Refurbished hybrid battery losing charge quickly
Discussion in 'Gen 2 Prius Main Forum' started by Mickcline, Feb 13, 2023.
  1. Mickcline
    Mickcline Junior Member
    Pompano Beach
    My 08 has around 136k and since I’ve moved from Florida to Colorado my battery is acting goofy. My drive to work consists of .6 miles of city and then 28 miles of highway. When I first start driving the battery seems healthy and happy at almost full bars then when I hop on the highway within two miles I’m down to one or two red bars. It will eventually get back up to 4 or 5 green bars but in between I can feel the car struggling. I’ve called the company who put in the refurbished battery for $1300 and they said they can’t do anything until my dash lights up. Which is awesome for me because the highway I drive is I-25 and the speed limit is 75 and these guys are passing me like there’s no tomorrow and there are NO shoulders to pull over. I’m not sure what to do but I know I don’t want to put my life at risk because of this. I honestly thought FL drivers were insane but CO drivers…
    How much time do you think I have left on this battery? I’ve already tried Dr Prius and I guess the battery is too cold because it won’t tell me the life expectancy.
  2. douglasjre
    douglasjre Senior Member
    2,172
    715
    Null, NL
    Alibaba for new pack under $1k. Never do used
    Tim Jones likes this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Don't forget, the car also severely reduces the charge and discharge limits for the battery when it's cold. Normal limits are around 25 kw, but can be reduced to less than 10kw in some circumstances.
    My first thought is that you have something else going on besides at battery problem. It sounds more to me like you have something draining the battery. This could easily be something like blocked airflow, preventing the engine from making sufficient power for highway speed, causing the HV battery to supply extra power until it drains, then the car cuts back and uses the engine power to keep the battery charged.
    If you're losing speed when at highway speeds, yet have no codes, the battery is likely doing it's job, but not getting adequate support from the ICE. Your symptoms are usually indicative of an engine power problem or something causing unusually high drag, causing the battery to drain itself trying to power the car.
    #3 TMR-JWAP, Feb 14, 2023
    strawbrad likes this.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,036
    1,965
    NJ-USA
    +1 to TMR-JWAP
    It sounds like the car is fine when the battery is in the green or blue, but falls on its face at 1-2 bars.
    Unless you drive continuously uphill, then something is wrong with your ICE (engine). Normally the ICE provides "power" to move the car and charge the HV battery. The battery provides momentary additional power to boost accel.
    If the ICE is weak (restricted exhaust or intake, MAF sensor, fuel pump, etc), then more battery is used to keep speed up until it is low SOC, then all you have is a sick ICE to move the car.
    (I drive my 06 for 20 miles at 80+, and 20 miles at 50-60 with lots of hills, each way on my commute- no problems. Battery stays at 6-7 bars most of the time)
  5. Prius blog
    Prius blog New Member
    new york
    well I will take my chances with prolong battery reconditioning system before putting in a recycled battery. I learned that recycled batteries have ratings. everything nowadays has (A, AA, AA+?!)
    I used the OBD app and found weak cells, do not know if you can do that.
    however, Im your grandpa driving. nice an easy never over 63mph easy acceleration and always coasting (and recharging)
    https://prius.blog/
  6. bisco
    51,844
    I’m thinking your engine hasn’t warmed up when you get on the highway, and it’s using some battery assistance, then refilling when it warms up.
    Florida experience is not helpful in a cold environment
  7. Mickcline
    Pompano Beach
    I’m taking it in to Toyota tomorrow and having them diagnose it. I’ll let you guys know what they say. I’m actually hoping it’s just the HV battery and then I can get some use out of my warranty.
  8. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    You're going to pay a diagnostic fee of a couple hundred bucks, but the car has no diagnostic codes triggered?
    Bet they're going to be confused, but they'll be happy to make a few guesses and hand you an estimate for a few K.
    I'll have popcorn in hand. I really do hope they're straight up and actually do a thorough investigation for you.
  9. mr_guy_mann
    4,036
    1,965
    NJ-USA
    If the technician doesn't road test the car the same way as you (ie, highway driving at 75+ at whatever hills and distance you do) then you will likely get a bill for diag time with "no trouble found).
    If it does act up, it will take an "above average" tech to figure out an ICE problem vs HV battery.
  10. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    Hi Doug, Do you have a link or an Alibaba store name for this please? Very, very interesting. Aloha. John
  11. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    462
    Leawood, KS
    I
    Hi. I am familiar with Colorado weather. With a 28 mile commute I'm guessing you drive north..maybe to Castle Rock? The I-25 section North of Woodmen Road past Baptist and up Monument hill is hard on the Prius. WIth the Speed limit of 75 I usually did 80 and stayed in the middle lane. Colorado now has the title of the worst drivers of any state. I used to commute to DIA from the Springs and 15 years ago it was rare to have someone go past me at 100mph. The last 4 years I had 4 or 5 cars do that every trip. Fatalities on that corridor of I-25 to Denver were up 62 percent.
    Be careful. At 80 mph and hills your mpg in the cold will be not the best. My 2008 with the OEM battery would get about 42 mpg round trip the 160 miles from COS to DEN. Gas wise avoid Monument If you can. There were chip card readers and I had my credit card info stolen twice. I never used Springs Hybrids but they might be a better option then Larry MIller Toyota on E Woodmen road. If you go there our service advisor was Gary. Very helpful guy. Maybe ask for him and your service will be even better. The service I had done on our Prius there was fine. OIl changes took up to 90 minutes so I started doing my own to save money. The cold dry temps in COS can be very harsh on the battery and it will show a weak battery very quickly. It sounds like your refurb might be having trouble. I would park the car in a garage..heated if possible and try to warm it up before you drive. Outdoor parking in the winter in CO is HARSH to say the least. When you drive home from work try setting cruise at 75 and stay in the right lane coming down monument hill. IIRC by the time I got to Woodmen road (or maybe Baptist Rd.) I would have full blue bars and maybe a green in the summer. Oh. Also twice a year I would drive up to woodland park on 24 HWY WEST and to the same thing on the descent. I would get full green bars for sure on that. Like a poor mans full battery charge and discharge. Make sure your hybrid fan is clean,ICE air filter is clean. COS is DUSTY. I replaced our air filters every 6 months just to help out the engine. A warm car is for sure needed to run better Dr. Pruis tests. Good luck and keep us posted.
  12. rjparker
    10,089
    6,258
    Significant mountain pass climbs have the potential of using up battery power without any opportunity for regen. I-25 should not fall into that category. Normal hv battery charge at highway speeds, even with occasional climbs followed by descents, will keep the battery over 3/4 all the time.
    Sitting in city traffic jams for ten minutes or more while using ac is the only time I have seen a good battery in a low state of charge. Toyota's charging algorithm only partially charges the battery under these conditions. Even then you get normal acceleration without hesitation or abnormal engine sounds.
    Almost all engine related issues will code and become obvious with misfires or poor performance even on level roads. Odds are good your refurb is weak but they go a long time before they code. Fast discharge is the number one weak hv battery symptom. Normal performance when you do manage a charge pretty much excludes the engine.
  13. Mickcline
    Pompano Beach
    i actually am driving to castle rock! And I live in glen eagle. Good to know about the credit card thing. I was going to take it in but with the snowstorm we’re having I’m just going to stay tucked in today. I called and made an appointment with the Toyota on woodmen and my service advisor is actually someone named Gary. If it’s the same guy, that’s crazy. I made the appointment before I checked this post lol. I’m going in Saturday to see if they can see what’s wrong because I know this car well and it’s never done this before. I know I’ve moved to a very uh mountainess(?) terrain but this doesn’t seem normal. Maybe it’s connected to the 12v? But I just replaced it with an OEM one not even a month ago. Hopefully I can get it figured out because I’ve put a lot into this car and I don’t want to lose it. I’ve also weirdly grown attached to it even though it drives me crazy sometimes.
    ColoradoCrow likes this.
  14. ColoradoCrow
    1,108
    462
    Leawood, KS
    I
    Sounds Like a good plan. There is a Villiage inn and Sonic close to the dealership for food if your wait is longer. When we bought our 08 Prii. (we have 2) the 12 volt battery in both died the first Colorado Winter. Went with the larger of the 2 options with SKS with batteries from O'reilly's. About $200 IIRC. They have been solid ever since. Now going on 3 years. Through 3 winters..zero issues. If your battery was OEM I doubt it is bad. But they can check it out. If you park outside and know there is a snow storm coming. Lift your wiper blades off the windshield and park them in the air. Easier to remove the snow. We ran Bridgestone Ecopia 422 Plus 185/65 R15 tires and never had a problem even driving them to Summit county. (Breckenridge,Keystone,Frisco...etc.) so that is a good tire choice. I hear you on the love. Our Prii are only about 126K,paid off, and we commute wayyy less now so we won't be buying anything for at least 2 years. I don't even think we will hit 175K before then. Be safe on I-25. And remember comp insurance covers a new windshield for about $23 per year. And now that you live in CO you will need to buy a new one every 2 years...rock chips are everywhere. You can drive with cracked glass but after you get 100's of chips your starburst windshield when the sun hits it just right will drive you crazy.
    Mickcline likes this.
  15. Mickcline
    Pompano Beach
    Alright guys, so I took it in and they weren’t able to find anything. The hybrid tech told me it’s just an older car and he tested the HV battery. He gave me a sheet so I can post it if you guys want to see the reading. Gary didn’t make me pay for the appointment so that was cool. But it happened again this morning. Also, my MPG is showing 51.4 but I’ve already lost a blip just coming into work so I’m not sure what’s wrong. The tech said to just drive it -_-
  16. rjparker
    10,089
    6,258
    This is the smoking gun. When a hybrid battery charge is too low you will lose power. I have seen this in the past. Normally the system does not let this happen with a healthy battery.
    Here is an easy test that just uses observation. As you are seeing low hv battery charge and resulting loss of speed on I-25, look for other Toyota hybrids blowing by you. They have a good hv battery. New cells gives you 8-10 years of reliable service. Used cells, reconditioned, refurbished or repainted are not reliable. Even with a "guarantee".
  17. ColoradoCrow
    1,108
    462
    Leawood, KS
    I
    Hi. Good news. Gary is awesome. Welcome to cold dry Colorado. Lol. It sounds like your older car is just showing the aches and pains like ours did. By the way the gas tank will show signs of “shrinkage” in the cold (insert Seinfeld joke here) this is normal. You gas gauge digital blocks are a very loose guideline in the Colorado Cold. You will find yourself on empty with 1 block flashing and when you fill up you will only be able to put 8.5 gallons in. Both our Prius did this in Colorado. In the summer we could get 9 maybe 9.2 gallons on a really hot day. All very normal. The plastic bladder is just less flexible in that environment. Now that we live in Kansas where we have hot humid weather both our batteries are in the green and blue all the time now. Gone are the days of 2 purple bars on the MFD. …. Until we drive back to CO…lol took a ski trip in December and it all switched back. Drove home and back to never seeing 2 purple bars..ever. So it’s normal. By driving that far on I-25 you will keep the Cat clean by getting the car up to temperature. Optimal for long car life. when you can visit Bella Panini in Monument for a great dinner with your significant other. Try the Vegetarian lasagna. My wife and I love meat but THAT dish is the best we have ever had.
  18. ColoradoCrow
    1,108
    462
    Leawood, KS
    I
    Also keep in mind that there is 16%less oxygen in the air where you drive now in Colorado. The car’s intake will be affected just like your lungs. Just keep your air filters new and clean to help out the engine as much as you can.
  19. Ernie stires
    Ernie stires Member
    107
    30
    Colorado
    I too live in Colorado, Denver actually, and have a similar experience. A couple of things, we are at 5000 feet and while the computer dies adjust for the lack of air, there is still less air, less power. We also enjoy winter gas here which is high in Ethanol which has less energy than pure gasoline. I drive the i25 strip myself and understand the hazards and I’ve found that entering the freeway from the in ramp can seriously drain my HV unless I carefully feather the gas pedal. The difference is very noticeable. At 65-75 mph speeds my Prius will hold the charge, maybe 4-5 bars, but i cannot floor it to go faster or pass, I literally have zero torque! I use Dr Prius who tells me my battery is fine so I rely on adjusting my driving habits. And yes, monument hill, going north, is a bear!
    douglasjre likes this.
  20. douglasjre
    2,172
    715
    Null, NL
    I love what Prius does for me but if I lived at that altitude I'd get a turbocharged AWD car
