more EV range with double charging ?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by jacktheripper, Feb 10, 2023.
  1. jacktheripper
    jacktheripper Active Member
    229
    466
    Hello everyone,
    This is Jack from the Dr. Prius App. As many of you are aware, we are currently testing a new lithium pack with increased capacity and EV range for plug-ins. However, we've encountered a charging issue that we would like your assistance with.
    The situation is this: when charging the plug-in overnight, the state of charge (SOC) reaches around 75%, which provides roughly 16 to 19 miles of EV driving. But, if after the initial charging we unplug and then plug the charger back in, the car continues to charge to 85% SOC, resulting in 25 miles of EV driving. We've tried this in different conditions, such as charging in hot temperatures and during the day, and the results are consistent. It appears as though Toyota has a built-in mechanism that stops the first charging at 75% and then allows for additional charging if needed.
    Could someone try this double charging on a stock plug-in and let us know if this is the case? Your help would be greatly appreciated.
    thread for the lithium upgrade pack for plug-in:
    https://priuschat.com/threads/project-lithium-prototype-doubles-ev-range-of-plugin-prius.238536
    CC: @PriusG909
    Best regards,
    Jack.
    Isaac Zachary, Kot21 and nicoj36 like this.
    48,947
    I’ve already done it, it won’t accept a charge, the light comes on for a few seconds and goes out. The evse never actuates
    jacktheripper likes this.
  3. jacktheripper
    229
    466
    Thanks @bisco ! do you happen to know the SOC % when fully charge?
  4. bisco
    48,947
    unfortunately, i don't have any equipment to measure things except a simple volt meter. i have never hooked up an obd, and have no idea what the battery charge has been over the years.
  5. jacktheripper
    229
    466
    ok no problem, thanks for letting me know!
  6. vvillovv
    vvillovv Senior Member
    3,529
    1,242
    NY
    scangauge said SOC was 84 or 86% when the PiP was fully charged (from memory) I have a picture somewhere.
    jacktheripper, bisco and PriusG909 like this.
  7. PriusPiP
    PriusPiP New Member
    Europe
    Hello everyone
    On our 2012 model the charge varies a bit. Currently it is in our garage around 7°C and our Prius charges to around 80%. I've noticed that during the summer SOC went up to 85%. If i have more than on charge a day i currently stay around 83%. I believe that this is based on the battery temperature. Also if we start to go downhill, the battery will not rarely charge over 83%.
    I've also noticed that the car starts an charging pattern once it reaches a certain level ov charge, were it reduces the charge and (I assume) starts balancing the batteries. I think (haven't tested) that this i based on SOC and time.
    I also could image that Toyota implemented an safety feature, which shuts off the charging after a certain time. Maybe if you start charging around 50% the car would go back to 80%.
    Kind regards
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,782
    2017 Prius c
    Real professional battery engineers know that changing the type of battery usually also requires changing the charger too.......to get the best charging performance.
    In this case, I think you are lucky that it will continue to charge the second time.
    If the characteristics of the Li battery were a little different, it might not.
  9. vvillovv
    3,529
    1,242
    NY
    Does anyone have the voltage after a full charge in the PiP?
    The Prime full charge voltage is 374 to 375 volts (depending on how long after charging stops, and voltage is read). 0% ev SOC is 330 volts - with about a 5 volt buffer (meaning 325 volts can be seen at times as long as the voltage rebound after load is removed is 330 volts or above).
  10. LeviSmith
    LeviSmith Member
    108
    NY
    Just checked my 12 PIP after plugging in to my L2 evse Friday on timer to charge at midnight Sat morning. Sunday morning now and it says 84.72% 220v. Unplugged and plugged in again and EVSE says it's connected but no power going.
  11. jacktheripper
    229
    466
    Bingo!! it is a safety feature, we tried start charging at 50%, and next morning it charge all the way up to 85% straight.
    I believe the safety feature could be input power limited, will continue to dig.
    Thanks so much for the helpful input !!! you guys rock!!
  12. Isaac Zachary
    Isaac Zachary Senior Member
    1,729
    834
    Data Daedalus and PriusG909 like this.
  13. vvillovv
    3,529
    1,242
    NY
    Does charging stop part way to full SOC when using L1 and L2?
    Does A/C work the same while charging? easy test : sit in PiP while charging on a hot day, Push A/C button on fob.
  14. PriusG909
    PriusG909 Junior Member
    17
    Los Angeles/IE
    Noted
  15. PriusPiP
    PriusPiP New Member
    Europe
    Just out o curosity. Where you able to get around the chargingissue?
    PriusG909 likes this.
  16. PriusG909
    17
    Los Angeles/IE
    Hi! We are testing a new charging procedure tonight. I will update once results are in!
    PriusPiP and Kot21 like this.
  17. PriusG909
    17
    Los Angeles/IE
    Will update with results
    Kot21 likes this.
  18. PriusG909
    17
    Los Angeles/IE
    Indeed as stated above it’s a safety feature implemented by Toyota. A simple solution is using a cycle timer.
    @jacktheripper
    vvillovv likes this.
