Oil Leak Near the Exhaust Manifold
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by richard203, Jan 14, 2023.
  1. richard203
    richard203 Member
    276
    60
    SF
    Hi when I did my oil change today I saw some oil on the engine and follow it up to below the Exhaust Manifold and next to it. I can not see it on top of the engine since the windshield thing blocking it. Do any1 know where its leaking from? Im thinking mybe leaking from the valve cover but another spot of oil is next to the Exhaust Manifold do any1 know what is near there that can leak oil?
  2. JC91006
    JC91006 Senior Member
    16,806
    8,593
    over time it is quite normal for oil to leak out of the valve cover gasket.
  3. Mendel Leisk
    41,808
    It's on the back side of the engine, towards right or left end? (r/l as you sit in the car)
    At right/rear corner there's timing belt tensioner, and oil pressure sensor is just up and over to right from oil filter. Not sure about 2nd gen, but both those have been prone to leak on 3rd gen.
    #3 Mendel Leisk, Jan 14, 2023
  4. richard203
    richard203 Member
    276
    60
    SF
    its on the top right behind the engine or passenger side
