Help me identify this part
Discussion in 'Gen 3 Prius Accessories and Modifications' started by J. Naranjo, Jan 15, 2023.
  1. J. Naranjo
    J. Naranjo Junior Member
    I am looking for the button that is next to the 12v lighter plug in the center console. Part #6 in the diagram. I am not planning to put a button. Just don’t like a a hole there. Thank you in advance.
  2. AzWxGuy
    AzWxGuy Weather Guy
    1,054
    538
    Tucson, AZ
    2021 Prius
    A little confused. Your info says you have a Gen II (2005) while the attached graphic is from a Gen III. Specifically, it appears to be the auxiliary box located beneath the "flying bridge" that everyone hated so much. The round hole on the right is for the auxiliary 12V socket and the square on the left that you have indicated is for the driver/passenger heated seat switches (if equipped). I snipped the page from my 2011 owners manual:
    You might be able to order the blank that is installed in the non-equipped models, but I would bet you will have to order part #5 that comes with the blank. Otherwise, maybe an auto recycler pick-and-pull would have what you are looking for.
    Montgomery likes this.
  3. J. Naranjo
    This part is for a Gen 3. I forgot to update my profile.
  4. SnowMexicanuck
    55
    66
    Quebec, Canada
