Strange behavior with engine not cutting out
Discussion in 'Gen 4 Prius Main Forum' started by Steve Ball, Dec 8, 2022.
  1. Steve Ball
    Steve Ball Junior Member
    17
    New York
    2021 Prius
    LE AWD-e
    All -
    My 2021 Prius has exhibited a strange behavior a few times - strange, but not necessarily bad. Just I think it is a little quirky.
    On my commute (mostly highway, 65-70mph, about 45minutes driving), if I let off the gas pedal, the car rolls along - and downhill, will pick up speed pretty swiftly. Engine seems completely off, even if >64mph (and EV) in this.
    However last night: it seemed like the engine was not cutting off, and was remaining on, even if a little bit - car did not roll as much downhill (pick up speed as much) as engine was definitely on a little bit. Hmmm. I put the car into 'B' and this was noticeably different - engine braking (and engine noise) much more apparent - but back to 'D' and engine definitely was not cutting out as normal. Even if engine was somehow on, MPG meter was all the way to top (100MPG+) so whether engine was on but very lightly fueled, I don't know.
    Car stayed this way pretty much the whole ride back, very, very hesitant to switch to EV at <64mph, even on downhills. Battery was at mixed ranges - 2 bars from empty and all the way to 2 bars from full - and car did this across all of these.
    Didn't do it today.
    Wonder if there is something specific? No warning light, car is fine, MPG is fine - just the engine was still being ran for some reason.
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    961
    542
    Cow-lee-fornia
    2023 Prius
    Most likely the cold. Even though you can ride along in EV mode, the engine still needs to be a certain temperature in order to operate optimally. You being in New York is gonna make the engine run for longer periods to stay in the correct temperature range.
    Pulse07 likes this.
  3. Steve Ball
    17
    New York
    2021 Prius
    LE AWD-e
    I don't think it's the cold. It will cut out just fine in the cold once warmed up - and yesterday was around 50F so not too cold. Something was directing the car to keep the engine on. To add, the graphic showed battery and wheels (no power feed from engine) even though I could hear and feel the engine was on slightly.
  4. Doug McC
    Doug McC Senior Member
    1,080
    419
    Midwest
    2022 Prius
    The display isn’t always reality. The system is monitoring a multitude of parameters and starts and stops the ICE for as many reasons. Air temperature, hybrid battery temperature, use of electrical devices (fan, lighting, heaters), having the cabin heater on, even the radio, etc. can result in the ICE running to meet anticipated electrical and other energy requirements, among many other factors. Trust the system to protect itself. The display is telling you (primarily) the “driving” and “regenitive” force.
  5. CR94
    CR94 Senior Member
    2,733
    1,193
    Northwestern S.C.
    How are you determining whether the engine is "on" in those circumstances? Above a certain speed (about 45 mph for 3rd generation, maybe higher for 4th) the engine always continues to rotate slowly while you're coasting, although fuel delivery is shut off if the engine is warmed up and happy. Whether it is rotating at borderline road speeds isn't obvious, unless you have added instrumentation that can show (for example) engine speed.
  6. Steve Ball
    17
    New York
    2021 Prius
    LE AWD-e
    I could feel it (more resistance while going down hill, less tendency to speed up) and hear it a little too. Again, not as severe as 'B' (which I tested), and today's commute it did not happen at all: when coasting down hill, engine force was not noticeable nor audible, which is why - since I'm so used to it - the car's behavior the other day was strange.
    Anyway - other poster stated perhaps other things going on. As I said, this is an intermittent and has happened maybe a handful of times over the past year - so I was just wondering if this was (is) a known thing that happens.
    Yes, agreed on all - the car of course looks after itself - so was just wondering more than anything.
  7. Doug McC
    1,080
    419
    Midwest
    2022 Prius
    The short answer to your question is “yes, it is a known thing.” These are fascinating vehicles, and the more we learn about them, the more fascinating they become.
  8. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    I would say this is somewhat typical especially at this speed. Mine (2016) never likes cutting back to 0 rpm running in the 60's (but it can up to 72 MPH and does sometimes). If running the cruise control its much less likely to cut out the engine then if your driving with the pedals also. I have a scan gauge so I can tell pretty easily if my engine is truly running or not.
  9. BiomedO1
    3,973
    2,093
    SacTown, Ca
    LoL; Here's a joke: How do you tell if a guy is a Prius owner or a Motor-head?
    Answer:
    A Prius owner asks, Why doesn't my motor cut off or shut-down.
    A Motor-head asks how do I fix my motor cutting-off - Dude; you need to bypass your speed sensor.
