Can I get some thoughts about the 2010 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tom Mayor, Feb 15, 2023.
  1. Tom Mayor
    Tom Mayor Junior Member
    55
    Orlando
    Hi everyone,
    After weeks of research, I have finally found an honest guy that is selling his well loved 2010 Prius with only 147 500 miles on it, great condition and pretty clean based on the pics/videos. he asked $7000 but I have negotiated to $5600. Some random dealerships tried to scam me and the cars in renown dealerships are way too expensive. I can't justify paying $800 of fee for a $7000/$8000 car + taxes etc.
    I have asked the owner what were the maintenance he is done the car since he owns it (8+ years) . He said nothing major other than tires/breaks/oil change and the ABS module (2years ago). The car is located in Orlando, FL and he mostly drove through the city, not too hilly or windy and damaged roads. What can I expect to have to fix soonish that can be costly? He said the hybrid battery was doing really well, but I don't know how to test it. I have heard that the Prius had a lot of water pump or head gasket issues. I don't know a lot about cars. It seems that 2010 is the first year of the 3rd generation and since that, maybe I can go through more important issues than on the later models of the same gen. Overall, I have also heard only great things about those Prius, quite surprised to see that some owners still run theirs with 400 or 500 000 miles without any major and expensive repairs, is it just luck or common ? There is a lot of electronic in those cars and people always mention that there is nothing that went bad with them . What costly/annoying repairs did you have to make on your 2010/2011/2012 prius and at what mileage... Thanks for the help!
  2. Tombukt2
    13,116
    2,354
    I have a 2010 and the reason I believe it's still on the road is because it's almost never off of the road my ex drives this car for Uber eats and all of those silly things and it's an early 2010 with solar roof and JBL The prior owner kept the car on the road all the time as a young college student and then in some kind of sales job real estate who knows then the car went to a small car dealership where it did not sit but a day or two and I came along and bought it for my ex she immediately put it on the road full time It's never had time to sleep since I bought the car for her I believe this has a big presence of why it's still on the road now I have a 2013 persona I bought a year later that car blew a head gasket needed an engine in 24,000 miles It was just luck of the draw It's a Gen 3 issue I put a motor in that persona and we're heading to 50,000 mi on that motor and it's only been in there 7 months or something like that The persona is not driven like the 2010 at all we'll see how the JDM spec engine holds up in the persona which is driven like most people here regular go to town come back go to work come back. The 2013 is driven nothing like the 2010 I believe the 2010 is still on the road because it's hardly ever off the road I truly believe that the Prius needs to be three sheets in the wind as much as possible always being driven The minute it sits things start to happen immediately It seems like. It is one of the perfect cases for use it or lose it so if you're buying a Prius to sit in the driveway and drive 6/10 of a mile to work and back and rarely do much else truly do yourself a favor buy a Corolla or a Yaris seriously.
    Foxglove likes this.
  3. Leadfoot J. McCoalroller
    8,112
    7,591
    Pennsylvania
    2018 Prius c
    The hybrid batteries are nearly guaranteed to fail somewhere between year 15 and year 20.
    That 1.8L engine is known for elevated oil consumption.
    There can be expensive problems with the brake booster and master cylinder.
    The EGR system can clog up, and there's a theory circulating that a clogged EGR system can lead to a blown head gasket. This theory makes some sense to me, but none of us have the resources to prove it one way or the other. Toyota just ignores it altogether, since it occurs long past any warranty coverage.
    None of these problems are easy to detect pre-purchase. They don't happen to every single car- you could get away totally clean. But some cars will hit all of these problems, and the total for fixing just these is higher than what you've negotiated for purchase.
    Elevated risk of catalytic converter theft.
    When a Prius is running well it is an amazing car. When they aren't going well they are legendary money pits. You can spend a fortune trying to save a little gas.
    The gamble we all take with a Prius is that we are driving enough miles to save enough fuel to pay for eventual repairs on the more exotic hybrid powertrain. When you are driving many miles per year and you start with a fresh new Prius, this is a good gamble. Those repairs won't be needed for a long time.
    If you start with a 13+ year old car, you are much closer to that risk- you'll have to do the math to work out if your driving demands are high enough to justify the bet.
    Welcome and good luck!
    CR94, Foxglove and Mendel Leisk like this.
  4. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    The ideal person to buy an old Prius is someone who is handy enough and has tools, space and time to do maintenance and some repairs. If, for example he hasn't had spark plugs and coolant changed, it is time to do it. You can do it yourself for almost nothing or pay to have it done. I agree with Leadfoot's comments about EGR. The EGR circuit can be cleaned when replacing plugs. There are plenty of videos to help. A old Prius can serve you well and be fun to own for a long time if you continue to maintain it.
    So, can you do that? If not, get an estimate on how much it would cost.
    There is a very experienced and respected independent hybrid dealer in Tampa. If I were you I would have them do an inspection.
    tampahybrids.com
  5. Mendel Leisk
    41,642
    The logic there is that the wipers and windshield cowl need to come off for plug replacement, and the maintenance interval for plugs is 12 years or 120k miles, whichever comes first.
    my 2 cents: if you leave the EGR to 120k miles, that just may be too late. Taking off wipers and cowl is a pain, but head gasket failure is a disaster.
    Maybe do the EGR every 60k (double up on spark plug miles interval), and do it well, including intake.
    He “may” just be starting to experience the cold-start shakes, got some bad news.
    Ask to take a test-drive starting with a stone-cold engine, early morning.
    #5 Mendel Leisk, Feb 16, 2023
  6. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    Well. A new head gasket job at Tampa Hybrids is well worth it for $2,600. If you are willing to spend $5600 on the car and don't have $3,000 to spend on the repairs. I would pass. Or. Look up Tampa Hybrids online. They sell Prius THAT HAVE ALREADY HAS THE HEAD GASKETS repaired and offer a warranty. I would look at there website for cars for sale as well. The 2010-2011 IIRC is the worse offenders and can be a money Pit. Ask to see repair paperwork. See what they did. Was the PO diligent on oil, air filters? Was it garage kept? Why is he selling? If you don't need the space and you don't commute very far I would look at a Corolla. I had 3 Corollas and only went to a Prius when we had a family and needed more space...Starting to outgrow that now.
  7. Tom Mayor
    55
    Orlando
    Hi thanks! Alright so the hybrid battery can last a very good time.
    I have changed egr valve in all of my previous cars. It cost $20 to $100 for the part and it's often easily accessible. I am sure I'll get a message on the dash if it's too dirty and be able to swipe it for a new one before it impacts the other elements.
    Regarding the 1.8L engine. I used to drive a 8.1L vortec engine v8 that burns +/- a quarter of oil every 1000 ish miles. I think the 1.8L will be fine and if I have to top off 1 quart between oil change i would be OK lol.
    I have heard about the catalyst converter through memes. It's crazy right!
    The 2010-2011 IIRC what does, "IIRC" means?
    The guy sold his car for financial reasons. He used to drive it through Orlando for personal and as a Lyft driver. The breaks and tires are basically brand new.
  8. Tom Mayor
    55
    Orlando
    Thanks!
    I had to change the egr valve in all of my vehicle. It cost around $50 for the part and I have swiped all of them in 10/15 minutes. It's usually pretty accessible. I'm pretty sure that if I get a message on the dash regarding a dirty egr valve it won't have time to have impacted the head gasket or anything....
    Thank you!
    What, means 2010 2011 IIRC
    Thanks! I have changed all the egr valve of my precious vehicle and the part cost $20 to $100 depending which one. And it always took me 10 to 15 minutes to swipe it. I assume that if there was an issue with the egr valve he would have gotten a message on the dash and changed it. Especially since 27 000 + miles. No?
    I drove the car this morning after 18 hours resting, well it's in Florida so it was about 70 degrees but the car didn't make any noise or I didn't feel any odd sensation.
    #8 Tom Mayor, Feb 16, 2023
  9. ColoradoCrow
    1,108
    464
    Leawood, KS
    I
    IIRC. means....If I Recall Correctly. :). I would run a Dr. Prius APP at a minimum , and if you are really serious about this car. Pay a Mechanic to look it over and get a in depth Professional opinion. Dare I say pay the toyota dealership $150 to give you a report on it. I think that a 2010 is worth $150 if I was serious about buying it. I would gladly pay that for a professional opinion. However If you don't have $2,000 to invest in repairs for the first year....it is a big gamble in my book. Cheap Cars....are....usually cheap for a reason.
  10. Mendel Leisk
    41,642
    3rd gen Prius EGR access and cleaning is more involved. See first couple of links in my signature.
  11. bisco
    52,093
    2010 with 150k is a ticking time bomb
    m.wynn and Mendel Leisk like this.
  12. Tom Mayor
    55
    Orlando
    Really...? I have seen some listing for 2010 with 250 or 300 K miles on it.
  13. Leadfoot J. McCoalroller
    8,112
    7,591
    Pennsylvania
    2018 Prius c
    Past performance is no indication of future results.
    You're seeing the ones that were used heavily while they were fresh. A young Prius can absorb miles like nobody's business. The first 10 years of any Prius' life is pretty magical- low usage costs and ultra-low maintenance costs.
    Once you get past that period things start getting more random and expensive. Not all at once, of course. Every car is different, and years of use further individualizes each one.
    The point is that the ultra-reliability that everyone talks about is something that happens in that first 10 years and then fades after. That's not what you're getting when you buy a 13-year old Prius.
    Don't make the mistake of thinking you are buying into that legendary reliability unless you get one new enough to actually deliver it.
  14. Tom Mayor
    55
    Orlando
    Right on. So you think that the prius are incredible car if there are less than 10 years old? I have heard that the 2009 model was super great no matter the mileage it had. Is that true?
  15. Leadfoot J. McCoalroller
    8,112
    7,591
    Pennsylvania
    2018 Prius c
    That was true. But time has moved on, and it isn't necessarily true anymore. That's what I'm getting at here: you can go broke chasing yesteryears' ghosts. Old cars are expensive to keep up with- especially high tech ones like hybrids.
    A 2010 like the one you found obviously isn't dead. It'll probably be okay for another couple of years before something really expensive happens. But is that really long enough?
    The same money on a simple car like a Yaris, Accent, Corolla, Fit, Spark etc would get you a car that could age more gracefully. Much cheaper repairs. If you aren't going to drive much, the difference in fuel savings is negligible.
    Montgomery likes this.
  16. Tom Mayor
    55
    Orlando
    We are on a website DEDICATED to prius and you are the 10th person that told me to buy another Toyota model I don't understand why there is guys on that forum if there aren't too prius totally.... Have you ever owner a prius?
  17. Tom Mayor
    55
    Orlando
    BTW an egr valve issue or head gasket can happens to any car... I would even say that if the head gasket issues is present on the prius 3rd gen it might be the same for some othera toyota model from the same years.
  18. brzy25
    brzy25 Junior Member
    40
    30
    My 2012 had the inverter failure at 100k July 2022 and the abs booster pump failure at 120k December 2022. Thankfully both were still covered by enhanced warranty programs, the booster pump barely because my car didn't get first registered until July 2013. Those would have been $3,500 for the inverter and likely a $3k repair. Older Prius's are terrifying potential money pits. Mine I bought in 2021 for $14k with 75k miles with documented 5k oil changes so other than those 2 potentially catastrophic repairs it's been fine. I likely will need a battery in a year or 2 but decided to wait till it pops a code. Something else may go before then and it still gets 48mpg on the way to work.
  19. nicoj36
    nicoj36 Active Member
    518
    162
    Clean egr, intake manifold, throttle body, maf sensor, replace all fluids.
  20. Leadfoot J. McCoalroller
    8,112
    7,591
    Pennsylvania
    2018 Prius c
    I don't understand the first part of your question, but for the second part: yes, we bought a new 2018 Prius c. It's now coming up on 5 years old, just shy of 70k miles. It's been fantastic. We love the car.
    If you want to have a fantastic, carefree, low maintenance experience with a Prius, try a 5 year old like mine.
    Would our answers be less surprising if the website had been called oldprius.com?
    #20 Leadfoot J. McCoalroller, Feb 17, 2023
