Annoying fastener on hybrid battery filter
Discussion in 'Gen 4 Prius Technical Discussion' started by fsu23phd, Jan 21, 2023.
  1. fsu23phd
    fsu23phd Active Member
    186
    114
    Wilmington, NC
    I am not the most technically inclined car owner..
    I have a 2016 prous 2 eco, 55ish k miles.
    I decided to clean the traction battery air filter, and found this video
    At about 20 seconds, he uses a screw driver to remove a fastener. For him it seems that he turns and the middle part of the fastener protrudes, and he then grabs the middle part and yanks it out.
    I cant get this to work. At first the entire fastener would turn, so I stabbed the outside portion with a flat screw driver, and they move independently, but the center part doesn't come you. I tried grabbing the outside portion of the fastener w a pair of pliers and yanking. No avail (I stopped before breaking it.
    Any ideas?
  2. Mendel Leisk
    41,908
    Honda had that style of fastener, first plastic fasteners I recall seeing, holding the plastic liners in the wheel wells one we had. I think the trick is to press very little when unscrewing, otherwise it jumps the threads, doesn't back out. A flat blade screw driver under the edge of the head, lifting a little, as you rotate the screw counterclockwise with the Phillips screw driver would help I think.
    Looks like yours is a little mooshed now, maybe score a replacement.
    Mambo Dave and fsu23phd like this.
  3. Elektroingenieur
    2,515
    3,287
    Three Touring
    As @Mendel Leisk kindly mentions, clips of this style are meant to unscrew, but not completely. In the Repair Manual (more info), Toyota writes, “Remove the clips by unscrewing the center pin and prying out the shell,” with this illustration:
    If that doesn’t work, just pull out the existing clip and buy a new one, part number 90467-06165-C0, list price $1.81, shown in Figure 58-04, Mat & Carpet, part name code 58441N.
  4. fsu23phd
    186
    114
    Wilmington, NC
    Good call yall, thanks, indeed turning it w8th absolutely no downward pressure caused the center part to come out, and I was able to grab it and yank it out.
    The filter wasn't even dirty at almost 7 years old and 55k mi. I blew a little air on the fan for fun and a tiny amount of dust came off, but it looks like thos wasn't particularly necessary.
    Thanks again for the help!
    ColoradoBoo and Mendel Leisk like this.
  5. Doug McC
    Doug McC Senior Member
    1,082
    421
    Midwest
    2022 Prius
    In the OM in section 6.3 “Do It Yourself Maintenance” on pages 546 and following there are instructions for doing this and warnings about what to do and not to do such as
    “When cleaning the air intake vent
    When cleaning the air intake vent, make sure to only use a vacuum to suck out dust and clogs. If a compressed air blow gun, etc. is used to blow out dust and clogs, the dust or clogs may be pushed into the air intake vent, which may affect the performance of the hybrid battery (traction battery) and cause a malfunc- tion.”
    Just some information for those who might be doing this in the future. FWIW
    jzchen likes this.
  6. ColoradoBoo
    ColoradoBoo Senior Member
    1,271
    879
    Monument, Colorado USA
    Those clips are a thorn in our sides!
    I'm getting ready to make an order on McGeorge Toyota so asked them what the part number for that ridiculous clip. They said they think it's 90467-06165-C3 but in their search engine page it says it does not fit my 2021 Prius....neither does 90467-06165-C0. (But it IS that one in the diagram that you unscrew a bit before it pops out.)
    You'd think an organization as big and smart as Toyota would sell a bag of the assorted clips that fit our specific vehicle....or, at least, sections of it!
    But, when you can't find anything, zip ties come in all sorts of sizes but it does make us look like hack mechanics!!
    fsu23phd likes this.
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    These are available at any autoparts store, typically in packs of 5 for about 4 bucks. They're also all over ebay in bulk bags, relatively cheap. They do come in a few different sizes and lengths.
  8. ColoradoBoo
    1,271
    879
    Yesterday, I was near my Toyota dealer so ran in and removed my clip from the rear seats' HV battery cooling fan and had the parts folks see if they had any.
    After a LONG wait, they said they had one, it's called a rear seat clip but the part number is strange....90467-06153. American Toyota parts places don't list it but on Amayam it does....$1 for the clip and $19 to ship it...hehehehe My dealer charged me a buck 80.
    Yes it has grooves on the part you pull out but they are not threaded, so you have to use a tiny flat-head to get it to come out a bit and then pull it about halfway out before you pull the whole clip out from the hole....VERY stupid design, IMHO.
    I think the closest American part number is 90467-06151-C0
    So they have two VERY sweet new rides at the dealer....a 2023 Sequoira TRD ($76K) and a 2023 bZ4X XLE ($46K). The bZ4X was very nice but I popped the hood to have a look at her innards and VERY disappointed she only has a prop bar to hold open the hood, no struts. Really? We need to pass a law that ANY vehicle costing more than $30K needs struts on the hood...mandatory!!!
  9. Mendel Leisk
    41,908
    Think I’d rather have the prop bar: simpler, cheaper, and bulletproof.
