Can I spray egr cleaner into the air intake?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Steveurie, Feb 4, 2023.
  1. Steveurie
    Steveurie New Member
    london
    I have rough idle still and it has been suggested that I spray in EGR cleaner, but cannot find the best spot to spray it in. Can I do it at the red arrow on the attached pic, or the green arrow?
    thanks
    Steve
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    733
    287
    Maine
    My mechanic wants to inject 'Seafoam' into a vacuum connection on the intake manifold. Apparently, this is common practice for cleaning other vehicle manifolds.
  3. Mendel Leisk
    38,956
    What's the "EGR cleaner"?
    I would get going on what's described in the first two links in my signature. Basically take off the intake manifold (and throttle body), andd the EGR components. Clean all.
    Again, is this London, Ontario, or The City? I think someone else was saying there's a London in the States as well.
  4. ChapmanF
    16,002
    Have you actually found "EGR cleaner" to spray in? That's not a thing I've seen on the shelf.
    If you had some, I guess you could spray it in the intake if you wanted, but I'm pretty sure by the time it reached any of the EGR components, it would have been turned into ... exhaust.
    Mendel Leisk and jerrymildred like this.
  5. CR94
    CR94 Senior Member
    2,642
    1,140
    Northwestern S.C.
    ??? There are several of those (and Parises, too).
  6. Steveurie
    london
    London England.....egr cleaner is in pic.
  7. Mendel Leisk
    38,956
    As @ChapmanF said, spraying that in the intake isn't going to do anything, for the EGR components. It's gonna go through the air passages in the intake, then onto the combustion chamber, where it will combust. It will maybe clean the throttle body a bit.
    jerrymildred likes this.
  8. ChapmanF
    16,002
    I guess if it really says "EGR cleaner" on the tin, the maker must think there's some reason to believe it'll survive that.
    Color me surprised....
    Grit likes this.
  9. Mendel Leisk
    38,956
    Maybe for cleaning accessible or removed EGR components.
  10. Grit
    Grit Senior Member
    6,160
    4,064
    Wilkes Land
    Let the og poster have his/her moment to spray the product in!!!
  11. MikeDee
    MikeDee Senior Member
    1,552
    590
    San Francisco Bay Area
  12. mr_guy_mann
    mr_guy_mann Senior Member
    3,592
    1,651
    NJ-USA
    Since the EGR valve on a petrol engine is closed under all non-load conditions, I wonder how the cleaner would reach it. (the instructions for the Valvoline product is to spray it into the engine at 2000rpm)
    It might help clean things when the system is disassembled.
  13. Mendel Leisk
    38,956
    First time around filled the cooler with brake cleaner, and let it soak. It got a bit out, but really not that effective. It took multiple hour soaks in a (somewhat caustic) concentrated Oxi-Clean Versatile Stain Remover to do the job. Spraying that EGR cleaner, which I'd suspect is somewhat like brake cleaner, or throttle body cleaner, into the intake? Wouldn't do a thing.
    Foxglove likes this.
