Car thinks there is a key inside???
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ianmeister, Mar 23, 2023.
  1. Ianmeister
    Ianmeister Active Member
    304
    311
    Meridian Idaho
    Hey all! So my 2007 is acting like I’ve left a key inside when I shut it off and walk away. It beeps 3 times, won’t allow a lock, and gives a yellow light icon of a key with an exclamation point. I only have one key. What the heck is going on? TIA!!
  2. SFO
    SFO Senior Member
    5,286
    4,225
    Northern California
    How healthy is the 12v battery?
  3. pasadena_commut
    pasadena_commut Senior Member
    1,350
    408
    Southern California
    Has it always done that or did you just get the car? If the latter, the simplest explanation is that the previous owner dropped a fob in the car and its battery is still active. Does the car have the smart key? If so, leave the other fob far away and see if the car will start anyway when you push the start button. That should only happen if there is a fob somewhere in the car. Most likely locations are: wedged in next to one of the front seats, in one of the many storage slots in the center console, under the mats, in the glovebox, in the storage slots in the doors. If the car has a glasses holder near the front of the ceiling, look there too.
  4. Ianmeister
    304
    311
    Meridian Idaho
    it just started doing it, and it won’t start with the fob away from the car. Now that SFO mentions it, the 12v is a bit elderly. Stay tuned!
  5. Ianmeister
    304
    311
    Meridian Idaho
    ok 12v reads 14 with the car on, 11.8 off. Time for a battery!
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,089
    5,806
    Columbia, SC
    Doesn't the car beep when the fob battery is detected as getting weak? Maybe it's telling you to replace a $4 battery and not a $200 battery.
  7. dbstoo
    dbstoo Senior Member
    1,232
    660
    Near Silicon Valley
    2024 Prius Prime
    My wife had a similar problem when she rented a car from hertz. She could not get it to stay locked. She found the spare key fob in an envelope in the spare tire compartment. It had fallen out of it's silvered mylar envelope.
    If the extra fob is near the diver's seat, it should start with the main fob 30 feet away. If the extra key is in the back seat or trunk it will not start.
  8. bisco
    48,942
    I have gotten the ‘key detected in car’ message occasionally.
    No idea why
  9. Ianmeister
    304
    311
    Meridian Idaho
    Hmmmmm, thing is that it’s inconsistent. Sometimes it’s fine, sometimes wonky.
  10. Ianmeister
    304
    311
    Meridian Idaho
    ah yes. I forgot to mention that. I did replace the CR 2032 battery
  11. Ianmeister
    304
    311
    Meridian Idaho
    yeah. It just comes and goes. Weird.
  12. bisco
    48,942
    maybe a funky ecu or connection
