2014 with 180K miles for $9.5K or 2009 with 50K miles for $10K
Discussion in 'Gen 3 Prius Main Forum' started by Victor1507, Feb 24, 2023.
  1. Victor1507
    Victor1507 Junior Member
    I'm looking at two used Prius. One is a 2014 with 180K miles for $9.5K. It has no accidents, one owner, and regular maintenance at Toyota dealership. The other is a 2009 with only 50K miles for $10K. Also no accidents, but three owners, and less documented service history. The 2009 would be about $1500 more expensive than the 2014 because of a $999 dealer fee. Which is the better option?
  2. Todd Bonzalez
    Todd Bonzalez Active Member
    250
    160
    Ireland
    I'd go for the 2014 as it's newer and more likely to be worth something if you sell it on in the future. Also it's $1500 cheaper as you say.(y)
    Given the age of both I'd buy according to the condition rather than service history. 180k miles wouldn't bother me as long as it hadn't been used as a taxi or something
  3. Victor1507
    Some people say to avoid the 3rd gen because of EGR/head gasket issues. 2010-11 were the worst years for the gen 3. 2014 should be better. The 2009 has low miles, but it's approaching 15 years old and might need a new hybrid battery. 2009 was the best year for a gen 2.
  4. Todd Bonzalez
    250
    160
    Ireland
    Meh, not every gen 3 has these issues. The fact the this gen 3's made it to 180k would suggest that it may have been well maintained. If you have a specific concern about EGR and head gasket issues, use some of the money you could save to get an independent mechanic to check these areas before buying.
    Well you identified the biggest potential issue with the gen 2 :LOL:. It's easier to find a replacement engine for a gen 3 than a good battery for a gen 2 (how much is a gen 2 battery at a dealer these days?). Spending $1500 more for a car that's five years older doesn't make sense to me, but I'm sure others will beg to differ.
  5. Victor1507
    Here's a battery for a gen 2 with a 4 Year 48,000 Mile Warranty for $1,990. They also have reconditioned batteries with a 12 Month 12,000 Mile Warranty for under $1,000. I assume this price excludes installation.
  6. JC91006
    JC91006 Senior Member
    16,827
    8,600
    Both of these cars are either nearing 10 years old or over 10 years old, bad news for hybrids. There are many parts to replace after a hybrid gets to 10 years old and they aren't cheap.
    If I had to choose, the one that will hold it's value best would be the 2014, but that car at 180k miles may have issues, the reason it was sold to the dealership.
    Also the one with the super low mileage, you should run your own carfax to determine if the mileage is accurate. There are many reports of mileage rollbacks from independent small dealerships (more red flag when service records not available or missing.)
    Todd Bonzalez likes this.
  7. Mendel Leisk
    41,861
    The third gen with 180k miles is more'n likely blowing it's head gasket. Year doesn't matter.
  8. bisco
    52,350
    any non hybrid options available?
  9. nicoj36
    nicoj36 Active Member
    518
    162
    Keep in mind that some high mileage gen-3s are let go by their previous owners due to rattling and head-gasket issues. So if you do decide on the gen-3, i suggest you clean the EGR, intake manifold, replace pcv valve right away. In my opinion do a full blown maintenance like all fluids, spark plugs, clean the maf sensor, fuel treatment, etc.
    jerrymildred and ColoradoBoo like this.
  10. Todd Bonzalez
    250
    160
    Ireland
    It's pretty easy to test for head gasket failure, right?
    ColoradoBoo likes this.
  11. Mendel Leisk
    41,861
    That just tests for exhaust in the coolant, and third gen head gasket failures are usually coolant in cylinder. Any 3rd gen with that sort of miles I don't think I'd touch, because the odds are so high it's being ditched.
    Leak-down test and boroscope inspection may detect, but if current owner puts in some sort of stop leak product that'll likely mask the head gasket symptoms.
    Plus, if you're going to such lengths to assess the vehicle, it's getting kinda nuts.
  12. Tombukt2
    13,341
    2,401
    The gen2 hands down . If I'm driving
  13. Leadfoot J. McCoalroller
    8,134
    7,641
    Pennsylvania
    2018 Prius c
    From a physics standpoint, it's really hard to get one of those without the other.
    Mendel Leisk and jerrymildred like this.
