don't wanna dump it but.....
Discussion in 'Gen 2 Prius Main Forum' started by misterdean, Apr 30, 2023.
  1. misterdean
    misterdean Member
    204
    28
    FL
    had it for around 10 years. it's been the best car i've ever had. but i've been having some problems with it that have me thinking about dumping it. about 8 months ago a bunch of service lights came on while i was driving. engine, slip warning, ABS, VSC, brake, master warning, etc. it drove fine but once i turned it off it would not turn back on. i disconnected the battery and it started right up. no lights. drove fine. a few weeks later the dash wasn't on. nothing at all. car drove fine. i posted here and the suggestions were check the battery and clean the terminals. it tested good, i charged it, and cleaned the terminals. been driving fine for like 7 months.
    today the dash was out again. drove fine. got home and i couldn't turn the car off. power button did nothing. pulled the battery but car was still on. kept pressing the power button and eventually it turned off. connected the battery again and started right up. dash working. no service lights. drives fine. not sure what to do. if i bring it to the mechanic it is likely they will look at the car and not be able to tell me what's wrong with it cause it will be working as expected and there won't be any service lights on. i can see the hourly rate adding up quickly looking for a problem that took 7 months and hundreds of miles before it appeared again. hybrid battery seems healthy cause getting 48-49 mpg. really really hoping you guys can help me figure this out.
    #1 misterdean, Apr 30, 2023
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,052
    1,977
    NJ-USA
    What you are describing right now is a common problem on a Gen2 Prius - a bad capacitor on the Combination Meter (speedometer cluster) circuit board.
    When it fails the CM won't properly "boot up", which mucks with the power button function (can't turn the car on or off like normal).
    If you have (or know someone with) good soldering skills, then repair is take the dash apart to pull the CM and replace some caps.
    Otherwise you can pull the CM and ship it to texas-hybrid-batteries for repair (or buy an exchange unit).
  3. Tombukt2
    13,065
    2,341
    I drove like this for 2 years You hold the button down 20 seconds or so the car shuts off problem is is when you turn the car on and you have no dash you don't know the car's ready and ready to go luckily for me I had a check engine light with the PO420 code for the whole time I've on the car that was the way I would tell my car was on and ready because the check engine light would be glowing orange and I just pulled it in the drive and drive away then during the day at random I would turn the car on to leave a service call the dash would come back on and be on for weeks and then all of a sudden one day I'd push the button and the dash would be off for a couple hours come on midday this went on like I say for 2 years so I would always make sure I knew where my gas was when I shut the car off so when I came out in the morning and started and had no dash I know I had a half a tank last night so I'm good for 230 mi or so or whatever the case may be usually by the time it was time to get gas or before the dash would come back on and if I didn't do any resetting procedures like unplugging batteries and all that My gas gauge would return and show correct - what I had used while the dash was off and running service calls it was really easy to know where I was at pretty much so I didn't worry about it. Now I've changed the dash to a known working unit from a little old ladies car that had 90,000 mi on it and still sometimes when I boot the car up I get no dash display and it does not seem like bad capacitors or the display is failing to me It seems there's something further up or back in the chain that's not happening and not allowing the display to boot That's what I believe I'm seeing. I want to buy the Texas hybrid rebuilt doodad heads up display whatever but I'm sure once I do that and I install it every so often my display's not going to light anyway there's something else going on I just haven't had the time or the will to fool with it because it's nothing permanent not in my case.
  4. Tombukt2
    13,065
    2,341
    You're not anywhere close to dumping the car yet You've got a long time to go or maybe you don't and you just need to get rid of it because you're afraid of what you're not seeing I don't know.
  5. misterdean
    misterdean Member
    204
    28
    FL
    assuming this is the part? i see them on ebay $75 used $100 refurb and $50 for repair service.
    i don't want to dump it. it's been good to me. it just hit 125K and i still see 50+ mpg sometimes. this is the first problem i've had with it. but it already got me stranded once. no dash is bad enough not turning off might drain the hybrid battery. how else can i turn off if it doesn't cooperate? i read pulling fuses. hearing you replaced yours and it's still acting up is concerning. i noticed some listings are saying i need to program it. is that something i can do?
    #5 misterdean, May 1, 2023
  6. pasadena_commut
    pasadena_commut Senior Member
    2,678
    797
    Southern California
    Your odometer info is on that component. If you put in a random board then your car will show the odometer info from the donor car. The repair service will return your repaired board with the correct (unaltered) odometer reading. Not sure about your state, but here in CA the DMV is not happy with cars having inaccurate odometers. As I recall there are a bunch of extra hoops that one must jump through to sell a car like that.
  7. The Beast1
    The Beast1 Junior Member
    France
    I just bought a used gen 2 from a dealer that came with a 1 month warranty. Had the combo meter go out which caused the dash to not turn on and the car to turn off. Thankfully, I was able to get the dealer to do the work for free. Came to $1,000 with SoCal prices.
    If I didn't have a warranty, I would pull the combo meter myself and just send it to these guys: texashybridbatteries dooty com
    Replace the dooty with a full stop (period). I'm too junior to post links yet.
    $150 is astoundingly cheap for a properly programmed combo meter.
  8. misterdean
    misterdean Member
    204
    28
    FL
    how do i turn this car off if holding the power button does not work?
  9. Texas Hybrid Batteries
    Texas Hybrid Batteries Senior Member
    271
    563
    Dallas -Fort Worth
    Nope. You just put in another meter that has the same problem. We've sold over 5,000 of these displays and anytime a Gen 2 Prius is having interment dash lights it's 100% a combo meter failure. If you go looking for another problem you will just make more work for yourself.
    ColoradoCrow and Prius Rising like this.
  10. Texas Hybrid Batteries
    271
    563
    Dallas -Fort Worth
    You definitely don't want to dump the car over this. It's probably one the cheapest (and easiest) things to fix on a Gen 2 Prius.
    When the car won't turn off you have to hold the power button down for 5-10 seconds and the car will go into accessory mode (only the MFD will be on). Once that happens press the power button two times quickly and the car will fully power off. Without the main display working it may be hard to tell when the car has switched to accessory mode but if you listen there will be a few clicks in the back of the car (those are the main battery relays opening), once you hear those clicks that's your cue to double press the power button to shut everything off.
    If you are ordering a replacement combination meter it will need to be programed or the odometer will not match. Sometimes there are ebay listings that tell you what the mileage is on the meter and you could get lucky and find one that's close. In most cases those are straight out of wrecked cars and could have the same problem as the one you're replacing (like in Tom's case). All of the replacement meters that we ship out are pre programmed to the exact odometer value requested.
    PM me if you have any questions.
    Matt
    Gearhead52 likes this.
  11. Tombukt2
    13,065
    2,341
    Yeh I have 4 of them too all out of old lady low mileage vehicles and one or two with over 200 on them and they all act same eerily exactly same
  12. misterdean
    misterdean Member
    204
    28
    FL
    hey matt,
    i've been looking at your site. i've also been talking to my buddy. he was a contractor for the military. he worked on jets and helicopters. he can take my whole car apart and put it back together. but he doesn't want this job. he sent me a youtube walkthrough of the whole process. he said it will be a pain in the balls. i also watched the video. when i saw them taking out the center console and the trim by the doors i also agreed it was going to be a pain in the balls. i told him about you for $250/$125. he laughed and told me he would rather drive to texas from tampa than do this job for $250/$125. he questions why you are doing it for that. we are also debating how long this is going to take. i've read people saying 2-3 hours. he thinks 6 hours. i know you can probably knock it out quick, but how long do you think it will take us not knowing the process and having to watch a video to guide us through it? i'm gonna guess 4 hours. some of these guys on ebay give a partial refund/credit if i send them my old meter. do you do anything like that?
    cheers!!!
  13. Texas Hybrid Batteries
    271
    563
    Dallas -Fort Worth
    We install these almost everyday at my shop. I’ve had days that I put in 4 or 5 in row and it takes 30-45 minutes each. We just don’t believe in ripping people off like the dealership. $125 for 45 minutes of work is more than fair I think.
    The majority of customer feedback we get from people doing their own installs is that it took 2-3 hours and it was a lot easier than they expected it to be. If your buddy can work a helicopter this should be a walk in the park.
  14. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    @misterdean
    Matt helped me with a combo meter repair job I did a while back. He's the real deal. The job is not complicated, the important thing is that you want to do it once, so make sure the replacement CM is right. I did my swap in about 2 hours, including beer.
  15. Texas Hybrid Batteries
    271
    563
    Dallas -Fort Worth
    Yes, all of the orders that we take include a $75 core deposit. We provide a pre paid return label to send the old meter back. Once we receive it that $75 gets refunded to you.
  16. misterdean
    misterdean Member
    204
    28
    FL
    he definitely can do it. he just don't want to. i think he would rather burn $250 than do this job for $250. he seems super concerned about breaking parts clips etc. he is actually more interested in helping ME do it vs him doing it for me. he thinks it will be amusing to watch me do it. i will relay what you said about your price and the time involved for both you and regular folks. appreciate the info.
    #16 misterdean, May 3, 2023
  17. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    The dash vent piece that has the shifter opening is often very brittle and may crack. Replacements are available on Amazon for about $30.
    I keep 2 in the garage.
  18. mr_guy_mann
    4,052
    1,977
    NJ-USA
    It's a bunch of tedious work. As mentioned, the center dash vents can/will break (oh well). Not breaking the clips at the tops of the A pillar trim pieces is super annoying.
    Otherwise you follow the service manual procedure and try not to forget any screws or connectors when going back together. It helps to take pics during each step of the disassembly process.
