In the market for tires. Trying to keep MPG
Discussion in 'Gen 4 Prius Fuel Economy' started by Recian, Mar 6, 2021.
  1. Mambo Dave
    Mambo Dave Active Member
    641
    306
    2019 Prius
    L Eco
    51 psi isn't something I'm willing to mix with well over 100-degree highway surface temperatures.
    Though I am now (currently, for the last few months) running 41 front and rear. Perhaps this is why the road noise seems even higher at over 75 MPH?
  2. atterbury90
    atterbury90 Junior Member
    SE Pennsylvania
    2022 Prius
    XLE AWD-e
    That's unbelievable mileage! Way to go Sir.
  3. douglasjre
    douglasjre Senior Member
    1,901
    661
    Orlando, FL
    What would help my fuel economy?
  4. ken2116
    ken2116 Junior Member
    37
    Northern CA
    2019 Prius
    I just mentioned in another thread that our mileage dropped 18% when we tried 195/65R-15 Michelin Defenders for several weeks and over 500mi. after the original Dunlop Enasaves were replaced at 42kmi (4/32 remaining tread). Mileage immediately returned to normal when the Defenders were exchanged for a new set of Dunlops. Over 50 yrs we've had far better satisfaction with Michelins than with other brands and had looked forward to switching to them, but 18% mileage was too big a hit to accept.
    #24 ken2116, Nov 12, 2022
  5. douglasjre
    1,901
    661
    Orlando, FL
    Wonder what the measured sidewall tire height was
    Mambo Dave likes this.
  6. Mambo Dave
    641
    306
    2019 Prius
    L Eco
    Michelin revs per mile: 832
    Dunlop revs per mile: 836
    Michelin tread depth 10/32
    Dunlop tread depth 8/32
    Michelin weight 18 pounds
    Dunlop weight 16 pounds
    https://www.tirerack.com/tires/tires.jsp?tireMake=Michelin&tireModel=Defender+T%2BH&sidewall=Blackwall&partnum=965HR5DTH&tab=Sizes
    tirerack.com/tires/tires.jsp?tireMake=Dunlop&tireModel=Enasave+01+A%2FS&sidewall=Blackwall&partnum=965SR5ES01ASV2&tab=Sizes
    So if I have my tires chosen correctly, he traded weight, quality, tread depth (which boosts wet traction / decreases hydroplaning) for a lighter-built tire (I have a had time believing that they are exactly 18 pounds and 16 pounds each) with less tread depth.
  7. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    I've tried many different tires. No change in mpg.
    A well conditioned battery on the other hand I do see better mpg.
  8. Mambo Dave
    641
    306
    2019 Prius
    L Eco
    That was supposed to read: "I have a hard time believing that they are exactly 18 pounds and 16 pounds each"
  9. ken2116
    37
    Northern CA
    2019 Prius
    Exactly, that's the trade-off. Of course, the Michelin tread depth is deeper only until worn to 8mm. However the two sets of Dunlops have held dry and wet roads well (heavy rain, higher speeds) and despite some bad Forest Service roads, at 66kmi total Dunlop experience (now on our second set), we haven't managed to wreck one. In other words, they appear to be reliable until worn out.
    Overall cost per mile of running Dunlops vs. Michelins, factoring in expected tread life (longer for Michelins) is about a wash, though at current gas prices the Dunlops might be favored a bit. There's also the wear and tear cost of running the engine/ driveline/battery that much harder, this is difficult to pin down but could be a factor over a long life. Petroleum usage (figured as pounds of gasoline + rubber) favors the Dunlops. If this car saw snow we'd put Michelins on for the winter, but we live in CA and have another car with Michelins for ski trips.
  10. beef jiggles
    beef jiggles Member
    136
    34
    Colorado
    It will take you decades to recoup the money you spend on ‘lightweight’ rims with mpg savings That’s dumb.
    Prius wheels are already very light, and far more durable than aftermarket trash.
    regardless, no matter what tire you go to it’s likely to be heavier than whatever you have now, because you’re currently missing tread from wear and the slight change of overall radius is making it seem like you’re getting better mileage than you actually are. Don’t expect better mpg with any new tire.
    Anything low rolling resistance will be loud, have poor traction and be worthless in snow but get better mileage over time. If you live in an area that sees whether you will need separate tires for winter.
    OR just get decent all seasons and don’t stress over it.
    douglasjre likes this.
  11. bikeprof
    bikeprof New Member
    26
    Houston
    2020 Prius
    Best size to go is the OEM Prius standard...
    195/65/15
    Mine are 42PSI -- Arizonians/Discount
    I was really thinking about up-sizing to the 17 wheels(to make the vehicle look prettier) but it'll damage the pocketbook a pretty penny,
    NOT get ANY + mpg improvement and tires are almost made out of gold...
  12. KRDucky
    KRDucky Junior Member
    27
    US
    2018 Prius
    I'm having a hell of a time getting above 51mpg here in south Texas where speed limits are usually 70+ mph. The dealership put Continental tires on my 18 two. They had originally put something else on it when they sold it to me but it was the incorrect size and my speedometer was off by 7 mph
    SM-G981V ?
