Tire pressure monitors
Discussion in 'Gen 2 Prius Main Forum' started by techman01, Nov 30, 2006.
  1. techman01
    techman01 New Member
    Long Island, NY
    Finally have my new vehicle, but I went to get new tires put on Triple Thread, and they broke the tire pressure monitor on one of the tires!
    Size 195 was the triple thread...so he said that he will only put size 185 tires on the vehicle and i ended up getting the comfort tread size 185...
    he will replace the monitor tomorrow morning(getting part direct from Toyota)
    Is there a secret to putting larger tires on the Prius without breaking the pressure monitors?
    He even mentioned that they would have to be extra careful putting them on because of the monitors, and he heard told his techs as well(I was dealing with the store mgr)
    Thanks.
  2. McShemp
    McShemp New Member
    371
    SA, TX
    According to what I've read here - no TPMS problems for me yet - each monitor must be registered with the car's ECU. So, a simple replacement by the tire store may not be the end of it. Search the forum or call your dealer for more info.
  3. Vaughn
    Vaughn Junior Member
    37
    Lubbock TX
  4. techman01
    Long Island, NY
    Yeah, I saw that it has to be registered with the ECU. Can that only be done by the dealer? Or should he have the necessary equipment? (Goodyear owned & Operated)
  5. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    <div class='quotetop'>QUOTE(techman @ Nov 30 2006, 06:22 AM) [snapback]355644[/snapback]</div>
    Yes, only the dealer can do it so be sure to get the number off the new monitor before it is installed. It is right on the outside.
  6. maryingels
    maryingels New Member
    <div class='quotetop'>QUOTE(Allannde @ Nov 30 2006, 10:20 AM) [snapback]355687[/snapback]</div>
    A newbie question: A few weeks ago I had Triple Treads (the 195s) put on my 06 by Discount Tire. Does this mean that my tire pressure monitors are not working?
  7. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
  8. maryingels
    <div class='quotetop'>QUOTE(galaxee @ Nov 30 2006, 03:29 PM) [snapback]355923[/snapback]</div>
    Thanks Galaxee! This makes more sense now. The shop said that they had plenty of experience with TPMs and it sounds like I would know if I had a problem.
    This is a great forum!
