2023 Prius Reviews
Discussion in 'Gen 5 Prius Main Forum' started by Danny, Dec 14, 2022.
  1. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    Too bad it cuts when he start driving around - hoping he posts the rest soon.
  2. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    How about price paid??
    McCarthy likes this.
  3. Trollbait
    12,631
    All cars use to come with a jack. Instructions for the goo pump were to jack up the flat corner. Less work for the little compressor that way.
    Notes in the manual make it sound like the jack was something you'd have to buy from the dealer for this model.
  4. TgrXtrm
    TgrXtrm New Member
    22
    Ohio
    2023 Prius
    Why do you have to be very careful parking? Visibility?
  5. mrlarrys
    mrlarrys Junior Member
    26
    68
    PA
    2023 Prius
    not visability but the car is easy to get a ding - sides are smooth with no door guards, a car that would park next to you and open their door could cause easy damage. Other cars and the people who drive them could care less about opening the door and causing someone else dammage !
  6. bisco
    52,186
    and no matter howfar away you park, someone always parks next to you :p
    mikey_t, Trollbait and pakitt like this.
  7. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
  8. Hammersmith
    Hammersmith Senior Member
    2,315
    2,357
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Arguably the best part of that video is that the reviewer's pre-production car had Michelin tires. I believe that makes 5 major tire manufacturers confirmed to be making tires in at least one of the needed sizes. (Granted, he doesn't think much of the Primacy A/S on the car, but now the possibility exists for CrossClimate2 or Pilot Sport A/S 4.)
  9. Sammyd
    Sammyd New Member
    2016 Chevy Volt
    Consumer Reports car reviews have been laughable for years.
  10. Maxwell61
    Maxwell61 Active Member
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    Waiting for US driving test on the Prime, you can browse YouTube for the test drives of the EU Prime.
    do not know if has been posted already, this is in english.
    telmo744 likes this.
  11. JoeBlack
    JoeBlack Member
    112
    89
    Europe
    2021 Prius PHV
    I found a really nice review / overview of new HEV and PHEV, even with comparison to older PHV.
    mikey_t, Maxwell61 and pakitt like this.
  12. Maxwell61
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    Well, this is interesting, the HV mode in the Prime have a 3-step settings! Have anyone more infos?
    The tester wanted to try max acceleration and placed the setting to the highest level.
    Can be the setting of a kW limit to the EV mode? Probably.
    Here the moment he shows it:
  13. Hammersmith
    2,315
    2,357
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Google translate says it's a regenerative braking setting. The manual says it's only connected to the B choice on the shift lever. Since most of us typically use D, it probably is fairly meaningless to those not in mountainous regions. I don't think the reviewer understood what the settings meant.
    The setting is described starting on page 260 of the US owner's manual.
    Maxwell61 likes this.
  14. Maxwell61
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    Manual found out, thanks.
    #134 Maxwell61, Apr 2, 2023
  15. Hammersmith
    2,315
    2,357
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Prime manual.
    https://assets.sia.toyota.com/publications/en/om-s/OM47E73U/pdf/OM47E73U.pdf
    If that doesn't work for some reason, go to the US Toyota site and click 'Owners' > 'Manuals & Warranties' > then select 2023 Prius Prime and chose 'Toyota 2023 Prius Prime Owner's Manual (OM47E73U)'
    edit: Was just a bit too late. lol
  16. JoeBlack
    JoeBlack Member
    112
    89
    Europe
    2021 Prius PHV
    If I am not mistaken, there are settings affecting the amount of regen breaking (probably two steps) + Eco, Normal, Sport and Custom.
    This time Eco vs Sport should not just mean sensitivity of gas pedal, but affect power steering and maybe more aspects.
    That's probably why he set that settings to the max and than commented steering became much more heavy (sports like).
  17. hyhi
    hyhi Member
    163
    48
    fl
    Saw the video, plus there is a link to the full write-up here.
    Toyota Prius Plug-in Hybrid (2023 prototype) | Reviews | Complete Car
    Do have a question though…
    In ev mode only, using the Prime’s battery and not ICE, does the CVT rubber band effect then not apply in any manner? I know in ICE mode the CVT is always keeping the revs in the sweet spot thus the engine racing feels at times while waiting for the wheels to sort of catch up (at least that is the sound effect to the driver…well me).
  18. JoeBlack
    JoeBlack Member
    112
    89
    Europe
    2021 Prius PHV
    Nope, in EV there is pretty much instant response, especially in Sport/Power mode - at least that is my experience with current PHV and new PHEV should work identically.
  19. Trollbait
    12,631
    MG2, the traction motor, connects to the drive line after the planetary gear set that makes up the CVT for the engine. It is about as direct a connection to the wheels as in a BEV.
    JoeBlack, Maxwell61 and telmo744 like this.
  20. hyhi
    hyhi Member
    163
    48
    fl
    Nice, so smooth drive for 30 miles or so and no ICE…just then have to wait 4hr wait for battery recharge :(
