No power to low beam headlights
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by jeff.gt, Nov 15, 2020.
  1. jeff.gt
    jeff.gt New Member
    Chesapeake, VA
    Checked everything. New bulbs, fuses good, replaced turn signal switch too. Still No 12v power at the low beam fuses. HI Beams work, DRL works too. Does low beam power come from the integration relay? I really don’t want to pull the fuse box apart and replace that!
    jeff
  2. jeff.gt
    jeff.gt New Member
    Chesapeake, VA
    Gave in and took it to Toyota. Found a short somewhere in the wire harness between the steering column and passenger side fuse box. Not good!
    valuequest likes this.
  3. valuequest
    valuequest Junior Member
    southeastern Virginia
    Has anyone else had a problem with power delivery to the low beam headlights? What was the cause and the solution?
