What happens if I disconnect the 12v battery?
Discussion in 'Prime Audio, Electronics, and Infotainment' started by MikeDee, Apr 4, 2022.
  1. MikeDee
    MikeDee Senior Member
    1,580
    597
    San Francisco Bay Area
    Will I lose radio presets? Any other information? Clock setting? Please, no speculation. I want to know from someone that's actually done it and what happened and what needed resetting (if anything).
    52,092
    unfortunately, there have been different experiences. for me i lost trip memory. radio and windows were fine.
    there have been various combinations for unknown reasons. you can always put a 12v source on the front jump point.
    some seem to have lost mpg's until the computers relearn something or other, i don't understand it.
  3. Dominus
    Dominus Junior Member
    Illinois
    On mine when i installed my power setup for my sub amp and had disconnected for a few hoursi lost my radio presets, clock, and mpg, and upon starting it it didnt start and just showed all the alarm indicators which cleared and started up fine upon a second press of the power button
  4. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    I haven't done it on my PP yet, but from reading others' reporting, the behaviors are different on the PP models compared to older Prius. Even for a PP, 7" HU used on the base trim (either Plus in pre-2019 or LE for post-2020) and 11.6" HU used on the higher trims may behave differently.
    OP has a 2017 PP Plus. There is no front jump post in Gen4 and PP.
  5. Mendel Leisk
    41,642
    Why are you disconnecting? If temporary, say for a battery replacement, there are memory-saver strategies, gizmos that provide voltage to the car while the battery is disconnected.
  6. MikeDee
    1,580
    597
    I did replace the battery and used a device using a 9v battery to maintain the presets. I originally asked the question because I wanted to charge the battery with the ground wire disconnected from the battery, as it says to do in the manual. I found that I can not fully charge the battery with an external charger with the battery connected to the vehicle.
  7. bisco
    52,092
    in another thread, i read that there is a drain on the battery, so the charger has to be powerful enough to overcome it or something, i forget the exact details.
  8. Mendel Leisk
    41,642
    I’m constantly doing that.
  9. BiomedO1
    3,786
    1,971
    SacTown, Ca
    That's correct; you can only get the battery to about 90-95%. IMHO; that's good enough. If you install an automatic maintenance charger; make sure it outputs at least 2 amps. As stated by Bisco; you must overcome the constant drains of the cars appliances - that are running in the background (ie. Entune, key scan, self diagnostic, clock and timers).
    I hook-up a charger on mine for a few hours every quarter; while I'm doing yard work. The battery is usually around 11.8 - 12.3 VDC, when I hook it up. When I unhook, it reads 12.8 - but I'm sure it's actually 12.6 or lower.
  10. Bootney Lee Farnsworth
    Bootney Lee Farnsworth Junior Member
    Ladera Ranch, CA
    I have the same question as MikeDee... I want to charge the battery with an automatic maintenance charger (I have an adjustable Schumacher charger that will charge up to 15 amps).
    @Mendel Leisk and @BiomedO: Do you charge the battery in the vehicle, with the ground wire still connected? Or do you disconnect it (as the manual says to do)? I've charged other vehicles, like our Honda Odyssey with the ground wire connected with no problems, but of course, it's not a hybrid/plug-in hybrid.
    Thanks in advance!
  11. bisco
    52,092
    yes, you can charge it with ground connected. a few have reported trouble charging because the car is pulling current at the same time. but with a proper charger, it should work fine.
  12. Bootney Lee Farnsworth
    Ladera Ranch, CA
    Thanks @bisco - I checked some other posts here about 12V battery issues and saw that many others were using external battery chargers / maintainers, and NO ONE wrote "make sure you disconnect the negative/ground wire!!!"
    I'm guessing that the manual says to disconnect the ground wire when using an external charger to cover their a$$es in case someone uses a faulty or really old-school manual charger.
    I also just ordered a BM2 Bluetooth battery monitor today to keep a constant eye on the battery voltage. I've had other cars with batteries that went bad really quickly, only to leave me stranded (or at least having to call AAA to bail me out).
    Thanks again; I'm hooking up that external charger now!
  13. Mendel Leisk
    41,642
    That, pretty much constantly.
  14. ChapmanF
    18,316
    Some chargers try to be very smart, and detect how the battery charge is progressing by noticing small changes in the current-to-voltage relationship as a battery gets toward full charge.
    Those chargers can have their fancy judgment thrown off by being connected to the battery in the car, so the charger is not just charging the battery, it's also powering all the ECU memories and smart-key transponders and all the other powered-when-OFF stuff in the car. It'll probably still charge the battery, but its smart behavior could be somewhat off. An old-school dumb charger will just go ahead and do what it was going to do anyway.
    If you're using a fancy charger and if you really want what it tells you about the battery condition to be accurate, for that you might want the battery isolated.
  15. Bootney Lee Farnsworth
    Ladera Ranch, CA
    @ChapmanF Thanks for the additional info. I just installed a BM2 bluetooth battery monitor, so even though the PP is drawing power for for all the electronics (while the car is "off" / not in READY mode), I think the monitor will give a pretty good data about the battery's condition.
    I'm coming up on 2 years of owning the car (and a lot of miles!) so let's see how the OEM battery holds up.
  16. MikeDee
    1,580
    597
    I have a CTEK (56-864) MUS4.3 battery charger. My car recently sat for 10 days unused (EVSE unplugged). I charged the battery with the charger, thinking it was a tad low. I didn't disconnect the battery from the car. It took over 24 hrs. to go through all 7 stages on the charger (good thing I wasn't in a hurry). That seems rediculously long, but maybe normal with this charger. I'm thinking it would have gone much faster if I had disconnected the ground wire from the battery. The battery is maybe a year old and should be in very good shape. I've got a Schumacher smart charger too, and it charged my Tacoma way faster than the Ctek.
  17. bisco
    52,092
    how many amps is the ctek?
  18. MikeDee
    1,580
    597
    4.3 amps
    iPhone ? Pro
  19. bisco
    52,092
    that is a long time. will be worth trying it with the neg disconnected next time the car sits that long
  20. Mendel Leisk
    41,642
    If it took 24 hours probably because the battery is deteriorating. I use the same charger; it’s usually complete in 4~5 hours. Have the battery assessed with an electronic load tester, typically for free at some battery retailers, or DIY with something like Solar BA9.
