Its time for a rebuild.
Discussion in 'Gen 3 Prius Main Forum' started by -JnC-, Mar 1, 2023.
  1. -JnC-
    -JnC- Member
    Bedford, MA
    Much better, this block will be paired with the clean parts from the first engine I opened on page 1, that will include side cover, camshaft holder head piece and valve cover. The only part that will be used from my old engine (the dirty one) will be the head, head is getting dropped off with the machine shop once I get the valve seals order in as they will do all the cleaning and installation.
    I placed the order for everything yesterday, parts prices have gone up again.
    Ordered a new ring compressor tool as the old one was a pain to use.
    - Mopar gasket maker (2).
    - Head bolts.
    - Fel-pro head gasket.
    - Crankshaft main seals (both sides).
    - Block dowel/positioning pin (needed 1).
    - Oil filter attachment O-rings (2).
    - Rod bearing set (4).
    - Crankshaft bearings sets (5).
    - Timing chain tensioner.
    - Updated pistons (4).
    - Ring set.
    - Thermostat.
    Toyota parts total $830.
    Other parts $116.
    Machine shop quote is $100 for skimming the head, check valve clearance/sealing capacity and install valve seals. Aforementioned plus deep clean (media blast the intake/exhaust ports), clean and reinstall valve springs etc $175.
    C039751C-C81E-419C-A450-3A1951CE9169.jpeg BBA0DA42-DCC8-4A99-AF08-D7899D6EA586.jpeg 8A78CE8F-69DE-4862-BDF4-79C50F993AC7.jpeg
    #101 -JnC-, Apr 26, 2023
    Lost-hybrid likes this.
  2. peteandbeans
    peteandbeans New Member
    NC
    There is an evil bolt on the underside of the radiator tube connected to the transmission I got it out but gave up tryna get it back in when all was said and done
  3. -JnC-
    -JnC- Member
    Bedford, MA
    Once the radiator hose is off from that pipe (going to the radiator) access to that bolt is easy with a swivel extension or swivel socket.
  4. -JnC-
    -JnC- Member
    Bedford, MA
    Bottom end is done, waiting on getting the head done from the machine shop, it should be together this week.
    0CB2CBE8-34B4-427A-BA73-92B7E9911888.jpeg FFFA3D91-AE5B-4623-B528-8B4672F43CD6.jpeg 21BF7FB8-30D7-45A3-B275-DF9A9C55B1A5.jpeg 1FCB9D90-E183-417E-8D08-29074692B1E9.jpeg EF018E4C-407F-4B22-A6BF-D57A803A492A.jpeg 0B129627-88C9-40D3-A5DE-4D9EA239085A.jpeg E7AF3973-1A65-4BB0-869F-7476224910DE.jpeg 64D0B0A5-52FF-47EA-A101-B77A0878489C.jpeg 1DECDCCC-AB27-44CA-AE96-0D7F01055B94.jpeg 4DD4F121-4D66-405B-B0EE-EAE15D4FA711.jpeg 04F5C867-3347-4D78-8217-49F67FD40C7D.jpeg AB83750D-1648-49D8-995C-DF677164A569.jpeg 64260D0B-5FE0-4941-ACE2-825F43302F23.jpeg ED4E1E47-631B-43AE-9FE9-0F42AEAD13F8.jpeg 4271FC7B-0696-42EE-83FF-C57C6A0964EA.jpeg 0EE1B861-AC2D-4168-9C45-BA12A75DFEEB.jpeg 517B024A-DD26-481B-9A63-2922945AF96F.jpeg A97DC55A-4321-429D-B688-D4AF3227B6B4.jpeg 72707A97-69F0-457E-9BA6-7D158DFA9286.jpeg
  5. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    462
    Leawood, KS
    I
    I got your name. "Wicked Prius Pit"
    -JnC- likes this.
  6. -JnC-
    -JnC- Member
    Bedford, MA
    Waiting on sealant to come in as I ran out, side cover to go on once it’s here. Note to self and others, better to install oil pump chain when the head is not on, to align the timing marks on the pump and sprocket when the head is on is tedious. I didn’t want to rotate the pistons etc to get it into alignment as the head and it’s components were not timed with the crankshaft. It took a while but I was able to overcome this hurdle.
    6158D679-3EEC-4116-B81F-71A6EDAAF800.jpeg 2EC6B7E7-9BF8-4A48-B60A-5F014BBB0AF8.jpeg A4EE0E23-6476-4B02-887F-1278030CE84E.jpeg FF731ED4-9EAD-4B33-9A70-C01B283B2BF1.jpeg 81FF3BB3-17DB-4D7C-83BA-412E840882BB.jpeg 8009DBF1-23B6-4AAF-A0FF-AAEECEEB690B.jpeg 7DD93023-A549-4CDB-9E40-22DF092B32D3.jpeg 2D2A41F0-8DB3-457C-A677-AB8ACF46F4CD.jpeg 68E6BBA9-1D16-4987-9F76-DD2C43DF7552.jpeg BCA36B38-4B94-47FE-B5E9-59347A96ABD8.jpeg 9FA90FE2-FAFC-4C97-BAA3-BEA2F89F9F46.jpeg
    don K otay, bdc101, RachaelH and 3 others like this.
  7. Bill Norton
    Bill Norton Senior Member
    2,143
    734
    MONW, Ks.
    Yay! FelPro head gasket!
    That's a very good choice!
    V Sport Wagon and -JnC- like this.
  8. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    How about "The Boston Builder" ?
    RachaelH likes this.
  9. -JnC-
    -JnC- Member
    Bedford, MA
    6 Month update, prius 1 (mine) has clocked around 15k on the new motor, runs perfect, no oil consumption or death rattle any more.
    Prius 2 finally got finished a couple of months ago as I didnt get much time over the summer to do the swap and there was no hurry either, this one has clocked 2k miles so far and all seems to be well. I did get a CEL come on for purge valve for the gas tank, turned out to be the purge valve bolted to the air intake, I had just forgotten to plug the harness plug to it, once that was plugged back in the CEL went away on its own.
    CR94, ASRDogman and bdc101 like this.
  10. BrianStranded
    BrianStranded Member
    118
    84
    New Orleans, LA
    Nice work, I’m about to tackle this task as well using your thread, wish me luck!
  11. Prius V 301
    Prius V 301 Junior Member
    Silver Spring MD
    2013 Prius v wagon
    Just wondering if you reused the old timing chain components?
  12. Chris Duryea
    Chris Duryea New Member
    Alabama
    Does anyone have this repair manual to share? Should be "2ZR-FXE Engine Mechanical Cylinder Block: Reassembly"
  13. ASRDogman
    ASRDogman Senior Member
    7,540
    3,893
    Did you fix yours yet?
  14. -JnC-
    -JnC- Member
    Bedford, MA
    First page of this thread should have the links to both disassembly/removal etc.
  15. Mendel Leisk
    41,305
    Last link in my signature is full engine section, should have whatever’s needed. On a phone turn it landscape to see signature.
    BTW, attachments are working again. :)
  16. DieselHammer
    DieselHammer Junior Member
    29
    Kansas
    Why replace rings if within tolerance?
  17. Mendel Leisk
    41,305
    Toyota, likely to eke out a few extra tenths of a mpg, chose Gen 3 piston rings that had low springiness, often referred to as “low-tension”. This, plus the piston design, is the likely culprit in oil consumption that starts somewhere after 100k miles, and often gets out of control.
    partway through model year 2014, they revised the rings, and pistons. There’s no real explanation as to why, but there’s a TSB for excessive oil consumption (greater than one quart in 1100~1300 miles IIRC), and the fix involves swapping to the revised pistons and rings. The new rings will not fit in the old pistons, and that “may” be the only reason pistons are revised as well.
    Toyota has not been forthcoming, apart from that TSB. Clever clogs, they offer to replace rings/pisons, but only if car is under 60k miles.
    If you look at 3rd Gen mpg stats on Fuelly, there’s a slight but distinct dip in model year 2015. Runaway oil consumption is the price earlier year owners pay for the extra tenths of one mpg.
  18. TNToy
    TNToy Member
    70
    Memphis TN
    The maker of this video is a Master Diagnostic / Hybrid Tech with Toyota. He is also an EXTREMELY good teacher.
    This explains it far better than any thread about this motor ever will…
    As a Master tech for Toyota from 2006-10, I can vouch for the content of this video. I don’t want to guess how many of these motors I did pistons/rings in under warranty. Then they went and did the same horrible thing to the Prius…
    (There’s very little difference between the motor in that video and what is found under the hood of a 3rd gen prius. The video’s content certainly applies.)
  19. ChapmanF
    18,065
    While you were in there, did you see anything that explained why there are timing marks for an oil pump?
