CVT oil change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Wobblybike, Dec 7, 2022.
  1. Wobblybike
    Wobblybike Junior Member
    Los angeles
    I checked on the internet the Toyota bulletins on changing the oil in a 2010 Prius and it says it should last the live of the car unless there are leaks or repairs to it...... so why do people say around 100K on this forum.. I'm just asking as I bought the oil but finding out that I don't need to do the CVT liquid change... thank you in advance.
  2. ChapmanF
    18,567
    The oil you bought was ATF WS, I hope?
    The CVT in a Prius is not mechanically similar to CVTs in non-hybrid cars.
  3. Mendel Leisk
    41,924
    What's the miles on it? My 2 cents: do it at least once, around the one year or 10K miles is good. Then you can let it go quite some time,/miles, say till 10 years or 100K miles.
    Toyota says nothing about it, for maybe a couple of reasons.
    1. It will survive a long time, no arguing that.
    2. It simplifies maintenance requirements.
    There's a link in my signature about transaxle fluid change.
  4. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    all fluids require changing unless you want to replace your transmission
  5. bisco
    52,401
    but what's the life of the car?
  6. Paul E. Highway
    Paul E. Highway Active Member
    209
    129
    Hawaii
    It's not a CVT. A fluid change with ATF WS is incredibly cheap insurance.
  7. ChapmanF
    18,567
    In what way do you think it is not a CVT?
    It has a shaft where engine power comes in. It has a differential delivering output to the wheels.
    It can deliver power from one speed,torque at the input to a different speed,torque at the output, and the ratio between them is continuously variable, not restricted to certain steps the way it is in non-CVTs.
    Any device that does the above is a continuously-variable transmission, a CVT.
    We get some of this "it's not a CVT" confusion periodically because there are different ways other CVTs have been built (such as with cones, belts, discs, or the like). #2 mentioned that. But whether something is a CVT or not isn't determined by how it is built—only by what it does.
    Now, where the "how it is built" can matter is in the choice of oil. Some of those other ways to build a CVT call for a special kind of oil. The CVT in the Prius, however, uses ordinary Toyota ATF WS.
  8. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    Lifetime fluid is marketing.
    Lifetime the automaker wants or lifetime the owner wants? Different perspectives sometimes.
    The fluid is used to lubricate gears and is still subject to things like shearing and oxidation. If you like your car, and plan on keeping it, a drain and fill is easy and doesn't break the bank.
    Georgina Rudkus likes this.
  9. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,513
    2,503
    Taylors, SC
    To the auto manufacturers, it is apparent that it is their warranty period on the vehicle.
    BMW until recently recommended 15k oil changes as a marketing tool.
  10. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    This is an easy one.
    It is because the Internet if full of self appointed experts who know more about any device than the Engineers who designed and built it.
    Even though those real experts likely have a combined training and experience into the hundreds of years.......or thousands maybe.
    :rolleyes::whistle:
  11. bisco
    52,401
  12. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    And work for companies that cost engineer things and want you to buy another one of their products. Absolutely no compromise being made there.
  13. bisco
    52,401
    bean counters always have the last say
  14. ASRDogman
    ASRDogman Senior Member
    7,833
    3,990
    "Lifetime" means for the lifetime of the warranty..... Once the (emissions) warranty is over, you're on your own.
    It was never meant to last forever. So what is the "lifetime" of the transmission????
