Refurbed battery, now won't start.
Discussion in 'Gen 2 Prius Technical Discussion' started by Todd98391, Jan 7, 2023.
  1. Todd98391
    Todd98391 New Member
    Seattle
    Hi guys, I have a 2005 Prius, trouble started with a blown head gasket. Took me forever to fix it, but got it done. Took a while to bleed the air out. After all said and done, the battery crapped out. So I just finished returning the battery, changed out 4 cells, balanced everything, good to go. Installed the battery and now the car won't start. Still getting the triangle of death. Dash lights up like normal. Won't start or go into gear. Tried to put it in maintenance mode, won't run. What did I miss!!! Its been off the road for a year. Thanks!
    Tombukt2 likes this.
  2. Tombukt2
    13,116
    2,354
    Reinsert the big orange plug on last step flip down Smartly. Don't know what I speak of You will in a few minutes.
  3. Leadfoot J. McCoalroller
    8,112
    7,591
    Pennsylvania
    2018 Prius c
    orange safety plug?
  4. Albert Barbuto
    Albert Barbuto Active Member
    108
    100
    Northeast USA
  5. Tombukt2
    13,116
    2,354
    In the picture above the last stroke the locking down sometimes you need to pull down so smartly it hurts your finger for that last little switch to make the contact that says everything is a okay and go ahead. Seriously.
  6. Todd98391
    Seattle
    Dang, you are the man! Thank you very much!
  7. Tombukt2
    13,116
    2,354
    You are welcome now enjoy the hale out of your car..
