Best way to properly install transmission input shaft seal ?
Discussion in 'Gen 3 Prius Technical Discussion' started by Salopeck James, Jan 23, 2023.
  1. Salopeck James
    Salopeck James Junior Member
    United states
    I removed a damaged seal , I cleaned surface well but want to put seal in properly without destroying it. I see it goes over a raised edge and centers around it . I was thinking of a deepwell socket near outer diameter of seal but the seal looks like the middle would seat on the ring also at same time.. is there a special tool needed ?
  2. Salopeck James
    United states
    Backside of old seal, you can see it self centers around input shaft
