Red triangle and friends
Discussion in 'Gen 2 Prius Technical Discussion' started by GreenMeanie, Apr 24, 2023.
  1. GreenMeanie
    GreenMeanie Junior Member
    47
    Started up my 2006 with 99,810 miles today, and saw the red triangle plus several other warning lights. See attached photo. Extra beeping sound, and middle console screen has red car outline with exclamation mark. I'm seeing in the forum that this could be a number of things.
    Car is in my garage. I'm not clear on whether I can drive it or not. Considering whether to buy one of those little readers to figure out what's wrong, but would this one do the trick?
    Kinda freaked, as I've had a number of big expenses lately, and wasn't counting on a hybrid battery failure. Does anyone know:
    a) what the problem might be,
    b) whether I can drive it, and/or
    c) whether it's worth buying an OBDII to self-diagnose.
    Also, if I can't drive it, need to look into AAA to see if their towing service kicks in immediately after signing up...I don't have AAA because I drive a Prius. I knew I shouldn't have detailed it last week...
  2. ChapmanF
    18,412
    There are a couple hundred possibilities behind the red triangle, all with their own trouble codes to identify them, and there can be a comparable number behind the check-engine and brake system lights, though they also can be on simply because of the codes behind the triangle.
    That's why we read codes when the lights come on.
    Here is a thread that reviews some products for reading those codes and how well the different ones work:
    Gen2 OBD2 app review | PriusChat
  3. Tombukt2
    13,221
    2,390
    Inverter pump comes to mind first . The AM fuse or burnt plug at that pump . NO movement in inverter coolant jug etc . One of the first things I'll be checking before I even run back in to get the code reader It's that often the thing.
  4. pasadena_commut
    pasadena_commut Senior Member
    2,750
    821
    Southern California
    If it is the inverter pump, and it has not blown the fuse, then the car will start up and run normally after it cools off. No RTD. So the OP might be OK to drive it to a nearby mechanic, at low speed, and on a cool day.
  5. GreenMeanie
    47
    Thank you so much for your replies. I hadn't updated my email address, so wasn't notified of them, hence my delayed response.
    I already went ahead and bought the device that I pasted the link for in my original post. I got this screen, but don't really know what to make of it. It also says that this vehicle has no fault codes, so I think this thing is going to be going back to amazon.
    What it looks like I need to do instead is buy an adapter like OBDLink LX. I have already downloaded the Hybrid Assist app, based on the info in the link from ChapmanF. Does that sound like a good next move?
  6. GreenMeanie
    47
    Hang on...on the Amazon page for the OBDLink LX, it says it's not compatible with hybrids. What's up with that? It was specifically mentioned in the Gen2 OBD2 app review thread.
  7. The Beast1
    The Beast1 Junior Member
    France
    I own an obdlink lx Bluetooth scanner module that I bought separately for a BMW I own. Letting you know that the module works fine for the Gen 2 Prius. Im able to pull codes using a free obd app I downloaded from AndrOBD which can be downloaded from F-Droid. Don't bother with their included obd app. There are far better apps out there.
    The module also works with Dr Prius.
  8. GreenMeanie
    47
    Well, just to give some closure to this thread, here's what ended up happening. Had it towed to a garage that I trust, where they diagnosed the hybrid battery as going bad. It was completely drivable they said, although I would not get the gas mileage that I normally would get. They quoted me $2500 parts and labor for a reconditioned battery. I told them I wanted to think about it, and drove home. The hybrid battery charge showed things very erratic on the way home, two bars, followed by all green bars, etc.
    Did some research and found that reconditioned was not the way that I wanted to go, because I intend to keep the car and not sell anytime soon. Called a Toyota dealer and they had the new battery on the shelf at a cost of $1900. They said if they installed it, it has a 3-year warranty, but if I bought it and took it to a garage and had it installed there instead, it would be a one-year warranty. The dealer quoted me $3,600 for parts and labor. I called other dealerships for comparison and one came in at $3400 and one came in at $4,400(!). So I went with the one for $3,400 and will have a 3-year warranty.
    Sadly it was the hybrid battery, but at least it wasn't $10k to get it fixed like I was thinking it would be.
    Thanks to all for your help on this.
    AML and ColoradoCrow like this.
  9. John Krauchunas
    John Krauchunas Junior Member
    Chicago
    GreenMeanie, I just dealt with this myself tonight, Come to find out i have one bad block, I tested with my obd2 scanner with hybrid testing ablilty. it also gave me a p0a80 code which is the hybrid battery is bad. further research shown you can replace the block for about 40.00 dollars instead of replacing the whole battery. hope this helps
