Pictures of various items in a Prius C
Discussion in 'Prius c Main Forum' started by parked, Feb 21, 2018.
  1. Mendel Leisk
    41,804
    Like the orange colour; it goes good with the black rims and trim.
  2. Roqu3
    Roqu3 Member
    92
    63
    Lima
    2019 Prius c
    Habanero
  3. Leadfoot J. McCoalroller
    8,130
    7,627
    Pennsylvania
    2018 Prius c
    Actually "HabaƱero" was discontinued by then, so this is hue is called "Tangerine Splash Pearl" which is a little brighter and has a lot more green hiding in the sparkle coat.
    The winter rims were taken from a Hyundai Accent and work beautifully on the Toyota.
    vvillovv likes this.
  4. priusCpilot
    priusCpilot Active Member
    663
    210
    LA
    I ran the fire stone ride helper bags 2012 Toyota Prius c Suspension Enhancement Firestone | etrailer.com in the rear to lift it up to level under load. After ten years they tore but I can just replace the bags since the hoses are there.
  5. Leadfoot J. McCoalroller
    8,130
    7,627
    Pennsylvania
    2018 Prius c
    Well if you total it up, you'll see I'm still well under the rated payload for the car even with my fat a## on board. Never felt the need to add a leveler but it's cool that they exist!
  6. priusCpilot
    663
    210
    LA
    If you have a sagging in the rear when loaded due to age of the springs and suspension, this can also help. It does rise more poised in rear with them.
  7. Leadfoot J. McCoalroller
    8,130
    7,627
    Pennsylvania
    2018 Prius c
    I didn't get a picture :(
    But today I was able to haul a toddler bed frame & mattress (52"x28") entirely inside the Prius c, no special contortions needed.
    farmecologist likes this.
