2023 Weird tire size and gas mileage: XLE 195/50R19 52MPG vs LE P195/60R17 57/56 MPG
Discussion in 'Gen 5 Prius Fuel Economy & Prime EV Range' started by Blue Prius 2023, Mar 4, 2023.
  1. Blue Prius 2023
    Blue Prius 2023 New Member
    2023 Prius
    For the 2023 Prius the tire size for the 19 inch wheels is 195/50R19. Which is not very common and will probably be expensive when you can find them. I believe they are also bringing down the gas mileage of the XLE.
    So here's my question/concern, should I sell/trade my XLE tires and wheels for LE tires and wheels to get better gas mileage, a smoother ride and cheaper tire replacement?
    arcbat and mountaineer like this.
  2. Trollbait
    12,665
    The 17 in wheels with improve fuel economy, but they are still an odd size for the US, thus just as hard as the 19 in ones to find in the beginning.
  3. Mendel Leisk
    41,861
    Sit tight for a few years.
  4. bisco
    52,351
    have you actually taken possession?
  5. mountaineer
    mountaineer Active Member
    146
    115
    Hamilton, ON
    2019 Prius Prime
    I intend to do this too. Will ask the dealer if they have any base 17" Primes being delivered to customers who'd like to swap for my 19s.
    Eventually would like to put Nokian WRG4 all-weather tires on. kaltire.com already has the 2023 Prius in their configurator, but no tires available. Now we wait.
    dbat23 and Kalianyia like this.
  6. Hammersmith
    Hammersmith Senior Member
    2,315
    2,361
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Agreed on the WRG4 or maybe Michelin CrossClimate 2.
    Here's a list of all the tires I've found that match the Prius sizes exactly. It's probably not complete, but pretty close for the moment. All are Japan-only or Toyota-only right now, but I expect that will change over the next few months.
    Code:
    195/50R19
    Toyo           Proxes Comfort IIs*        Summer/AS
    Bridgestone    Ecopia NH200               Summer/AS
                   Blizzak VRX3               Winter Studless
    Yokohama       BluEarth-GT AE51*          Summer/AS
    195/60R17
                   Observe GIZ2               Winter Studless
                   Blizzak VRX2               Winter Studless
    Yokohama       BluEarth-FE AE30*          Summer/AS
    *Toyota OEM tires
    Kalianyia and mountaineer like this.
  7. Gokhan
    Gokhan Senior Member
    6,511
    2,601
    Paramount CA
    17" tire is the premium tire.
    19" tire is the inferior-spec but better-looking tire.
  8. akiraproject24
    akiraproject24 New Member
    Pennsylvania
    Dropping down to the 17" wheels for 5 mpg increase is pretty big. Anyone happen to know the offset on the OE 17" wheels? Would be nice to find a nicer looking replacement at some point for the OE 19" to recoup that mpg. Planning to investigate Corolla offset and lug pattern or even older prius/Corolla wheel specs.
    dbat23 likes this.
  9. Gokhan
    6,511
    2,601
    Paramount CA
    aluminum 17×6-1/2J or aluminum 19×6-1/2J (except additional steel 17×6-1/2J option in Japan)
    195/60R17 90H or 195/50R19 88H
    PCD: 114.3 mm (4.5 in)
    inset: 40 mm
    hub-hole diameter: 60 mm
    bolt-hole diameter: 19 mm (except 14 mm for steel 17-in wheels in Japan)
    number of bolts: 5
    #9 Gokhan, Mar 15, 2023
    dbat23 and akiraproject24 like this.
  10. daisy555
    daisy555 Senior Member
    1,727
    715
    CT
    Anyone own an XLE AWD and getting advertised mpg. My 2009 is getting 47 mpg right now. I’m still having trouble accepting that 2023 hybrids are barely beyond that.
    Gokhan likes this.
  11. Mendel Leisk
    41,861
  12. daisy555
    1,727
    715
    CT
    I’m the one with the 2009 that needs repairs and who has time sensitive funding for a new car so I’m not sure I can wait until an equivalent hybrid appears. Who even knows if one will? If there was Corolla hatch hybrid that matched Prius mpg I would jump on it. I really liked my Pontiac Vibe…well… the Toyota parts anyway except for cloth seats.
  13. Mendel Leisk
    41,861
    Yeah Pontiac Vibe, and its Toyota Matrix counterpart, were great, unpretentious people and cargo movers. Is the Vibe cancelled as well?
    If Toyota would bring back the Matrix (and resist the urge to mess with it), doubly so as a hybrid, I’d be very interested.
    If our ‘10 Prius ever needs replacement. At this point it’s been trouble free though, may be our sunset car.
    #13 Mendel Leisk, May 7, 2023
  14. Hammersmith
    2,315
    2,361
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    More than just the Vibe was cancelled at Pontiac. lol. Both have been dead for almost 15 years.
    Sorry, that just sounded to me like someone asking "what's Studebaker doing lately" and I got a laugh out of it.
    tovli, Teleplayer, GuyLR and 3 others like this.
  15. Gokhan
    6,511
    2,601
    Paramount CA
    @flarecde in NY has a 2023 Prius Limited AWD.
    daisy555 likes this.
  16. daisy555
    1,727
    715
    CT
    Thanks! What’s the best way to communicate…search for their most recent post? Used to be able to message members. Maybe @flarecde will see your post?
  17. Mendel Leisk
    41,861
    You get an alert whenever your username is invoked with the @ symbol.
    daisy555 and Gokhan like this.
  18. Gokhan
    6,511
    2,601
    Paramount CA
    You will get 50 mpg with XLE w/AWD.
    You will get 58 mpg with LE w/o AWD.
  19. flarecde
    flarecde Member
    57
    68
    NY
    2023 Prius
    Limited AWD-e
    My milage varies a lot. The old C was more consistent, and probably a little better at least. Hard to compare as I could use the HOV lane and therefore dealt with less traffic.
    Short, sub-1 miles local drives to and from the store is not so great, high 30s, low 40. My general commute, which is the bulk of my miles though, is better. Over 20 miles of heavy traffic highway driving, usually get low 50s, but I've gotten as high as 60 a couple days.
    Note: this is just based off the car's display, for whatever that's worth. I know its not of supreme accuracy. I've not gotten around to doing the math when filling up. I tend to get gas while going to get food, and for some reason fueling myself always seems to be more important!
  20. Trollbait
    12,665
    Some of the variance can be because the car is still new, and new to you.
