2023 Prius Reviews
Discussion in 'Gen 5 Prius Main Forum' started by Danny, Dec 14, 2022.
  1. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Exactly. If you believe in your hybrids then make them! They’re not helping if you don’t make them or nobody can get them. Make as many as the gassers you’re making. BTW that includes north of the border as well.
    Tightwad77 and Tideland Prius like this.
    51,912
    and toyota claimed they might break a record for production this year
  3. Trollbait
    12,534
    Hybrids or ICE too?
  4. bisco
    51,912
    everything
  5. davemo
    davemo Junior Member
    29
    Iowa, USA
    I'm always jealous when I see color options in other parts of the world. The which shade of grey would you like? Or for an extra $500 you can get Red. We also have one shade of blue, but given limited supply good luck finding that with the trim and options you want.
    avocadoman1 likes this.
  6. beamsley
    beamsley Member
    66
    100
    2023 Prius Prime
    Premium w/ Solar Cells
    As a Canadian that could get a mustard yellow Prius for the equivalent of roughly $40k USD OTD before markup, count your blessings! Wraps are always an option.
    davemo likes this.
  7. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    462
    Leawood, KS
    I
    Production number don't equal sales numbers.....I hope the make a ton and only sell half. Then supply will finally exceed demand and prices will have the opportunity to drop. We vote with every dollar and I'm not voting with my car dollars for a few years....I like beer too but at $9.00 a can I'll stop drinking it.:cautious:
    avocadoman1 and bisco like this.
  8. dctalk523
    dctalk523 Member
    The OC
  9. David Mk.2
    David Mk.2 Member
    61
    61
    Connecticut
    2023 Prius
  10. Perpetual Waffle
    96
    120
    Wisconsin
    2023 Prius
    XLE AWD-e
    First driving review (second half of video) in a snowy climate that I have found. No mention of handling in snow, but there is mention of MPG, at least. Comments on general handling and road noise as well.
    Kalianyia likes this.
  11. Kalianyia
    Kalianyia Junior Member
    26
    17
    Shows a spare tire! Not quite shows (it's too dark), but he does say there is a spare.
  12. Mendel Leisk
    41,440
    In a Japanese market model. Toyota giveth and taketh away. You can do similar, with your check book.
  13. Perpetual Waffle
    96
    120
    Wisconsin
    2023 Prius
    XLE AWD-e
  14. bisco
    51,912
    i wish he had lifted out the hatch foam
  15. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    Two areas of concern:
    1) From this video, the steering wheel is in the way to see the speedometer and other things in the instrument cluster, and
    2) the new steering wheel controls are hard (impossible?) to use while wearing good winter gloves. I recently rented a car with cruse/etc on the steering wheel, it was very cold, so I wore gloves. But I had to remove my gloves every time I wanted to adjust the cruse control's set and resume. On my Gen 3 Prius, it's on a steering wheel stalk, so very easy to set, cancel, and resume even with thick gloves.
  16. Trollbait
    12,534
    Were the steering wheel controls capacitance buttons(VW did that), or just poor design for gloves?
    An interesting theory from Wayne Gerdes(Cleanmpg) about the display he had after the RZ press event. He suspects the Prius was suppose to get the steering yoke. The RZ has a similar dash display, and the yoke doesn't block it.
  17. bisco
    51,912
    Yoke? And reduce sales even more?
  18. Trollbait
    12,534
    Toyota's yoke is a lot more than a simple steering wheel swap like Tesla did. It is a by-wire system where the car wheels' turning rate progressively increases so the yoke doesn't need to be turned as much as the traditional wheel to go from straight to full turn. The shape also allows the dash display to be position for more comfortable viewing.
    It is an high tech advancement to car steering, and the Prius was once Toyota's tech display case. It once got features that were Lexus only, and the yoke is going to be an option on the RZ.
    2023 Lexus RZ Steer-by-Wire Steering Yoke Review: It's No Yoke
  19. bisco
    51,912
    Nothing like that even close in my 04, that’s just too drastic for the average driver
  20. Hammersmith
    Hammersmith Senior Member
    2,315
    2,341
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    1) Remember that the reviewer's camera is mounted on a harness on his chest(or he's holding it at that level). His eyes were about a foot higher and could easily see the instrument cluster above the steering wheel.
    2) I also prefer cruise control on a stalk, but I understand the problems car makers are facing. Standard cruise only needs four commands: on/off, set, resume, and cancel. A stalk can easily handle that. But when you add the commands that modern adaptive cruise needs, suddenly a car maker is faced with a choice: do you move all controls to a single location somewhere else, or do you split the controls into two locations and leave the basic controls on the stalk? I guess I prefer the second option, but I understand the issue.
    On the other hand, at least the heated steering wheel is standard on all trim levels except base. Perfect world would have cruise control functions added to the voice command system, but I understand how that could have serious issues(unintended commands, security, passenger abuse, etc.).
    *I have to say I'm feeling REALLY stupid right now. I've been driving my 2010 since it was almost new, and I never realized I could adjust the CC set speed incrementally by bumping the stalk up and down until just now(I was just double checking something in the manual for this post and saw it). And that was a feature I envied from other vehicles. Sigh.
    mountaineer and Trollbait like this.
