gonna buy axle stands 4 weight of 1575kg - this ok?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Robert William Aston, Jan 25, 2023.
  1. Robert William Aston
    26
    new zealand
    1575kg is good prius c weight isn't it?
  2. Sonic_TH
    Sonic_TH Active Member
    574
    96
    Puerto Rico
    2016 Prius c
    You mean to carry in the trunk? if you plan to put that in the trunk, that is way too much.
  3. Robert William Aston
    26
    new zealand
    haha...in garage
  4. CR94
    CR94 Senior Member
    2,740
    1,198
    Northwestern S.C.
    What specifically are you wanting to do?
    The total mass of an empty C is under 1575 kg, if that's relevant
  5. Mendel Leisk
    41,863
    “Axle stands” is another term for “jack stands”. You’re getting four? What’s the issue, load rating?
