How about a "security" Prius v shifter?
Discussion in 'Prius v Accessories and Modifications' started by Georgina Rudkus, Apr 30, 2023.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,513
    2,503
    Taylors, SC
    My dad's friend, a retired aerospace industry machinist and engineer has come up with this removable shift knob shifter for extra security. If you cannot put the car into drive, you cannot move it and drive it away.
    prius16 likes this.
  2. ChapmanF
    18,585
    Is there something in the design I'm not seeing that would make that harder to shift without the knob than I'm thinking?
  3. prius16
    prius16 Active Member
    462
    246
    New England
    2022 Prius Prime
    If you look at the first picture, the stud that the shift knob screws into has been cut down, such that the stud is now below the bezel.
    For OEM, the stud rises ~1"-3" above the bezel, and the shift knob screws on to the stud.
    Georgina Rudkus likes this.
  4. bisco
    52,414
    i guess i'm lucky to live in a prius crime free zone
  5. ChapmanF
    18,585
    Does even the cut-down stud look as if it would stop anyone from shifting who had a pencil, drinking straw, skinny fingers, or a house key?
  6. Georgina Rudkus
    3,513
    2,503
    Taylors, SC
    Neither of these things will strong enough to overcome the spring forces that need to be overcome to shift the car.
    It is unlikely that the thief would carry an M6x1.0 threaded tube that is 8mm or less in the outer diameter.
    He has updated the shifter to include two emergency shifter "keys" that the legitimate drivers can still drive the car even if the shift knob is misplaced.
    #6 Georgina Rudkus, Apr 30, 2023
  7. ChapmanF
    18,585
    I just walked out to my Gen 3 and shifted into every position using my pinky finger on the very base of the shifter stud.
    Then I did it again from a worse angle with the pinky of my non-dominant hand. Reverse was tricky at that angle but I got there.
    Are the shifter springs on Gen 2 that much stiffer than on Gen 3?
  8. Georgina Rudkus
    3,513
    2,503
    Taylors, SC
    That's got to be one super strong and thin finger, Chap.
  9. ChapmanF
    18,585
    That's just the thing. I make no extraordinary claims about my pinky fingers whatever.
    Maybe there's enough changed between the Gen 3 and Gen 2 shifters to make a difference?
    Air_Boss likes this.
  10. Georgina Rudkus
    3,513
    2,503
    Taylors, SC
    Jadem das seine
