DICE iPod Operating Instructions
Discussion in 'Gen 2 Prius Audio and Electronics' started by Bill Merchant, Dec 3, 2006.
  1. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    I installed the DICE unit without too much difficulty, now I'm trying to decipher DICE's cryptic one-page (6) instructions for operation. I keep having to pull out my iPod and scan for playlists/albums/etc. Also, sometimes I get the disk named "INIT" and it takes a while, and luck, to get the DICE and iPod in sync so I can see what's playing.
    Any wizards figure this out yet, and document it?
  2. SynergyGuy
    SynergyGuy New Member
    55
    Hi Bill,
    Could you tell me how did you install this unit or where did you find instructions on how to do it? I just got mine but have not found instructions whatsoever on how to install it in the car.
    Thanks!
  3. Alnilam
    Alnilam The One in the Middle
    760
    Carlsbad, CA
    <div class='quotetop'>QUOTE(Bill Merchant @ Dec 2 2006, 11:24 PM) [snapback]356890[/snapback]</div>
    I started a thread on this a week or two ago that went nowhere. The DICE unit is buggy. It'll usually play music but I have no idea what song it is going to start with or play next. Several people have notified Dennison, including myself, and we've all gotten simplistic answers that ignore the problem and suggest dumb fixes that go no place. Maybe in the future it might get upgraded to where it works, but right now I find it next to useless. Turning the whole radio off and on again usually gets it to play something. The playlist folder list has never shown me a thing. All Dennison said was that maybe I needed to swap it for another. I'll wait until I hear somebody has one that works before I start that game.
  4. bravoballer
    bravoballer New Member
    san diego, ca
    <div class='quotetop'>QUOTE(Alnilam @ Dec 3 2006, 08:17 PM) [snapback]357165[/snapback]</div>
    Is there supposed to be a list of folders? Mine works (after turning the radio on/off three times) and most of the bug issues I'm willing to blame on my IPOD because we all know those things have weird "habits."
    Once it is up and running the disc "1" button advances tracks in your current playlist when you use the steering wheel or the "track" button on the head unit.
    Disc 2 switches between playlists (I assume playlist 1 is your entire library) and the other playlists follow aphabetically.
    Disc 3 switches to the next album in said playlist. Not as good as I had hoped, but it seems to work on my 2005 after a few reboots. Also, I was disappointed to find out the "UR" mode claimed on the Priuschat webstore was not true.
  5. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(SynergyGuy @ Dec 3 2006, 07:38 AM) [snapback]356950[/snapback]</div>
    Use the instructions for the Vais AIC-100i at http://priuschat.com/index.php?act=Attach&...ost&id=5767
    The installation is the same.
    <div class='quotetop'>QUOTE(bravoballer @ Dec 3 2006, 08:09 PM) [snapback]357208[/snapback]</div>
    For me, I never get my entire library, unless I set it to shuffle on the iPod itself. If I used the iPod during the day it starts in the first song on the last playlist I was on, otherwise it starts on the first song of the first playlist.
  6. Bill Merchant
    4,096
    87
    Hi SynergyGuy. I've been looking for the pics I used that helped me, and will post the link when I find them. I used LurkAzusa's general method. The VAIS install instructions mentioned in frequent posts found with a search on "DICE Install" are helpful, but I found some great pics, which I can't find now.
    First, I wanted to install the setup so I could have the iPod in the drawer in the console so it wouldn't be visible. Here are the steps I took:
    I pulled off the plastic shroud below the radio/mfd console. I disconnected the 12V outlet to make it easier and to get the shroud out of the way while I worked.
    I removed the lower glove box.
    I pulled off the vent on the passenger side of the radio/mfd.
    I clipped the cable tie holding the wire harness to the white plastic plug assembly behind where the vent was.
    Using a 10mm socket (a #2 Phillips screwdriver should work too) I removed the screw holding the white plastic plug assembly. It's at the top, just under the vent tube, and a little hard to see easily.
    I wrestled the white plastic plug assembly free and maneuvered it out of where the lower glove box was, to get it clearly out of the way.
    At this point you can stick your head in where the lower glove box was and look over at the radio (flashlight helps) and see where some wires in a plug are plugged in near the edge nearest you. If you feel on the far side of this plug, you can feel an empty socket; this is where the Y cable male plug goes, latching clip up. I found it convenient to connect the intermediate cable that goes between the DICE unit and the Y cable first, so I wouldn't have to try to get a good solid connectinon while reaching under the dash. It took a little time and effort to get the Y plug in, and make sure it was tight. The first time I got it in, I gave a gentle tug on the wires and the plug pulled out. Push hard and make sure this is a tight connection.
    With the cable connected to the radio, I turned my attention to the other end of the line.
    Grab the cup holders and pull straight up, they pop out.
    Two silver screws at the bottom front of the central console (visible without the cup holder) and two 10mm screws under the little carpet in the bottom of the console box hold the console down. Remove the screws and you can rotate the console up and back between the two front seats. The wire for the 12V outlet in the console prevents complete removal, but you don't need to.
    Now you can figure out how to fish the iPod connector cable (and AUX extension cable, purchased separately, if you are so inclined) from the console area under the carpet to the area under the radio. It's easier to go this way since the mini-DIN (and male end of the AUX extension cable) are easier to pull than the square iPod end.
    Once you have all the cables in the right place, you can put the DICE unit in the middle and connect everything. Things only fit one way, but now's the time to check. Plug the cable into your iPod and turn your Prius to ACC-on. Turn on your iPod and start something playing. Hit the Audio button for the MFD. Hit the CD button twice to select CD2. You should hear what your iPod is putting out. If not, check all connections and start futzing (technical term).
    Once you have audio playing, turn everything off, it's time to put your car back together. Use cable ties to secure any plugs that might flop and rattle. I used some double-stick foam mounting tape to make sure the DICE unit was secure on the plastic air duct.
    Re-mount the lower shroud, connecting the 12V outlet. Wrestle the white plastic plug assembly back into place and re-install a cable tie if you are scrupulous. Screw it back on and make sure it's secure. Re-install the vent. Re-install the lower glove box drawer.
    On the console side, I removed the black screw on the driver's side of the front of the console, which connects the outer plastic to the black drawer assembly, slid the iPod wire and connector through, fished it around the back end of where the drawer slides, reached inside the drawer, and pulled the iPod connector as far forward as I could.
    Rotate the console back down into it's mounted position, pulling and easing on the iPod cord so as to get as much out of the drawer as possible (not all that much, but you want to be able to plug in the iPod with ease).
    Re-install the 10mm bolts in the bottom, and the silver screws on the front sides, to re-mount the console, Re-install the black screw connecting the outer plastic to the drawer assembly. Pop the cup holders (you did take this opportunity to clean them, right?) back into place and you're done.
    Pull out the drawer, plug in your iPod, and go for a joy ride to celebrate.
    Now, figure out how to use the CD2 disk buttons and the forward/back buttons and write a clear explanation...
  7. SynergyGuy
    55
    Thanks for the detailed instructions Bill, very much appreciated. I'll go ahead and get started now.
  8. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(Bill Merchant @ Dec 3 2006, 11:59 PM) [snapback]357268[/snapback]</div>
    What I've found for my 2005 is...
    D1- Using buttons on steering wheel changes within a playlist
    D2- Using buttons on steering wheel changes playlists (alphabetically)
    D3- Using buttons on steering wheel changes albums (never tried)
    D4- Using buttons on steering wheel changes chapters (never tried)
    D5- Using buttons on steering wheel toggles between AUX and iPod
    D6- Displays DICE information (version)
    The FF & Rewind on the MFD does the same on the iPod. This is handy for me as I have some MP3 audio books and it's nice to back it up or go forward as needed.
    Only when on D1 will you see Artist, Album and Title at the same time when the TITLE button is pressed. On D2 you'll see the word PLAYLIST and the Title; D3 says ALBUM and the Title with D4 saying CHAPTER and the Title.
    You don't see what the playlist (or album or chapter) actually is, just the word.
  9. CHART
    CHART Member
    184
    Mount Airy Maryland, USA
    To throw my 2 cents in here....I just installed my DICE in my 2004 Prius today and noticed:
    1. Playlist 1 is all of my songs on my Ipod in alpha order by album name
    2. Album only moves you to the next album "within a playlist" To test this, add several albums to a playlist, go to D3 and hit the next disk button on the steering wheel. The playlist will skip the rest of the songs on that playlist until it hits a change in album name.
    3. dip switch 2 doesn't seem to make any difference to me. I get text in either position. All other combos show INIT
    4. Sometimes the album name doesn't change from the old album on the 1st line where D1 shows "Artist * Album." I played until I realized that happened repeatably when the artist or album field on the "new" song is too long, it just keeps the old album name....
    So far, I like it. I wish it could actually go from album to album outside of a play list but other than that, I like it. I guess I will play with it for a few days until it starts acting weird like everyone elses!
  10. xraynano
    xraynano New Member
    56
    Chicagoland
    <div class='quotetop'>QUOTE(aaf709 @ Dec 4 2006, 12:27 PM) [snapback]357459[/snapback]</div>
    Yes, that is pretty much what it should do. But it doesn't do that on 2006 and 2007. In some cases, it will execute the action, but won't display the result (for example, on D2 you see the word PLAYLIST but not the Title, or maybe you see nothing. Once there is nothing shown, any further operations may not display anything either until the power is cycled for the audio unit.) Of course, even if it does what it is supposed to do, that is not ideal. You would like to know what album or playlist you are in as you change through them. I suggest it should say PLAYLIST - "playlist name" or ALBUM - "album name", even if abbreviated. That would be far more useful.
    In any case, the vendor is aware that this does not work properly for the 2006 or 2007, and believe it will require an update to the programming, and ultimately a swapout of the unit. They have swapped units for some of us seeing degradation of performance over time, believing the units are not only improperly programmed but also failing. In some cases, this has improved performance for 2006. I just received a replacement (with old programming) and will test it out this week.
  11. Bill Merchant
    4,096
    87
    Thanks, aaf709, that's exactly what I was looking for!
  12. aaf709
    3,862
    2022 Prius Prime
    One thing I forgot is when the DICE is in AUX mode:
    D1- Using buttons on steering wheel changes VOLUME
    D2- Using buttons on steering wheel changes BASS
    D3- Using buttons on steering wheel changes MID
    D4- Using buttons on steering wheel changes TREBLE
    For example, I use the AUX input for my portable XM radio. Normally I have the volume set at 30 (on the radio), but that was far too low. I went to AUX and changed the volume setting (on the DICE) from 50 (default) to 85. Now I don't have to worry about having to change the volume when I go between CD, iPod or XM.
    For me, Playlist 1 is the first Playlist I have in alphabetical order. Also, when I connect the iPod, the first song depends on what I left it at during the day. For instance, if I had been listening to a particular playlist, the first song is the first song of that playlist. If it was left on the main menu, then it's the first song on the first playlist.
    Oh, yeah, I forgot. If you have it on Shuffle (set by the controls of the iPod), you can use the buttons on the steering wheel in order to skip past a song you don't want to listen to. This is handy for me as I have audio books (in MP3 form) and Shuffle will stick an odd chapter or two in its lineup. :D
  13. Bill Merchant
    4,096
    87
    Thanks again, aaf709.
    By the way, at least on a Mac, in iTunes 7 you can select all the chapters/files of your audio book and do a get-info (Command-I on a Mac, not sure on a Windows machine, probably Ctrl-I, or File->Get Info in the menus) which will bring up a dialog with a button at the bottom called Skip When Shuffling which will exclude those chapters from your music shuffle. Also handy for podcasts. You can also set the audio book for Gapless Album to take out the one second pauses between tracks.
  14. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(xraynano @ Dec 6 2006, 10:54 AM) [snapback]358533[/snapback]</div>
    One thing I did notice is that if the song has a long title, like It's The End Of The World As We Know It (And I Feel Fine), it won't display any information of that song; the display shows the information from the last song until the song with the long name is finished. If I change the title to just It's The End Of The World, it will display It's The End Of The Worl.
    Bill, thanks for the tip, I'll give it a try. :)
  15. bravoballer
    san diego, ca
    <div class='quotetop'>QUOTE(aaf709 @ Dec 7 2006, 10:13 AM) [snapback]358840[/snapback]</div>
    AAF- I'm about to hook my portable XM through the AUX port on the DICE but I wanted to see what kind of connection you are using first. Do you have a GLI? Or are you just using a male to male patch cable? Is it 1/8" on your XM as well as the DICE? (I have a Roady XT). Thanks.
  16. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(bravoballer @ Dec 14 2006, 08:38 PM) [snapback]362615[/snapback]</div>
    Yes, it would be a 1/8" plug on either end. I had to use a GLI, so there's some adapters there as well.
  17. CHART
    CHART Member
    184
    <div class='quotetop'>QUOTE(CHART @ Dec 6 2006, 07:09 AM) [snapback]358712[/snapback]</div>
    Well, I guess I get to reply to myself. Installed DICE 10 days ago. Seemed to be working fine. Yesterday, the IPOD was still playing, the steering wheel control was still working, but no music info on the MFD. I reset the IPOD, disconnected the "box", reconnected everyrthing...the MFD shows "CD-2" but the 5 disks are grayed out and no songs show they are playing.
    Sigh......
  18. Blegate
    Blegate Prius Gen III 2013
    132
    Vancouver, WA
    <div class='quotetop'>QUOTE(CHART @ Dec 16 2006, 11:35 AM) [snapback]363112[/snapback]</div>
    Hmmmm I just ordered one of these. Should I call and cancel? Seems like it's going to be a challenge working with this.
    Brian
  19. Bill Merchant
    4,096
    87
    Chart, what year is your Prius and what sound system does it have?
    PriusBrian, in my 2005 with a JBL sound system and 6-disc CD/cassette tape player, everything works fine. I can control play as aaf709 described. I can see the song information on the MFD, though titles are sometimes truncated.
    I can't see the playlist name, but a given track will show up as Disc 1, Track 23 (for example) and show the album name and song title. By default, songs seem to be sorted by Artist; if I don't select a playlist on the iPod before selecting CD2, I get this snappy little number titled "DC Theme" by "7L & Esoteric". The first Artist name, but clearly not the first song name, on my iPod.
  20. CHART
    CHART Member
    184
    2004 with JBL sound system and 6-disc CD/cassette tape player. When I opened my DICE, I noticed that the I-TOYOTA-R had a typed DL-1007 on the top and bottom. I thought that this might be the older type so I called DICE and had them SWEAR to me that this was the correct type for my Prius. They did, and as I said in previous posts, it worked fine for 10 days. Minor glitches, but they always corrected if I chose the next disk, etc. Since yesterday, it has continued to work, sound though JBL, control through steering wheel....just NO text on MFD.
