Anybody else miss having a temperature gauge and tachometer?
Discussion in 'Gen 5 Prius Main Forum' started by Ronnie5, Apr 28, 2023.
  1. Ronnie5
    Ronnie5 Member
    49
    56
    2023 Prius
    I can’t believe there is no option to show a temperature gauge or tachometer. Last car I owned that didn’t have a temperature gauge was an old Volkswagen Bug.
    daisy555 and TGrracie like this.
  2. Leadfoot J. McCoalroller
    8,133
    7,630
    Pennsylvania
    2018 Prius c
    The Prius has never had either on its native displays. You can add both via a variety of phone apps or aftermarket gauge displays.
    TGrracie likes this.
  3. Mendel Leisk
    41,824
    Tach seems useless, but yes: confounding they don’t have an engine coolant temp gauge. :mad:
  4. rjparker
    10,411
    6,521
    I have temp and accurate mph. A tach is pretty useless as rpm is under hybrid control.
  5. bisco
    52,286
    years ago, someone retro'd analog gauges, they looked pretty cool
  6. ChapmanF
    18,457
  7. Ronnie5
    Ronnie5 Member
    49
    56
    2023 Prius
    Toyota put a tach and temperature gauge on the new corolla cross hybrid.
  8. Vneck
    Vneck New Member
    Kent, WA
    is that what you are looking for?
  9. CooCooCaChoo
    CooCooCaChoo Senior Member
    961
    542
    Cow-lee-fornia
    2023 Prius
    I think he means a coolant temperature gauge.
  10. Trollbait
    12,653
    Likely because it uses the same dash as the ICE model.
    He's asking for a coolant temp gauge.
  11. Ronnie5
    Ronnie5 Member
    49
    56
    2023 Prius
    Corolla Cross Hybrid…
    Sarge, samsprius1 and Mendel Leisk like this.
  12. CR94
    CR94 Senior Member
    2,737
    1,196
    Northwestern S.C.
    Right that engine speed is "under hybrid control," but I can't agree that "a tach is pretty useless." I want to know what's happening with engine speed, just as I would with any other kind of transmission.
    A few years ago, someone posted how to connect a conventional analog tachometer to function in a 2nd-generation Prius.
    I have RPM and coolant temperature shown on my ScanGauge most of the time.
  13. ChapmanF
    18,457
    Hey! I want an artificial horizon on my dash!
    Trollbait likes this.
  14. Mendel Leisk
    41,824
    I recall driving Daughter-In-Law's Sunfire over to Costco one time, muttering "even this sh*t-box has a temp gauge".
    samsprius1 likes this.
  15. Trollbait
    12,653
    Most drivers don't need to know this and dash space is limited. For those that do, there is now easy after market solutions.
    The temperature gauges in many cars are no better than the warning light the Prius has. They have increments, but really only show cold, warm, too hot. Really just the warning light in gauge form
    It's on the central screen, but my Subaru has an approach angle diagram.
    #15 Trollbait, Apr 29, 2023
  16. Ronnie5
    Ronnie5 Member
    49
    56
    2023 Prius
    I mostly like to see how fast my engine is coming up to temperature.
  17. samsprius1
    samsprius1 Active Member
    720
    182
    2023 Prius
    Limited AWD-e
    Tach No, coolant temp Yes.
  18. Leadfoot J. McCoalroller
    8,133
    7,630
    Pennsylvania
    2018 Prius c
    I'm really okay with the reduced instrumentation in the Prius. Heck, 99% of the time when we drive it we have the dash set to the "simple" display: clock, fuel gauge, odo & speedo.
    daisy555 likes this.
  19. andyg
    andyg Member
    25
    I have a ScanguageII mounted on my 2008 Prius that I set to show coolant temp and SOC. When I get my Prime, I hope I can use my Scaguage with it also.
    Sarge likes this.
  20. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,497
    2,482
    Taylors, SC
    On a Prius, a tachometer is useless.
    Engine coolant, inverter coolant and HV battery coolant, however, is something I need to monitor continuously. 12 volt battery temperature is also most important.
    The four are easily and best monitored with my Scangauge 2.
    andyg and Roqu3 like this.
