Gen 5 Prius Prime owner's manual
Discussion in 'Gen 5 Prius Main Forum' started by Gokhan, Mar 5, 2023.
  1. Gokhan
    Gokhan Senior Member
    6,476
    2,590
    Paramount CA
    #1 Gokhan, Mar 5, 2023
    Edward Coan, Maxwell61 and model464 like this.
  2. Hammersmith
    Hammersmith Senior Member
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    model464 and Gokhan like this.
  3. Gokhan
    6,476
    2,590
    Paramount CA
  4. Gokhan
    6,476
    2,590
    Paramount CA
    Interesting specs on the battery.
    Gen 5 Prius HEV cell capacity: 4.08 Ah
    Gen 5 Prius PHEV (Prius Prime) cell capacity: 51.0 Ah
    This means that they are using rather large pouch cells in Gen 5 Prius Prime PHEV. They are more than ten times the size of the cells in Gen 5 Prius HEV. 4 Ah is roughly the capacity of an 18650 flashlight lithium-ion battery such as those used in some older Tesla models or the capacity of an iPhone battery. 51.0 Ah is a giant pouch cell.
  5. Gokhan
    6,476
    2,590
    Paramount CA
    Another interesting spec difference between the HEV and PHEV is the oil capacity. The PHEV takes 0.3–0.4 qt less oil than the HEV despite having the same engine. Perhaps spin-on vs. cartridge oil filter?
  6. Hammersmith
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Bet the oil pans are slightly different because of clearance issues related to something with the hybrid system.
    Gokhan likes this.
  7. Gokhan
    6,476
    2,590
    Paramount CA
    It doesn't look like Toyota has started using the LG pouch cells yet. I think the 51.0-Ah cell in the PHEV might be this Panasonic prismatic cell. It has an impressive cycle life of 2,000 cycles at 1C (1-hour charging). It will easily last for 10,000 cycles at C/4 (4-hour charging). That is 400,000 miles of life even if the car is used as a pure BEV!
    https://www.geebattery.com/battery/panasonic-li-ion-battery
    #7 Gokhan, Mar 5, 2023
    farmecologist likes this.
  8. farmecologist
    farmecologist Senior Member
    1,959
    1,799
    Southern MN
    If true...that is really nice. And the modules should be vastly easier to replace than BEV batteries ( i.e. - Tesla ). (y)
    Gokhan likes this.
  9. Trollbait
    12,653
    I thought pouch batteries were the more common type in BEVs. By model, not numbers on the road.
    Gokhan likes this.
  10. Gokhan
    6,476
    2,590
    Paramount CA
    I don't think Panasonic makes them, but puch batteries are becoming more popular. Solid-state batteries are usually pouch batteries, as they require an external pressure to be applied on. Tesla batteries are either cylindrical (Panasonic?) NMC (some older models being NCA) or prismatic CATL LFP. NMC/NCA/LFP refer to the cathode active material. LFP is less energy-dense but a lot cheaper and typically has a longer cycle life.
  11. Trollbait
    12,653
    It seems Ford, GM, Hyundai, and Nissan favor pouch cells.
    Gokhan likes this.
  12. Gokhan
    6,476
    2,590
    Paramount CA
    They may be buying them from LG then.
  13. Trollbait
    12,653
    GM is. Didn't want to dive that deep. IIRC, Nissan/Renault had their own battery production in the beginning.
  14. Maxwell61
    Maxwell61 Active Member
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    Gokhan likes this.
  15. Gokhan
    6,476
    2,590
    Paramount CA
    You should be able to read the US manual (first link), can't you?
    Maxwell61 likes this.
  16. Maxwell61
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    Unfortunately not, Google says in my country is not allowed the access.
    403 ERROR
    The request could not be satisfied.
    The Amazon CloudFront distribution is configured to block access from your country.
  17. Roqu3
    Roqu3 Member
    92
    63
    Lima
    2019 Prius c
    yeah it doesn't work for me also
  18. JoeBlack
    JoeBlack Member
    112
    89
    Europe
    2021 Prius PHV
    VPN is your friend :)
    Manual
    bisco, Maxwell61, Roqu3 and 1 other person like this.
  19. Louis19
    Louis19 Active Member
    394
    369
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Thanks alot:) , it's the only way I can acces the manual in Canada(y)
  20. Maxwell61
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
