Apple CarPlay Wireless
Discussion in 'Gen 4 Prius Audio and Electronics' started by PaulDM, Jan 12, 2023.
  1. PaulDM
    PaulDM Active Member
    616
    318
    UK
    2022 Prius
    Excel
    Happy to report I got Apple Carplay working wirelesly in my Gen4 (2022)
    Used an adapter called Carlinkit. This was version 4 (the blue one). It got a little stuck at the connecting phase but a downgrade of the firmware to a previous version (very straight forward to do) fixed this.
    Stable connection and the head unit sorts itself out within around 20 seconds ( about 15 seconds longer than a standard Bluetooth connection) at startup.
    This adapter only works on cars fitted with the wired version of carplay and/or Android auto.
    RojaRosie and chuckiechan like this.
  2. par_struggle
    par_struggle Member
    44
    36
    nv.us
    2020 Prius
    LE AWD-e
    I'll second this, I bought the same last week and it arrived today. No firmware fiddling for me, just plug up and go. It added Android Auto to my son's 2020 awd-e for $60 and near zero effort - way easier than swapping head units.
    RojaRosie likes this.
  3. TucsonPrius
    TucsonPrius Member
    167
    Tucson, AZ
    2020 Prius
    Do you know if this works with Android 10 (i.e non-wireless Android Auto)?
    Thanks,
  4. Nurse19673
    Nurse19673 New Member
    Oklahoma
    2022 Prius PHV
    Were you able to hook up CarPlay wired prior to this? I can’t get mine to work at all.
    #4 Nurse19673, May 23, 2023
  5. GoodOldBob
    GoodOldBob Junior Member
    Mena, AR
    2020 Prius
    L Eco
    I'm using Carlinkit V4 and an Android V13 phone.....it was plug and play with no issues. Google maps navigation via Android Auto was the key feature I was after and I got it. I'm still exploring the whole Android Auto feature set, but for $40, it was a worthwhile purchase. I haven't quite figured out how to do the firmware update though. Plus, realize that when your cellphone is connected to the dongle via wifi....you can't get your internet from wifi at the same time. Leaving only cellphone mobile data open for internet connection.
    Polie likes this.
  6. beef jiggles
    beef jiggles Member
    135
    34
    Colorado
  7. Nor.Prius
    Nor.Prius Junior Member
    Southern New Mexico
    tried this, found it overides the built in amp, sounded worse, and when removed, bricks the car's ability to use the reverse camera.
    Brother A likes this.
