Vinyl Wrap for Gen 3 White Blizzard Pearl Paint peeling issue
Discussion in 'Gen 3 Prius Main Forum' started by lexibothersme, Feb 19, 2023.
  1. lexibothersme
    lexibothersme Junior Member
    Bay Area, CA
    Here's the TLDR for those not interested in reading:
    I found the following vinyl wrap colors that closely match that of Blizzard White Pearl Toyota color code 070:
    - Avery SW900-109-S (Gloss White Pearl)
    - Orafol 97RA-946 (Gloss Nacre Metallic)
    More detail:
    2010 Prius in Blizzard White Pearl with 174,000 miles. Paint started peeling in Dec. 2022. Minor at first and then got worse. I chose to use vinyl wrap because I can always remove it versus spray painting. It's so hard to get the colors I noted above as they are sold out everywhere (Metro Style, Vinyl Giant, etc...). The Avery is sold out everywhere so I wasn't able to order a sample. I was able to order a 12"x12" sample sheet of the Orafol wrap. It actually is pretty close. See pics. My main intent was to cover up the ugly spot where the paint peeled on my driver's side door and hopefully prevent further peeling.
    What I would like to do is get a 5-feet x 2-feet sheet and cover the entire length of the door (from handle to mirror) so that it blends in more. I used WrapCut vinyl tape to get an even cut. Do a google search for this, I highly recommend it.
    It's not a perfect match, and you can definitely tell I have something there but it's a lot better than the "before" pic with the peeling paint. It's my beater car, so I don't really care too much. I mainly wanted to see if I can prevent it from getting worse.
    If you have a recommendation on a specific vinyl wrap color that is a better match or is more readily in stock, please post your recommendation so others can see.
    ukulelegeek likes this.
  2. PriusCamper
    PriusCamper Senior Member
    12,818
    5,198
    Pacific Northwest, USA
    All wraps require near same preparation as paint... If you put a wrap on top of peeled paint every detail of the peeled paint underneath the paint will be almost as obvious as a coat of clear coat. If I were you I'd use a Plasti-dip spray on / peel-able rubberized paint option as a 4" inch wide white racing stripe down both sides of the car, because it can be sprayed on thick enough to hide the edges of the peeled paint if you're skilled enough to prep it down to super smooth and spray it super thick.
    ukulelegeek and avocadoman1 like this.
  3. Tombukt2
    13,059
    2,340
    I have a friend that does this for a living I wouldn't tackle this for a minute this would be like watching the grass grow or tinting windows or even painting No sir Not for me nor is furniture building and just do time-consuming lengthy yeah but good on you I would have left the paint feeling on the 2010 yeah I don't generally do painting and a lot of that cosmetic stuff unless the car is really some kind of worth it. I keep a vehicle three sheets in the wind paint should be peeling off unless it was painted by an airplane company.
  4. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    Or you can get it repainted for free with the Toyota ZKG customer support program for blizzard pearl or super white paint.
  5. lexibothersme
    Bay Area, CA
    I thought the ZKG program didn't apply to Priuses? Has anyone successfully gotten Toyota to paint their Prius using the program? Thanks in advance.
  6. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    My vin is printed on the perforation tear off to provide Toyota dealerships proof of eligibility. But ignore this info, I want to see a vinyl wrapped Prius!
  7. Todd Bonzalez
    Todd Bonzalez Active Member
    250
    160
    Ireland
    Please don't take this the wrong way but given the condition and age of the door, I'd just sand that area down and hit it with a rattle-can paint job
  8. Mendel Leisk
    41,548
    It's been posted here that Toyota's now covering Prius. Check with dealership.
    I still wonder, just how much can/will they do. It'd take a complete assesment of current and potential flaking zones, and is that even possible. I'd suspect they'd deal with what's currently flaking, do a partial paint job, and the flaking may continue, down the road. In short, it's a mess. And you had to pay extra for Blizzard Pearl. :mad:
  9. lexibothersme
    Bay Area, CA
    Thanks Mendel, that's good to know. Coincidentally, I checked my mailbox today and actually did get a letter from Toyota with my VIN stating that my 2010 Prius is covered by this Customer Support Program. I'm going to give my local Toyota dealer a call tomorrow to see if I can make an appointment.
    Montgomery and Mendel Leisk like this.
  10. lexibothersme
    Bay Area, CA
    I'd much rather get Toyota to repaint my door, obviously. No arguments there. I checked my mailbox and actually got a notification letter from Toyota that my Prius is covered by the ZKG program. Hopefully other Gen 3 owners get notified soon as well.
  11. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    Don’t let the zkg stop your vinyl wrap project. I like to see a chemelion color wrap.
  12. Tombukt2
    13,059
    2,340
    Minceys is right at the corner . The wrap this stuff all day . Gotta Prius right here w a wrap for lawn care and trailer wrapped to match local guy mows grass w prii n trailer
  13. ukulelegeek
    ukulelegeek Active Member
    159
    112
    I haven't gotten that letter. Is it because I'm not the first owner of the car?
  14. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    Mine was purchased second hand and still get the letters nagging to get recalls to git r done. How the wrap project coming along?
  15. tw0leftskis
    tw0leftskis New Member
    Honolulu
    Mine is silver, does the program cover this color?
  16. Theomancer
    Theomancer Junior Member
    New Haven, CT
    12 months later, Amazon is still out of stock on the Avery gloss white, but I was able to find it at a random online retailer using Google Shopping. For anyone in a similar boat to me and looking this up, here's where I found it:
    Avery SW900 Gloss Pearl White 109 Vinyl Wrap - Revolt Vinyl
  17. PriusV17
    PriusV17 Active Member
    335
    167
    CA
    2017 Prius v wagon
  18. PriusCamper
    12,818
    5,198
    So called "experts" make a good portion of their pay by charging more for replacement parts than they paid for them... So if they tell you that they don't install customer purchased parts, that's why. It's fairly standard in the industry.
    And if you're skilled enough to remove a part at a junk yard yard (practiced the job) and you've also done all your homework on Priuschat and Youtube, you don't need to depend on "experts" to install your part, you can do it yourself!
  19. PriusV17
    335
    167
    CA
    2017 Prius v wagon
    Yes if DIY is very capable. But a lot of these install requires two people or else you have alignment issues and then you want to make sure it is very safe for driving.
    PriusCamper likes this.
  20. PriusCamper
    12,818
    5,198
    Doing your homework and having the right skills and tools is key... I can't think of any jobs that take 2 people... Heck, even https://www.instagram.com/skimmilkhybrid/ puts Gen4 engines in a Gen3 Prius in a day in people's driveways in a day all solo. Though I do agree if you lack experience, having a friend or family member with more than you and lots of tools can help speed things up greatly.
