2012 PIP 90k service - highway robbery?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Belgian Monk, Dec 2, 2022.
Tags:
  1. BiomedO1
    4,225
    2,209
    SacTown, Ca
    That's very strange. Toyota long life coolant is good for 100K miles or 10 years; but when you change it - it's only good for 5 years or 50K miles?? :(:sleep::censored::cry:
  2. Mendel Leisk
    41,953
    Not that strange; IIRC Honda had sim schedule. Maybe the logic is that a brand new engine and coolant system will be very clean. After the first drain you’ve still got 20~30% of the old coolant left behind, and corrosion is starting to get a foothold, warranting more frequent subsequent changes.
    N.J.PRIUS likes this.
  3. vvillovv
    vvillovv Senior Member
    4,332
    1,516
    NY
    One of the differences between the regular prius and plugins is the %% EV to HV driven. Adjust accord ingly.
    Most DIYers like to get started early in the schedule so it's not as critical to get the complete process for any one service fully correct the first time. If everything proceeds without a hitch no harm no foul, but it there are unresolved issues it never hurts to do it again sooner than later and try harder to get the process as close to perfect as possible.
    When having the work done by a shop, it's extremely difficult to know much of anything about the actual work that has been done or why each shop has it's own set of procedures they follow and or recommend
  4. GregersonIT
    GregersonIT Member
    172
    92
    Livermore
    2020 Prius Prime
    Wow, I just got fluids for coolant, inverter, transmission, and engine all done with Amsoil stuff for 533. I thought was a little high but with amsoil it's what I would expect to pay at a shop anyways.
    -Kevin
