Grinding noise from transmission?
Discussion in 'Gen 2 Prius Main Forum' started by PriusHead05, Apr 19, 2023.
  1. PriusHead05
    PriusHead05 Member
    318
    2005 with 239k mi. Original everything except hybrid battery. Battery is a Green Bean. Started making a grinding noise almost like a stuck caliper. It's coming from the front only on one side. I can't remember which side he said as it's my friend's. He said that it goes away at higher speeds, and doesn't change in volume or sound when turning back and forth. When it does go away, a tap on the brakes brings it back. He said he started working on it and it's not a stuck caliper. He's thinking transmission. Any thoughts or advice?
  2. Aegean
    Aegean Active Member
    464
    208
    Alexandria VA
    I have heard people describing a similar issue with one of the calipers binding and it was a faulty brake actuator. I hope not because it is an expensive part and a difficult DIY replacement. Are there any codes?
  3. Leadfoot J. McCoalroller
    8,133
    7,632
    Pennsylvania
    2018 Prius c
    Brake or wheel bearing.
