Just purchased a Prime!!
Discussion in 'Prime Main Forum (2017-2022)' started by FlyMode, Apr 22, 2023.
  1. FlyMode
    FlyMode Junior Member
    GTA
    2018 Prius Prime
    Hey guys.
    Newbie here just purchased a 2018 Prius prime! Super excited for the savings and reliability. Coming from years of street bikes and modified cars. It's nice to daily something that I can trust for once.
    Never thought I'd be in a Prius but hey! Really love the car.
    Just curious as to what the best option for highway driving is? 401 East to West. HV mode, EV auto or just leave it in EV mode?
    MitchA, CBerg, douglasjre and 4 others like this.
  2. drash
    drash Senior Member
    2,477
    1,252
    Upstate NY
    Congrats!! (y) Sounds like it would be EV Auto for you. The engine doesn't come on unless you really press it down but delivers a bump in pickup. Depends on how long your highway part is. If it's really long stick with HV. Great car to experiment with and you'll figure it out as it responds quite well.
    FlyMode likes this.
  3. FlyMode
    GTA
    2018 Prius Prime
    Thanks for the reply! Super excited!! Read a bunch of posts on here and most people seem to say just leave it on normal mode and EV auto until the Hybrid engine kicks in and recharges the battery once it's dead! And the car will just do it's thing. I'll tinker around and see what's best
    douglasjre likes this.
  4. Louis19
    Louis19 Active Member
    379
    338
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Congrats ......Prius Prime is a fascinating and addictive car,:ROFLMAO:....when I travel on a highway for more than a few km, I switch the car to HV , that way the traction battery keeps it's charge . ...just drive it and enjoy.
    BTW pushing and holding the HV/EV button for a few seconds , initiates the Charge mode up to 80 SOC.if you need a quick charge on the road
    #4 Louis19, Apr 23, 2023
    FlyMode likes this.
  5. ColoradoBoo
    ColoradoBoo Senior Member
    952
    626
    Monument, Colorado USA
    Congrats! She's 5-years old so will need a little maintenance to avoid any issues if they haven't been done. (Transmission and engine/traction battery coolant changes.)
    Any whether normal, hybrid, or prime, oil changes every 6-months or 5,000 miles. (We go with 3,000 for our non-Toyota cars)
    FlyMode and Louis19 like this.
  6. FlyMode
    GTA
    2018 Prius Prime
    What do you mean by charging? Hold it down as I'm driving and it will charge the EV battery? Will I lose mpg by charging it that way?
    I got it from a Toyota dealership and it went through a 150 point inspection, I'm wondering if they changed the fluids if not I'll totally have to look into it.
    Also can you or anyone else here reading this give me some advice/answer a question?
    I had the car charging on a 15amp 120v plug for about 5 hours and only got 22% charge on the EV battery. I'm going to test it tomorrow during the day on the 60a 240v charger at work. I don't have any charge schedule set up, just plugged it in and when I came back the green light was off and only 20 percent!
    #6 FlyMode, Apr 23, 2023
  7. Tideland Prius
    16,128
    Yes. The engine will be “forced” to charge the battery. Great if you need a quick top up to for inner city EV driving.
    Yes your mpg will suffer.
    douglasjre and FlyMode like this.
  8. FlyMode
    GTA
    2018 Prius Prime
    Ahhh okay, thank you for the reply. Im sure I'll find a fitting time to use this mode . Good to know I have it
  9. Louis19
    379
    338
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Just a simple question, did you read the owner' manual concerning how to charge the car , and verified the charging parameters.Are the settings at 8 amps or 12 amps ...this will influence the time it takes to charge the traction battery on 120Vac or 240Vac.
    usually for a 12 amp setting at 120 Vac it should take approx 5H 1/2 to fully charge and at 240V it should take half ot that time ruffly 2h1/4 to fully charge the traction battery.
    you can dowload the manual from toyota it is a PDF document for your model and your year .
    N.B. as I see it , your question about the Charge mode reveals that you overlooked the user manual :eek: but I think you where so excited with your new car, that you did not have time to take a look;)
    #9 Louis19, Apr 24, 2023
  10. Canby
    Canby Junior Member
    Burlington, On
    2018 Prius Prime
    I use EV when in the city and HV on the 400 series highways.
  11. CharlesH
    2,785
    1,152
    Roseville, CA
    Uses for "charge mode" are very limited. Most people never use it. Charging the battery with the gasoline engine is inherently inefficient due to the multiple conversion losses. These are laws of physics, not engineering issues. One of the few uses for it that can sometimes make sense is to generate some charge for use in stop-and-go city driving at the end of a long trip during which the battery has been drained, but even that can be tricky to sort out.
  12. Louis19
    379
    338
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    yes indeed , but if you need a quick charge and you want to burn some old gas left in your tank before it goes stale , charge mode is an interresting option;)
    Tightwad77 and Tideland Prius like this.
  13. FlyMode
    GTA
    2018 Prius Prime
    Yes I was super excited and was in GO GO mode I gapped big time. But after a few weeks of ownership I figured it all out and I'm finally now able to enjoy the car without a billion things running through my mind lol!!!
    I'm able to get from work and home on full electric, my idea with the charge mode is one day a week, I won't charge at home or work and just refill the battery through this method. As long as I can get through a tank in two months I think I should be fine lol!
    Louis19 likes this.
  14. Louis19
    379
    338
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Great , enjoy your new automobile .:) Capture d’écran 2023-05-03 181450.png
  15. tovli
    tovli 2023 Prius Prime replaced 09 Prius
    323
    247
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    Thanks for this. I tried to digest the Quick Start Guide, and the manual yesterday, but today when taking delivery with the car at SOC: ——-% (700 miles from home to get it!) I couldn’t remember this. On the long drive home in HV mode the deceleration and regenerative braking were clearly adding some but it never got above the little division in the battery meter.
    Louis19 likes this.
  16. PT Guy
    PT Guy Senior Member
    1,085
    710
    Washington, the state
    I'm with CharlesH in Post #11. Keep the car in EV mode and forget it. It'll take care of itself. That said, I have one hilly route that is more than battery range where EVAuto does run the gasoline engine up those hills and results in a slightly lower gas consumption for the full route. I've never found a use for recharging the battery from the engine nor switching to HV mode.
    We continue to disagree. All my vehicles get the oil changed as spec'ed in the owner's manual, and they've run fine for as long as 202,000 miles (Volvo turbo, 5k oil drain interval) without engine repairs and the camshaft gallery still visually clean. My Prime gets the oil changed at 10k, as specified, and that is NOT engine miles; we don't know the engine miles, but they aren't many. My Mazda turbo gets its oil changed as specified at 7,500, and I have every confidence that there will be no engine wear or sludge problems.
    Tightwad77 likes this.
  17. DukeofPrime
    DukeofPrime Member
    107
    77
    US
    You've probably figured this out by now, but what you describe is completely normal. It usually only goes above the line with charging or running in charge mode. Maybe on a long downhill run...
    tovli likes this.
  18. Zed Ruhlen
    Zed Ruhlen Active Member
    235
    129
    Hood River, OR
    2018 Prius Prime
    In my experience EV Auto is worse than useless. It will just stay on EV mode till the battery runs down and then switch to HV mode. Basically zero difference from just using EV mode. I've tested it multiple times and it's always the same. Super annoyingly the car will ALWAYS revert to EV mode on restart. Even if you are just stopping at a rest area on the highway. Get back in and forget to hit the HV button and the battery just runs down to HV mode. This has burned me multiple times.
    Tideland Prius and Louis19 like this.
