Short Ram Intake
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AzusaPrius, Nov 20, 2022.
  1. Mendel Leisk
    38,242
    Same here. Puzzling why they would omit a little plastic piece like that.
    Georgina Rudkus likes this.
  2. Pulse07
    Pulse07 Active Member
    273
    137
    East Bay, California
    2020 Prius
    XLE AWD-e
    You forgot the MAF sensor you have to replace because the oil from the K&N filter. Also MORE dirt in the engine ( i guess some people like that), Bigger holes in the K&N filter means more dirt is allowed in.
    Mighty Car Mods (if anyone remembers them) already myth busted this. Cold air intake/Short Ram Intakes does nothing.
    Bill Norton likes this.
  3. Pulse07
    273
    137
    2020 Prius
    XLE AWD-e
    Same here for the "Stock" look. I probably be open for a "resonator delete", basically you take away the extra chamber in the air duct that meant to muffle the sound, but keeps the stock filter and stock air ducts.
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,125
    2,182
    Taylors, SC
    Basically, my setup is a "resonator delete" with the addition of a high flow rate K&N filter. The intake is in the same place except for the KN& filter replacement, nothing more.
    I especially like the space cleared under the hood. As Azusa stated, the water pump and thermostat are easily accessible for replacement. I also like the space freed from the removal of the OEM filter box for my short hose length installation of the oil cat can. The can can be removed just by unscrewing the cup from the bottom.
    When I needed to drain the radiator to replace the coolant, I just reached for the petcock by extending my left arm down the space behind the radiator without removing any other parts.
    Again, the air filter's condition is fully visible by just opening the hood.
    I might, however, look for a repalcabile OEM type paper filter that will fit like the cone type K&N over the intake, if one is available.
  5. Bill Norton
    Bill Norton Senior Member
    1,822
    595
    MONW, Ks.
    You got me there! (y)
    Only it's more like 30-45 minutes per stop at a DCFC,,,,
    But, this is only when on a Road Trip! How often is that?
    I have my noisy '10 Prius for road trips now!
    Mostly I wake up to a full and inexpensive 'tank' of energy every morning.
    I like that I can preheat or precool it for the wify, and it doesn't make a cloud of stank!
    I have an open mind on this!
    You tell me! Would there be a difference?
    I too work in aerospace and modifications/improvements are made only if they work/save money/are safe.
    Surely you have data from testing each of these 'Products' one at a time.
    Since you promote these vendors (in your signature) and get a little somthin from them, you have the Before/After numbers, correct?
    Can't meet for a show down, but we could do this remotely! (y)
    Wouldn't it be good for you and your 'crew' if your car is faster!
    But, back to testing:
    I'm at:
    1000' MSL, 45°F, close to standard at baro of 29.83".
    And this is a decent day, :unsure: and it will be much colder for months.
    What would your race conditions be at right now?
    Plus, my car has the big dumb 17" wheels and tires that came on a Level 5.
    I'm lucky to get above 40mpg on road trips and lately it's even less around town. WTH is wrong with this car?
    I have a set of stock 15" wheels, but I just bought them and I'm not sure what tires I want, probably the Ecopias.
    I'll be selling the 17" Wheels/tires!
    #45 Bill Norton, Dec 1, 2022
  6. Mendel Leisk
    38,242
    Yeah but… ah never mind.
    vvillovv likes this.
  7. AzusaPrius
    AzusaPrius Senior Member
    1,673
    771
    I guess my water pump and thermostat is even easier to get to with my setup.
    I would not have to remove my intake to actually remove the water pump or thermostat.
    Versus any type like Georgina's where you would have to still remove the intake to get to those said parts.
    That should clear things up.
  8. Georgina Rudkus
    3,125
    2,182
    Taylors, SC
    All I need to do is to remove one hose clamp and one 10mm headed screw; that's alll.
  9. Bill Norton
    1,822
    595
    MONW, Ks.
    Except for the question about how well all the 'Products' you promote actually perform.
  10. AzusaPrius
    1,673
    771
    @Bill Norton
    I was not responding to your comment
    Since you did not answer my question.
    You went on with nonsense around the question.
    Now if you really want to sit at your desk and bicker back and forth on how nothing can improve the performance of the prius, then I think your input is done here.
    I hope this....makes it clear.
  11. Bill Norton
    1,822
    595
    MONW, Ks.
    It's clear.
    I lost track of your question and I don't want to bicker, so we can drop it.
    However.....
    I'm rooting for a Li-ion pack replacement!
    I'm not so sure about 'enhanced air by using water' and getting 20-25% INCREASE IN MPG ON THE HIGHWAY I could really use that!)
    I read about the Go Pedal signal smoother, I'll pass on that also.
    I guess having sponsors is ok here.
  12. Georgina Rudkus
    3,125
    2,182
    Taylors, SC
    If , as you do, live in California, you will want to keep the original OEM intake and all of its components, since you might need to replace it to pass the visual C.A.R.B. smog inspection.
    As for me, I will keep the OEM and equivalent replacement NiMH battery, as it has a proven track record of lasting for many years. My 2012 battery is still as strong and efficient as when it was new, since I carefully monitor its temperature continuously with my Scangauge 2.
    For diagnostic purposes, I will not make irreversible modifications to any system including wiring, as I have a long career of trying to figure out modifications made by others on all types of vehicles. Such modifications can void warranties or incur high and expensive diagnostic costs. Some shops will even refuse to work on such modified vehicles.
    I'm just here to help others.
    #52 Georgina Rudkus, Dec 3, 2022
    jzchen and Bill Norton like this.
  13. jzchen
    jzchen Newbie!
    3,296
    1,006
    Arcadia, CA
    I was about to mention the CA smog check. You’ve effectively removed the “HC” gas trap which causes all (that I am aware of) aftermarket intakes on Toyotas to not get a CARB EO #. For most this means starting at year 6 of age the intake will need to be put back for biennial smog inspection….
  14. AzusaPrius
    1,673
    771
    Update after driving to work with the new intake, I can feel how well the engine now runs.
    Taking on big inclines where the posted speed limits are 60mph and everyone does 80mph.
    Very easy to keep 60+mph on an incline now without having to push the pedal more
    This is where I got it from if anyone wants to check them out.
    https://www.blackhawkjapan.com/?rfsn=6994644.446fae
  15. Georgina Rudkus
    3,125
    2,182
    Taylors, SC
    I'd be interested in more details of the filter. Is it a oil wetted like a K&N or a dry one ? Can you get a replacement, if needed? How easy is it to remove for cleaning or replacement?
  16. AzusaPrius
    1,673
    771
    This is a dry filter type and can be replaced very easy.
  17. Georgina Rudkus
    3,125
    2,182
    Taylors, SC
  18. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    As previously said an intake wont help performance it just makes some noise. Only way it can help performance is with a tune but requires an engine that has alot of horsepower and can use the extra air flow. Not so much with a Prius engine.
    If you want a cold air intake its easy and almost free just bypass the coolant loop to the throttle body. Remove the coolant lines from the throttle body and connect them together. 180 degree hot water no longer flows through the TB. Your throttle body is now instantly around 90 degree's colder. And the engine likes that alot.
    You live in California it never gets cold you don't need it.
    Its the first thing I did when I bought my 07 Prius new. Car ran perfect for 14 years then i sold it. First thing I did with my Corolla.
    The more powerful successive Gen's would probably see some small power increase or at the least seem more frisky under full throttle.
    And you prolong the life of the TB not having 190 degree water flowing through it. That's hard on the throttle body FBW motor.
    Use a 3/8 pex barrel found at Lowes or HomeD connect the 2 hoses together. Drive away.
    #58 edthefox5, Dec 7, 2022
    jzchen likes this.
  19. AzusaPrius
    1,673
    771
    @edthefox5
    You must not know California very well.
    I live where the temps dip below 32F and can get as hot as 118F.
    You must also not know that a better flowing air intake will in fact help the engine breath better in which it will perform better.
    Pretty sure if you got into my 2010 you should be able to tell right away, this bish has some pep in her step.
  20. edthefox5
    10,096
    4,795
    Clearwater, Florida
    Sounds like you live in hell.
