Replaced with cylindrical cells: 68.8MPG
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by DirkAshburn, Apr 30, 2023.
  1. rjparker
    10,581
    6,637
    The v dashboard
  2. Mendel Leisk
    41,951
    Any dash mpg readings are likely ~7% optimistic, if Toyota's running true-to-form.
  3. CR94
    CR94 Senior Member
    2,761
    1,210
    Northwestern S.C.
    That must vary with the car. I get ~4.5% very consistently
  4. Paladain55
    Paladain55 Active Member
    410
    169
    The South
    He also drained the piss out of the battery to two bars and probably rode around and stomped the brakes before he started testing. This testing doesn't really mean anything. Like when I do that i just get awful gas mileage the next short trip that is similar to it and it ends up balancing out. lol
    If he said "Well, after 1000 miles of testing, we got 68.8mpg" I would be like goddamn...
    I wanna see someone give us a capacitor battery with a 60w capacity that we could stick inbetween the hv battery and the inverter. That would be neat for capturing 90% of the energy captures and releases I get on my daily drives.
  5. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    I play 4D chess like Elon musk play against fake news on checkers sucka!!!
  6. DirkAshburn
    DirkAshburn Member
    158
    65
    Virginia
    Another video reviewing the cylindrical pack for those interested. This is a much longer detailed test. He was getting 39mpg with old battery, now after 1,798 mixed miles getting 44.7 mpg.
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    I don't understand why this is something to brag about. If he was getting 39mpg, there is something wrong with his car, other than the HV battery.
    Heck, I can't remember the last time I had a tank of gas that was less than 48 when driving like I stole it, and in the 53-55 range when driving more conservative..
  8. DirkAshburn
    DirkAshburn Member
    158
    65
    Virginia
    He's not bragging about it, he even breaks down the costs near the end of the video and stated he would most likely go with a refurbished battery instead.
  9. Skwekel
    Skwekel Junior Member
    Hey Dirk, did you end up installing the Cylindrical cell battery in your vehicle? I'm trying to decide if I should go this route or the Sodium ion route.
  10. DirkAshburn
    DirkAshburn Member
    158
    65
    Virginia
    No, still consistent ~38 mpg on current battery. I had thought a lot about replacing it before it fails, but now I'm more opted to wait it out until it throws the death code. For which one, after finally getting some time looking into the sodium more and reading all the threads it won't be that. Probably cylindrical, maybe just a refurbished oem. Just need it to last a few years until I can save up enough for the replacement - most likely an HR-V.
  11. ASRDogman
    ASRDogman Senior Member
    7,844
    3,997
    Sodium IS the way to go. Unless you want to be cheap and pass on the problem to the
    poor sole who buys it...
    Skwekel likes this.
