Sudden HV overcharging
Discussion in 'Generation 1 Prius Discussion' started by Jeff F, Feb 10, 2013.
  1. S Keith
    S Keith Senior Member
    799
    328
    AZ
    2003 Prius
    Having used both Torque Pro and MiniVCI, MiniVCI is best hands down as a diagnostic tool. Period. At <$30, it's barely more than bluetooth OBD and Torque Pro at about $18. This assumes one has a suitable laptop for installation.
    Torque Pro is a great tool, and it's more practical for continuous monitoring given the portability.
    bwilson4web likes this.
  2. bwilson4web
    15,518
    Several years ago, a Gen 1 with 320,000 miles was lost in a traffic accident. It was running on the original battery.
    Heat is the enemy and that is what metrics can provide.
    S Keith likes this.
  3. shimel
    shimel Junior Member
    after over 20 years of driving my 2002, I saw this charging situation last night. Driving on freeway it charged up to about 96% and stayed there for maybe 10 minutes. then in discharged back down to about 55% and stayed there until I reached my destination about 10 minutes later. Upon driving home about 2 hours later, it maintained about 65% charge. About 170000 miles, original battery
  4. dolj
    dolj Senior Member
    7,645
    3,858
    Wellington, New Zealand
    That sounds like something @ChapmanF might know about.
  5. TheLastMojojomo
    TheLastMojojomo Active Member
    231
    162
    US
    You should have been watching voltage difference between the Hybrid Battery Cells. I had a similar experience when my initial Project Lithium Battery failed after 3-days.
    Whenever voltage difference spiked significantly upon regen braking... State of of charge would shoot up to 80+٪ in a matter of seconds.
    You can watch this happen in my YouTube vid here:
    Watch starting around 3-minutes you'll see my State of Charge parameter spike to over 85% whenever voltage difference spikes under regen brake.
    If you'd like the full context to this video... see my thread: I think my Project Lithium Battery failed in 3-days.
  6. dolj
    dolj Senior Member
    7,645
    3,858
    The poster does not say anything about having a Lithium Ion battery. Also of note, the poster's car is a Gen 1 (this is the Gen 1 forum after all!) and I believe what the poster observed is a normal mode in a Gen 1. ChapmanF has commented in the past noting this behavior and hopefully, he will see this thread so and jump in and fill in the blanks.
  7. bwilson4web
    15,518
    Cell balance is a valid concern. He may have gone through the mythical rebalance cycle.
    Compared to what we have today, the earlier battery management systems were primitive.
  8. ChapmanF
    15,565
    Well, about the best I can do is google for the threads where I posted about it before. Those were, well, post #4 in this very thread ;) and, a couple years later, this other thread where I gave more details when it happened again.
