JDM Engine in a US Prius?
Discussion in 'Prius v Technical Discussion' started by RunningOnMT, Feb 13, 2020.
  1. framire
    framire New Member
    Savannah,GA
    Perfect! That’s the info that i was looking for, Thanks for the help!
  2. MrPete
    MrPete Active Member
    499
    190
    Colorado, USA
    A question on jdm engines. All ad's I see do not give a specific year.
    Yet for reliability, that is crucial info.can I spec 2015?
  3. 1996bot
    1996bot New Member
    fort worth, tx
    I'm in Fort Worth and am in desperate need of an engine swap on my 2012 prius III. When I saw you're in Dallas my heart jumped. Would you mind telling me who your mechanic was and where you sourced the engine? Thank you so much!
  4. 1996bot
    1996bot New Member
    fort worth, tx
    (Sorry if double posting) Could you tell me who your mechanic was and where you sourced your engine? I'm in desperate need of a swap for the exact same issue on my 2012 prius III out in Fort Worth. Thank you so much.
  5. LB28760
    LB28760 New Member
    NC, USA
    Thanks so much for all this info! Recently discovered a seized engine in 2012 V and JDM engine certainly seems the way to go.
  6. bkepler
    bkepler Junior Member
    SW Pennsylvania
    2013 Prius v wagon
    Did you replace with a JDM or not at all?
