Dealer wants to clean fan, "trans axle service," $611 total
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by carlbarry, Feb 8, 2023.
  1. carlbarry
    carlbarry Member
    63
    26
    Nassau County
    I brought in my 2012 Gen 3 Prius due to it not working because of an IPM failure after 28,000 miles.
    When it was ready, I was told that I don't bring it in to them for service, but it needs "hybrid maintenance" that only they can do. Which is:
    1. Hybrid fan cleaning service $339.95
    2. Trans axle service $269.95
    Over the phone, he told me the filter for the fan cooling the HV battery should be cleaned. From my research, it looks like the filter is near the fan, and requires quite a bit of work to get to.
    The "trans axle service" is I assume changing the transmission fluid.
    Do any experts have an opinion as to if any of this is necessary at this point? It's really a design error to not have that filter easily accessible.
    Thanks.
    52,292
    Too much!
    28,000?
    You need to follow the maintenance schedule that came with the car.
    10 years, a lot needs to be done, though tranny fluid is not on there , it’s a good idea.
    Battery fan does not need to be cleaned and the filter is on the side of the rear passenger seat, you can look at it yourself
  3. bisco
    52,292
    Find another dealer or private mechanic.
    $150. For tranny and $100. To clean the fan if you choose.
    Fan is only an issue if you carry shedding pets
  4. carlbarry
    carlbarry Member
    63
    26
    Nassau County
    I did some research on the filter by the rear passenger seat. A couple of places said I just need to slide up that whole assembly. Doesn't seem to slide on my car. Other sites said look through the grill there to see if there is a filter. I did; didn't see a filter. And of course, other sites said there is a filter down by the fan, after much disassembly.
  5. Noahdoge
    Noahdoge Active Member
    219
    148
    Mississippi
    Your 2012 may not have a filter. My 2012 didn’t. This video will answer all your questions.
    mikey_t and bisco like this.
  6. ASRDogman
    ASRDogman Senior Member
    7,765
    3,971
    mikey_t likes this.
  7. carlbarry
    carlbarry Member
    63
    26
    Nassau County
    I actually had come across his video. I can't pull up on that panel. Tomorrow I will try to loosen the bolt, and give it another try. And oh yeah, look through the louvres to see if I can see a filter there.
    Thanks!
  8. carlbarry
    carlbarry Member
    63
    26
    Nassau County
    Thanks. I'm a little leery of adding in an AC filter, which might cut the air flow a bit. In any event, I have no dirt at all around the intake. I have no dogs being transported, and 99% of the time, I am alone in the car. And I don't shed too much, either.
  9. nicoj36
    nicoj36 Active Member
    518
    162
    Just diy
    carlbarry likes this.
  10. CR94
    CR94 Senior Member
    2,737
    1,196
    Northwestern S.C.
    There's no battery-air filter, if it's the same as 2010-11. You can fairly easily improvise a filter to go on or just behind the intake grill at the side of the rear seat.
    The transmission oil is fairly simple to change DIY---not much more laborious than an engine oil change. $270 is at least double what that should cost, even if they're billing $100/hour.
    #10 CR94, Feb 8, 2023
  11. ASRDogman
    7,765
    3,971
    There IS an A/C filter, behind the glove box.
    Just remove the lower glove box, press the tab on the white cover and
    remove it and there is the cabin air filter...
    #11 ASRDogman, Feb 8, 2023
  12. carlbarry
    carlbarry Member
    63
    26
    Nassau County
    I meant putting a snippet of a room window air conditioner filter in the intake for the HV battery fan. I didn't mean the cabin filter.
  13. ASRDogman
    7,765
    3,971
    I put the Toyota filter and an AC filter and have not had any problem.
    I have two dogs, lot's of FUR! It's never overheated, never had any problems.
    Those filters catch the fur and a lot of dust and dirt.
    It pops right off and easy to clean with water. Then clips on...
    mikey_t and carlbarry like this.
  14. Mendel Leisk
    41,828
    $100 for transaxle drain and fill, ditto for fan cleaning.
  15. vvillovv
    vvillovv Senior Member
    4,324
    1,511
    NY
    #15 vvillovv, Feb 10, 2023
  16. carlbarry
    carlbarry Member
    63
    26
    Nassau County
    They would know the same way they would know if the fan needs cleaning, or any of the other things they have told me that needs to be done, but can only be inspected with a big disassembly.
    Last time I brought it in (3 years ago) for an oil change and State inspection, they told me it needed about $3000 in work. One thing they wanted over $100 for was cleaning the little flapper valve in the engine air intake. I did that myself in about 15 minutes, and there was NO dirt on the valve.
    In other words, it's a rip-off; recommend unnecessary work that an uneducated consumer would have no way of knowing whether it's necessary or not. I have a friend whose wife falls for that. She brought in their SUV to the dealer, and they told her she needs the cabin filter replaced for over $100!
    bisco and vvillovv like this.
  17. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Toyota dealers tend not to suggest tranny fluid replacement in their cars as it is claimed to be a "Lifetime" fluid. It is not gong to last the life of your car if you want your tranny to last 300k miles. I do an ATF drain/ refill at 30k miles (to get out the break-in metallic wear particles) and then a second one at 90k miles and every 90k thereafter. This approach was derived by tracking ATF using lab analysis every 60K miles in my 2004 Prius which showed the degradation of Type WS ATF with time/miles.
    JeffD
  18. Mendel Leisk
    41,828
    I did a transaxle fluid drain-and-fill very early, around 15K kms and one year, and it was markedly darker than new fluid. Did a couple more changes, progressively further spaced, and the drained fluid looked increasingly close to new, so I've resolved to forget about it for a long time now.
  19. ASRDogman
    7,765
    3,971
    "Lifetime" in the car business means: Until the warranty expires....
    Then they are off the hook!
  20. vvillovv
    4,324
    1,511
    NY
    I changed the tranny fluid at 36k . It looked like it didn't need changing, but 36k was at least 80% EV, though I wonder if EV % makes any difference in tranny fluid flush, probably not a big deal either way.
    I have 4 more qts of WS and am going to change it again, eventually.
