Tires size possible deal breaker on 2023 Prius?
Discussion in 'Gen 5 Prius Main Forum' started by Dionysus81, Jan 13, 2023.
  1. Dionysus81
    Dionysus81 Junior Member
    Honolulu
    I was wondering if anyone has concerns about the almost non existence of tires in 195/60R17 and 195/50R19 for the new Prius. I searched the web and it seems no one keeps this size in stock. The 19 inch size is not even an option to find in most tire search tools. Tire Rack, Sam’s Club, Walmart, Costco and others don’t even let you search for these sizes or have nothing at all.
    With no spare tire included in any of the new 5thGen this is grave cause for concern. I can imagine a case where your tire may sustain unrepairable damage. Good chance of getting stuck with no car to use at all with the tires being so rare. May have to wait days or weeks to get a replacement tire or be forced to go to the dealer for a replacement and pay maybe $300+ per tire?
    Would appreciate any thoughts on this matter. Also please point out if you find somewhere that actually has these tires and at what price points.
  2. beamsley
    beamsley Member
    66
    100
    2023 Prius Prime
    Premium w/ Solar Cells
    I'm in the same boat. Ultimately I'm hoping I can fit 205/65/R16 tires on 16 inch rims because it's a much more universal size with a close diameter.
    Supposedly the 19 and 17 inch sizes are common in Japan, but that doesn't really help us here in North America.
    Sarge and Dionysus81 like this.
  3. Trollbait
    12,653
    When Japanese cars calling for 0w16 motor oil first arrived in the US, the dealer was your only source for it. Now you have your choice of brands in the likes of Walmart.
    The sizes being common in Japan means they aren't like the tires for the i3, whose tires likely fit the 19in rims. That is not unique. Options will arrive.
    Bob P., daisy555, GuyLR and 1 other person like this.
  4. JoeBlack
    JoeBlack Member
    112
    89
    Europe
    2021 Prius PHV
    Yeah, I have the same problem in Europe. I am trying to find a decent 195/60R17 tire, but other than Michelin Primacy 4, I pretty much did not find anything, plus I found ZERO winter tires with these dimensions ...
    Even finding a decent aero styled wheels turn out to be quite a time-consuming challenge, as most of the aerodynamic ones are 19" or even bigger (Borbet AeroTec).
    What do you think of 17" OZ Rally Racing on a Prius? :-D
  5. Pri3C
    Pri3C Active Member
    183
    131
    Midwest
    2014 Prius c
    I think you’re right. This new generation of Prius is definitely getting noticed, and the big tire makers for the North American market are $urely paying attention too.
    daisy555 and GuyLR like this.
  6. Trollbait
    12,653
    IIRC from the photos, the tires on the car were made by one of those big tire companies. Somebody already importing tires to these other markets, and likely from the same factory.
  7. mikefocke
    4,038
    1,832
    Sanford, NC
    Had a bolt go through the tread destroying the tire while on a trip to a major metropolitan area. Car had been in use a year with 3k miles. Went to call around and get a replacement as I was 300 miles from home with an 8 year old accompanying me on a sightseeing trip. There were only two available and it took three days, the entire planned trip, before I could get the single tire replaced.
    So I judge: legitimate concern.
  8. Leadfoot J. McCoalroller
    8,133
    7,630
    Pennsylvania
    2018 Prius c
    Rare tire sizes are a drag.
    But @Trollbait has a point: often they don't stay rare.
    That just means it's too early to tell, for this particular trim with its tire size. Buy the version with common 17" tires if you're worried.
  9. bisco
    52,284
    i can't see anyone making or importing tires that only fit a car selling 35,000 units/year.
    i would rather have the tyres available first, then buy the car
    PrimeDan and JoeBlack like this.
  10. MalachyNG
    MalachyNG Active Member
    304
    225
    Northern NY
    2022 Prius Prime
    I think I remember reading in one of the threads where somebody posted the new owners manual that it made a few references to the 19" wheels not being appropriate for winter driving due to the low profile tires. I'm getting the feeling that you would have a hard time finding winter tires in that size and you'll probably need to find a set of 17" wheels for cold weather. Hopefully there are aftermarket wheels out there that'll still fit (maybe with the right spacer) and can take a more standard tire size. At least for winter tires.
    McCarthy likes this.
  11. Name Cannot Be Changed
    United States
    I have the same concern. LE size is 195/60 R17, but I can't find one anywhere. It is definitely an oddball. Tried Tirerack, Bridgestone, Tirebuyer, Discount/America's Tire, Michelin and GoodYear. No luck. (Will the Toyota dealer be the only potential source? What if you get a flat? Where do you get snows or All-Weather tires? etc.)
    This WILL be a problem. I drive cross-country road trips. The fix-a-flat kit is a joke, and a temporary compact spare is useless 100+ miles from the nearest tire shop (Toyota or otherwise). What I'm thinking now is that buying the car has to be contingent on receiving at least one extra tire upon delivery. No telling if Toyota will even sell me one. It doesn't even need to be mounted. For a long road trip I could keep it in the back seat, knowing I could get it mounted pretty much anywhere.
    p.s. even the wheel-size web site Rim and Tire-Size Calculator is stumped when looking for plus/minus-size tires, reporting "Selected OE wheel/tire size is unfeasible"
  12. Hammersmith
    Hammersmith Senior Member
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    FYI, Bridgestone already makes a Blizzak VRX3 non-studded winter tire in both Prius sizes for the Japanese market, so at least that part is just a distribution issue rather than a manufacturing one. Granted that the Blizzak wouldn't be my first winter tire choice(Hakkapeliitta or X-Ice Snow), but one choice is better than none.
    195/60R17 サイズ 検索結果 - タイヤを探す(乗用車用) - 株式会社ブリヂストン
    195/50R19 サイズ 検索結果 - タイヤを探す(乗用車用) - 株式会社ブリヂストン
    Toyo has now updated their Japanese website with the OEM Prius tires. Yokohama's Japanese website seems to be down, so I can't check to see if they already have tires in the needed sizes.
    PROXES Comfort IIs(プロクセス・コンフォート ツーエス)|タイヤ製品情報・検索|TOYO TIRES(トーヨータイヤ)製品サイト
    At the moment, there seem to be several acceptable(but not perfect) options for cold climate situations depending on which trim level you get and whether you prefer one set of wheels or two(this is assuming safety over mpg). Mix and match the sizes according to your preferences.
    17"
    195/60R17 - Toyo all-season(stock OEM)
    195/60R17 - Blizzak VRX3 (winter)
    205/55R17 - Hakkapeliitta R5 or 10, X-Ice Snow (winter)
    205/55R17 - CrossClimate 2 (all-weather year round)
    19"
    195/50R19 - Toyo all-season(stock OEM)
    195/50R19 - Blizzak VRX3 (winter)
    If you put a gun to my head right now, I would go with stock Toyo 19" for summer(I plan to get a XSE Premium) and 17" Hakk R5 or X-Ice for winter. If Michelin comes out with a CC2, Pilot Sport A/S or X-Ice Snow that fits on the stock 19" wheel, that would change my choices, as well as Nokian coming out with a 19" compatible WR G4 or Hakkapeliitta R5. I typically put on less than 10k miles a year, so a single all-weather tire makes better economical sense for me, but safety is more important to me if a top all-weather tire is not available in 195/50R19.
    edit: fixed a tire size from 215 to 205
    #12 Hammersmith, Jan 15, 2023
  13. Trollbait
    12,653
    The i3 has odd tire sizes. Four actually as there are two wheel sizes available, and the front and rear tires have different widths. When the car arrived, it was dealer only for the tires, but now the major tire stores can get them.
    Those sizes were unique. BMW had to have a tire company make them to their specs. The tire sizes on the new Prius aren't unique. Other cars use them in Japan. They just aren't used in the US now. Only dealers will have them at first, but availability will improve. If that availability at first is a concern, then wait. There are other good reasons to not buy a new model the first year.
    There is even snow tires for these sizes in Japan. Maybe snow chain options is something to look into until the tires become available.
    Not sure how low profile alone would be bad for driving in snow or ice.
    I carry a plug kit and portable compressor in the car. Have made several repairs. The kit states they are temporary repairs only, but I've driven on them for years. One needed to be replugged after a couple years when it developed a slow leak.
  14. bisco
    52,284
    those tires will be like the prius battery has been for 20 years, a thorn in the nice person.
    deals will be hard to come by, even after availability improves. choices will be limited, and other manufacturers aren't going to make an odd size for a niche market. choice will be lacking
  15. Todd Bonzalez
    Todd Bonzalez Active Member
    250
    160
    Ireland
    How about Yokohama BluEarth Winter?
  16. Sue Case
    Sue Case Junior Member
    89
    44
    Maryland
    2023 Prius Prime
    So if one had to pick between the 17 inch and the 19 inch for eventual replacement, which is better. Board seems to think size 17 tires will be a little easier to replace or match up.
  17. bisco
    52,284
    i have no idea. i'd want the ones that give the smoothest, quietest ride. but for replacement availability, it doesn't look like either is better.
    people may scoff now, but tyres are a big issue here. there are hundreds of different threads, and a wide variety of replacement tyres up until gen5.
  18. Todd Bonzalez
    250
    160
    Ireland
    The 195/60R17 are hard to find, but the 195/50R19 seem harder to find (and would probably give a worse ride anyway)
    A possible alternative to the 195/60R17 is 205/55/R17...?
    douglasjre and Dionysus81 like this.
  19. Mendel Leisk
    41,824
    Rmay635703 likes this.
  20. Hammersmith
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The answer is meaningless right now unless you need snow tires. Unless you put on over 30k miles a year, it's going to be a minimum of three to four years before you're going to need to buy replacement tires; maybe as many as five to seven years if you don't drive much. Nobody here has a crystal ball to tell you which tire sizes are going to be available by then.
    Those of us in cold climates are a little more pressed for time because we will need winter tires in about nine months if we buy a new Prius this year. But if you only need all-season tires, you've got loads and loads and loads of time(barring a catastrophic flat).
