Sudden Coolant loss—I don't think it's the head gasket
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by CloudJumper, Dec 4, 2022.
  1. Mendel Leisk
    38,247
    Hotter plug doesn’t make engine run hotter, just makes plug less likely to get a build up.
    jzchen likes this.
  2. CR94
    CR94 Senior Member
    2,642
    1,134
    Northwestern S.C.
    No, EGR plugging does not cause the engine to run hotter, but may be a factor in killing the head gasket, and consequent coolant leakage.
    jzchen likes this.
  3. jzchen
    jzchen Newbie!
    3,296
    1,006
    Arcadia, CA
    Correction, hotter plug = hotter tip, can in extreme cases cause predetonation. EGR recirculates inert exhaust gas which effectively enriches the mixture. Am I still off somehow? We’re talking chamber temp now…
  4. CR94
    CR94 Senior Member
    2,642
    1,134
    Northwestern S.C.
    You're getting closer. EGR dilutes the fuel-air mixture, which, among other effects, effectively reduces the (very brief) peak temperature of gases in the combustion chamber.
    jzchen likes this.
  5. ChapmanF
    15,099
    ^ This.
    Adding fuel would enrich the mixture; adding oxygen would lean it. EGR adds neither fuel nor oxygen, which is what's cool about it. It neither leans nor enriches the mixture. The mixture stays where the ECM has targeted it, the reacting molecules are just farther apart. so the energy release from combustion spreads out over a longer portion of the piston stroke, with a lower, broader temperature curve that never gets into the temperatures where oxides of nitrogen are formed.
    (The left curve shouldn't be read directly as combustion temperature. It's given as Rate Of Heat Release, in joules per degree of crank angle.)
    #45 ChapmanF, Dec 6, 2022
    jzchen and Mendel Leisk like this.
  6. rjparker
    7,601
    4,458
    Low tension rings respond to nothing but new rings and ideally pistons. Assuming the cylinder walls are not scored.
  7. Mendel Leisk
    38,247
    The revised rings won’t fit in the old pistons; they’re dimensionally different.
    CR94 likes this.
  8. CR94
    CR94 Senior Member
    2,642
    1,134
    Northwestern S.C.
    That left graph should make clear why blocking EGR without retarding ignition might be a bad idea.
