Anyone popped off the A Pillar trim?
Discussion in 'Gen 5 Prius Main Forum' started by theRob, Apr 17, 2023.
  1. theRob
    theRob Active Member
    103
    119
    2023 Prius
    Just picked up my XLE on Friday. Now I want to hardwire my dashcam and run the cables behind the airbag. I’m assuming it’s the similar to most Toyota vehicles? Stick your fingers in the crack and pull outwards? Like in this video.
    otatrant likes this.
  2. ChapmanF
    18,458
    Probably worth checking the repair manual if you really want to get it right the first time.
    Toyota Service Information and Where To Find It | PriusChat
    The little clips that keep it from being shot at you when the curtain airbag inflates are shown in that video as having some kind of squeeze release. From what I know of the Gen 3 Prius, there they have a rotate 90° release. I don't know if that's changed for Gen 5 or not.
    If you just assume it might be either, you can probably recognize which kind it is by the time you get that far.
    theRob likes this.
  3. JNemin
    JNemin Junior Member
    Washington
    2023 Prius
    Limited AWD-e
    Hi! You don't need to pop the A pillar trim - it's risky putting wires were airbags are located.
    Instead, pop the mirror surround trim, and tap into the plugs there. When I bought the Toyota integrated dash cam, you need to buy a "tap" harness that plugs into the black connector (there are three in that area, in addition white and a grey connectors). I believe it provides 5V because that harness includes two voltage regulators, but if your dashcam is 12V, can cut them out and you'll at least the tap that is needed for a clean install.
    thnok likes this.
  4. 2023p
    2023p Active Member
    161
    102
    Here
    2023 Prius
    Had it popped off for dashcam hardwire kit to fusebox via fuse tap for power. Simple, had the wire routed through/headliner and came out underneath the rearview mirror area plastic and it's unseen otherwise, plugs into dashcam. Tucked in along edge of that area
  5. theRob
    103
    119
    2023 Prius
    Are you able to demonstrate on how you popped off the A Pillar trim? Are you able to make a video? Please this would really help. Thanks I would really appreciate it.
  6. 2023p
    2023p Active Member
    161
    102
    Here
    2023 Prius
    Oh, I should have been clearer sorry. I had a tech do it. And it's done already. But I did see him by hand put it back in place. Not sure that's helpful
  7. thnok
    thnok Member
    122
    44
    2023 Prius
    Just checking, by memory was it in the plastic piece which is there around the rear view mirror? is that the spot where tech connected the cable?
