  1. ASRDogman
    ASRDogman Senior Member
    7,541
    3,894
    Excessive camber will cause wear, but you will feel it.
    Look at the older VW's, air cooled. The rear wheels have a lot of postive camber
    and the wear evenly.
  2. Matth Torrijos
    Matth Torrijos Active Member
    114
    207
    Poway
    IMG_6712.jpeg IMG_6711.jpeg Installed CF kenstyle spoiler
    ukulelegeek, icyrius, ockevin and 4 others like this.
  3. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    I like the solid red tail lights
  4. Matth Torrijos
    114
    207
    Poway
    Thanks! Its just film, im planning to redo it properly by actually removing the tail lights and reapplying tint
  5. Montgomery
    2,254
    2,241
    Orange County, CA
    I got some aftermarket tails while visiting Hybridpit awhile back. Didn't like the "bright shine Chrome look" on the lower half, so I wrapped the bottom portion with tint and double wrapped the bottom quarter side to give it a darker PXL_20220517_230617929.jpg PXL_20230406_223611855.jpg look for the profile.
    ukulelegeek, m3pare, icyrius and 4 others like this.
  6. icyrius
    icyrius Active Member
    238
    114
    Florida, USA
    2014 Prius v wagon
    I have to find a passenger side window. Thieves broke in my son’s car last night. $1000 deductible from insurance…
  7. douglasjre
    douglasjre Senior Member
    2,164
    715
    Null, NL
    Miami?
  8. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,440
    2,404
    Taylors, SC
    My dad and his friend just developed this custom MICRO speed SHIFTER with Tom's inspired with ball PEEK shift knob for the Gen 3 Prius.
    The cut down "speed" shifter centers the knob on the shaft for quick shifting with just a flick of the index finger.
    Since the shift knob is center, rather than oddly shaped as the OEM one, all movements are even rather than in an odd spaced multi -directional action.
    Unlike a much more expensive button shifter, there is no need take the driver's vision off the road to look, hunt for and find the desired function button.
    This shifter emphasizes function over looks.
    ockevin likes this.
  9. Bill Norton
    Bill Norton Senior Member
    2,145
    734
    MONW, Ks.
    But the function is to put it into D once, until the next drive.
    Oh, I guess sometimes I'll use R for a little bit....
  10. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Chicago, Portland or Philadelphia
  11. Bill Norton
    2,145
    734
    MONW, Ks.
    Win! $1000 deduct is the way to go!
    He saved way more than the cost of a used window and its installation.(y)
    No, just down the street from your house!:unsure:
  12. Bill Norton
    2,145
    734
    MONW, Ks.
    No. Just down the street from your house.
  13. Montgomery
    2,254
    2,241
    Orange County, CA
    I feel you bro....
  14. ASRDogman
    7,541
    3,894
    Coots, icyrius, ukulelegeek and 5 others like this.
  15. Bill Norton
    2,145
    734
    MONW, Ks.
    Congrats!
    Do you have a list of unscheduled maintenance?
    Like head gaskets?
    And what 'Off Menu' maintenance you performed?
    I hope to be right behind you someday!
  16. ukulelegeek
    ukulelegeek Active Member
    159
    112
    I got tired of the scruffy, dull look of the black spoiler of my Gen 3. So, I painted that sucker. I had seen a white one with a matching spoiler, so I did it too, cause I liked it. 1 coat of sticker, after sanding, 3 coats of Toyota white, 3 coats of pearl, 3 coats of gloss. I did all the masking myself, so it isn't perfect, but had zero overspray. Whadaya think?
    icyrius, Xterra72, Burna J and 3 others like this.
  17. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    Looks good, but isn't that overspray on the top half and far edge of the hatch glass in the picture?
    If it is, some rubbing or polishing compound and some elbow grease will remove it.
    ukulelegeek likes this.
  18. Matth Torrijos
    114
    207
    Poway
    Molding the widebody flares to make it actual wide body IMG_7241.jpeg IMG_7242.jpeg
    ukulelegeek and w84me like this.
  19. ukulelegeek
    159
    112
    It's more like paint dust. It'll come right off with a washing. Thanks for noticing.
  20. brzy25
    brzy25 Junior Member
    40
    30
    Ran over a big road cone on the highway late at night. Did a quick super glue together so I could drive it to work the next day, then went back with epoxy and sand paper to fill the gaps. Used a base coat, pearl, and clear coat kit off Amazon to match the blizzard pearl. It's not perfect but it doesn't hurt me to look at it at least.
    IMG_2285.jpeg IMG_2572.jpeg IMG_2573.jpeg IMG_2574.jpeg IMG_2583.jpeg IMG_2599.jpeg IMG_2600.jpeg
