naturally goes down as the brake pads wear. It doesn't have to have leaked out of the system, just more of it is staying down in the calipers. That's why if the level is quite low, it's not a bad idea to check all your pad thicknesses.
  9. Matt98svt
    57
    South Carolina
    2015 Prius v wagon
    Car still drives fine and has not thrown a code yet but still doing my research. I see where it is common to replace the brake booster as well as the brake actuator, but which one of the two has actually gone bad that creates the issue?
  10. Tim Jones
    Tim Jones Senior Member
    1,687
    547
    SE Texas
    2011 Nissan LEAF
    It will through a code but could be a long time...... might run like that a year or go out at anytime...... could even strand you....
    I put a used setup on my car and it lasted a year.....then it went out... luckily it was covered under recall but that has expired...
    I think the accumulator is the usual culpret...... but I changed both...... and you have to have parts out of a v not the hatchback....
    very dangerous when it goes out...very hard to stop especially if you had a emergence stop and it whet out then.....
    dealership always changes both parts...
  11. Air_Boss
    Air_Boss Senior Member
    3,913
    1,068
    New Yawk
    How many miles?
  12. ChapmanF
    15,110
    The names are tricky. When you say "brake booster as well as the brake actuator" you've really just said the same thing twice. That's the top thing in this picture. It goes by all these names: brake booster, actuator, master cylinder, skid ECU.
    The bottom thing also goes by multiple names: brake booster pump, accumulator.
    And yes, the booster and the booster pump are two different things. I agree it's confusing, but there's not much to be done about it, other than working extra hard at getting the names right.
    As to which one is causing the problem, it can be either. The problem is often leakage through a valve that isn't sealing completely, and there are a lot more valves in the top thing than the bottom thing, if you like to play the odds. Or you can use a mechanics' stethoscope and listen to them both.
    Or you can start by changing the top thing just because it's less of a knucklebusting job than the bottom thing, and see what happens, and go from there.
  13. Mendel Leisk
    38,253
    Is it typically one or the other, or both, that fail? Could the failure “cascade” from one to the other?
  14. ChapmanF
    15,110
    As I said, it often starts with a valve, and if you like to play the odds, there are a lot more of those in the top thing than the bottom thing.
    As for cascading failure, just consider wear on the pump. In a tight, shipshape system, it may run every few times you use the brake, and every several hours otherwise.
    As a leak develops, people often seem to let it go to running every several seconds on its own before asking if there might be some problem there. If I'm doing my arithmetic right, that may put every day of driving around that way roughly on par with several years in the normal life of the pump and accumulator.
    Tim Jones and Mendel Leisk like this.
  15. GregC1979
    GregC1979 Active Member
    201
    117
    Nowhere
    It's typically the Actuator only. The Accumulator can be replaced at the same time, but not entirely necessary unless there's a code or indications it should be. Most people looking for the safe, easy and inexpensive fix will opt for just the Actuator which is primarily your main issue. Toyota will replace both just to be thourough, and why not? Corporate is paying for it if under warranty.
  16. Matt98svt
    57
    South Carolina
    2015 Prius v wagon
    Thank you for the info. It just started recently so I was hoping if I could replace the problem part vs both pieces with a good quality low mileage one and solve the issue for less than the 3k plus the dealer/shops are asking. The actuator is the lower part though correct? Do you have to remove the brake booster above it to get it out or can it be removed with the brake booster in place? Thanks for your help guys!
  17. Mendel Leisk
    38,253
    Not sure. This video is pretty good, worth a watch, might answer your question:
    IIRC he ends up replacing both, but worth a watch.
    GregC1979 and Matt98svt like this.
  18. GregC1979
    201
    117
    Nowhere
    Whatever you buy I recommend they are NEW from the dealer based on your VIN #. If you have 15'' wheels for instance and you buy one from a junk yard that originally came out of a 17'' wheel car you will have issues, lots of them and vice versa. Always buy new, don't mess around with your brakes.
    Tim Jones and Matt98svt like this.
  19. Matt98svt
    57
    South Carolina
    2015 Prius v wagon
    13842655-2464-47AC-B749-ED6FA34BE400_1_201_a.jpeg For what its worth to others with the brake booster failure issue, I had been searching everywhere for part number 47050-47110, which is the part number given for the brake booster assembly/master cylinder for the 2012-2014 Prius V models. I would see used units for 2012-2014 prius v's but never once found a single used unit that had this part number on car-part.com or ebay etc. I was about to give in and purchase a new unit from toyota for $1200 when I decided to use my borescope to look at the factory unit on the car. First I saw the part number for the master cylinder, 47200-47040, which is only part of the assembly. Then looking around I see 47210-47280 on the front of the assembly, no where on it could i find the part number 47050-47110 on it which I gather is the number for the entire assembly and not stamped anywhere on these booster assemblies. With that information I was able to find a used unit off a 2013 V 5 just like mine with 68k miles on it and got the brake booster assembly and brake booster pump for $400 shipped. If i planned to keep the car longer I might have chosen to purchase a new unit but at 180k i am looking to sell the car within the year while it is still under 200k miles, 180k now, and think this unit should last probably alot longer than the traction battery or head gasket will.
    JBurbank likes this.
  20. ChapmanF
    15,110
    Yeah, it's kind of inconvenient that the nnnnn-nnnnn format is what Toyota uses both for part numbers of parts you can buy (which often do not appear anywhere on the part) and for other numbers that do appear on parts but are not the part numbers of anything you can buy. But that's the way it is. When I had a Ford it was the same way with their numbers.
