Oil Analysis, Redline D6 ATF 30k miles
Discussion in 'Gen 3 Prius Technical Discussion' started by TheChip, Oct 22, 2018.
  1. Noahdoge
    Noahdoge Active Member
    202
    144
    Mississippi
    i live in coastal Mississippi where we don’t really get cold winters. The summer now is getting into the high 90s almost 100s. My car is running perfect with 0-20 but I’ve never deviated from that. Do you think my engine would benefit from a synthetic 5-30. Currently at 156k miles right now.
    douglasjre likes this.
  2. luis perez
    luis perez Junior Member
    49
    17
    .........Don't know your Prius C history, but 35k mile spark plug life seems too short.....
    I agree, I am biting my nails with that car. As soon as I can get a week of vacation will check the EGR.
  3. luis perez
    49
    17
    ....20 weight oil came out for thing and one thing only that’s to be more fuel efficient...
    I live in South Texas, for practical purposes winter is nowadays in February for about a week and it will get down to -5C and all else is simply 110F =)
    Ok! I can't quite find any differences between the engine for a 09 and a 14 Prius C on the side of the internals that depend on the oil to work (spark-plugs, water pump, etc are outside that set) so 5w-30 will be, now to attempt to find prices lol
    THANK YOU for your responses!
  4. TheChip
    TheChip Senior Member
    388
    1,210
    Misissippi
    I've been running Motul 0w-40 since purchasing the car nearly 80k miles ago along with using the Redline D6 transmission fluid. I went back to 0w-20 once and noticed the engine sounded louder on startup. I've been very happy with my wear numbers using 0w-40 so I'll stick with it.
    edthefox5, mikey_t and luis perez like this.
  5. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    I've been using 0W-30 for since 100K on the car. Sitting at just under 166K now. No issues, no oil consumption over 15k intervals, no discernable effect on fuel economy. I'm in MA, so significantly colder winters then you, but see the same high temps in summer, just for not as long.
    If you short the trip car a lot, it might not be worth a thicker weight. If you don't, it won't hurt to go to a 30wt, especially as the miles increase.
    luis perez likes this.
  6. luis perez
    49
    17
    Hello!
    Just wanted to share a spreadsheet:
    Bill Norton likes this.
  7. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Yes! Another thread officially hi jacked!
  8. ToyXW
    ToyXW Active Member
    153
    148
    Sacramento
    Its interesting, but virgin oil analysis don't tell you as much as you might think. For instance 80 ppm trinuclear molybdenum may be more effective than 800 ppm molybdenum disulfide, but they are both just counted as "moly" by Blackstone.
  9. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    I've started using Motul in my new rebuilt engine. Are you still doing 5K OCI or have you extended it to 7.5K or 10K miles?
  10. Bill Norton
    Bill Norton Senior Member
    2,143
    733
    MONW, Ks.
    That was a lot of great data! Thanks to Luis!
    Why don't you like that, Grit?
    So it's about engine oil instead of ATF.
    So, you could suggest that it also be posted in other threads about engine oil, instead of the snark.
    But then,,, you have your personal brand to maintain....:(
    TheChip likes this.
  11. luis perez
    49
    17
    Hello!
    I am down to my last 3 90915-10003 filters and one 90915-20004. The goal is to find a filter with similar performance. Is there a thread related to this? Any suggestions on how I should order used oil analysis with particulate counts in mind??
    #151 luis perez, Feb 23, 2023
  12. luis perez
    49
    17
    On another note.... RedLine 5W-30 15304 did stop oil consumption on my 09. I did do an engine clean first. It does quiet down the engine very much as you drive! The wifes 14 started to sound much better in a few months of 0W-20.
    For me the sound levels changed: First 1000 super (erie) quiet, then for another 1000 it will make a bit of noise, then it will begin to quiet down again. The baseline to compare is Mobil EP. That oil was used always in all my vehicles until last year. For me that oil did not work.
    mikey_t and edthefox5 like this.
  13. Mendel Leisk
    41,234
    Probably. But should there be... ;)
  14. luis perez
    49
    17
    Any suggestions on where I should post info or questions about the 90915-10003,10004,20004 oil filters? It's not an item that only applies to a GEN2 or a Prius C =)
  15. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Just use the factory filter. Its a good quality filter has the proper bypass valve.
  16. luis perez
    49
    17
    [QUOTE="...use the factory filter. Its a good quality filter has the proper bypass valve....[/QUOTE]
    Hello! I do agree: In the OEM filter 90915-10003,10004,20004 versions the filtering media was made out of a sponge type material. So far I have not found any data related to those filters. Have you seen any data "out there" by any chance where somebody tested any of those filters? The new OEM version is pleated media and I am wondering if it "does the same" and I am trying to figure out what that means.
    Moving forward Baldwin has a online selector where the filters can be selected based on micron ratings. So far they are the only ones posting that info wide open. If you cross reference the 10003 you get a filter that allows for larger particle size to pass, and the 20004 equivalent has smaller pores: B243. The B243 fits just fine: Same thread and it will seal perfectly on the engine block filter base, it is longer.
    Fred_H likes this.
  17. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Its a very small motor. Its a very clean running motor if you run synthetic oil. Whats all the fuss about oil filters? Make a fuss the other direction and run very high quality oil.
    Grit likes this.
  18. luis perez
    49
    17
    lol I agree & I did make a fuss with the oil. I am grateful that you insisted with Red-Line!
    Check out the B243 oil filter and the specs. Very quietly these guys are making a 12 micron nominal filter., 30 absolute You can find it for $5.00, what do you think? I appreciate your comments!
    edthefox5 likes this.
  19. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Lol...alright!!!
    The G2 Prius loves Redline motor oil its the only oil on the market that will quiet down the solid lifters. I ran that oil 10-30 for over 15 years and sold my G2 after 15 years of ownership and she still ran great and did not eat oil. That ZDDP pack really makes all the difference.
    That's all I run in all my cars. I never see any engine issues whatsoever on any of my cars.
    Here's what 15 years of Redline looks like in a Prius. You get what you pay for.
    StarCaller, m.wynn and Grit like this.
  20. luis perez
    49
    17
    Those pictures convinced me last year. It is true that 0W-20 oil was made for the sake of conserving energy. I have to admit that I felt a bit chicken with using 10W-30 in the G2 engine, I did use 5W-30 in the Prius C engine and that is as far I can go lol. In both cases I did see an improvement. Last year I found out that I was burning engine oil in the G2 because of a misfire code. the engine had lost about 1 1/2 quarts of oil. To make a long story short the 5W-30 redline oil fixed that problem. The G2 still burns a tad of oil, If I try to put a number to it maybe it is about 1/8 of a quart in 5K miles & the misfire codes are definitely gone. I am very happy with those results. The Prius C is not burning oil at all. I am no longer using Mobil 1 EP in any of my vehicles.
    I did place small rare earth magnets on the top of the filter, got them at ebay. Small enough to fit between the tiny inlet holes in the filter's face plate, have been using those magnets for a while in all the oil filters I service. With RedLine I can see that the magnets collect less ferric powder. I wish I had better ways to quantify that =) That's my poor mans test. I am hesitant to do a test on the oil because I am not sure if those results are going to meant something to me =) I can't quite spare cash right now. In the long run, RedLine helps me save plenty of money.
    I have just used my last Toyota WS quarts (bought them by the case of course), next oil change will be RedLine fluid. At some point 2 years from now will do that change.
    Gratzi!
