Oil in the Intake Manifold
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Trospe, Apr 26, 2023.
  1. Trospe
    Trospe New Member
    Greece
    Hello guys. Today as I was cleaning the maf sensor and the throttle body I saw a pool of engine oil in the intake manifold. I had changed the pcv valve (with original OEM Toyota part) myself 40.000kms ago and the car has 171.000kms and runs quite fine(no problems). Should I worry about it and what should I do?
  2. ChapmanF
    18,071
    All the way back to the first generation, people have been observing that Prii have some gloop in the bottom of the intake manifold. It's what they do. Most people just keep driving the car.
  3. dolj
    dolj Senior Member
    8,428
    4,285
    Wellington, New Zealand
    ^^^ What he said. ^^^
    Nope and nothing.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    The function of the PCV "loop" is to suck oil fumes out of the crankcase and into the intake to be burned along with the fuel.
    Some of that instead condenses in the intake manifold.
    Whether it actually pools there or not is a function of the manifold design.......and maybe the engine type.
    With some different designs, that occurs inside the air filter housing.
    Many engines do that to some slight degree.
    Unless there is enough accumulating there that it might be sucked into the engine as a liquid, I wouldn't worry about it.
    Are you keeping an eye on the engine oil level ?
    Does it "use" much ??
  5. Mendel Leisk
    41,316
    The pool at bottom of intake manifold is just the oil vapour that managed to condense? Wonder if there's a way to determine how much doesn't condense, gets swept right through into the combustion chambers (contributing to stuck piston rings?), or coats the injectors and intake valves.
  6. sam spade 2
    7,035
    2,801
    2017 Prius c
    IF......it doesn't condense along the way, it BURNS up and is not a problem.
    Next wild idea.
  7. Mendel Leisk
    41,316
    Ah, the diesel input.
