Changing 2015 Prius Transmission Fluid
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mhdriver, May 1, 2023.
  1. mhdriver
    mhdriver Member
    162
    61
    florida
    Hi. Everyone. I've got a Prius (Trim 5) with about 170k miles on it. No idea if the transmission fluid was ever changed. It seems easy enough, but my problem is filling it properly because I don't have a lift. So when I service it, it's up at the front end because I drive up on a ramp. I could get the plugs out (fill plug first), drain it and then put the drain plug back in. But without getting it level, can I refill it properly?
    Also, is there anything else to do with the transmission for maintenance? Since it is a front wheel drive, there is no differential. Thanks to all who reply!
    52,417
    you can't even drain it properly. you have to get it up and level on tripods.
    there is no other maintenance
  3. ASRDogman
    ASRDogman Senior Member
    7,844
    3,997
    You can use jack stands in the rear. That's what I do.
    Ramps in the front and jack stands in the rear.
    You won't be able to drain it properly if it's not level.
    Once it's level, and you drain it. You can use a funnel and long hose
    to run down to the filler hole. File SLOWLY, it will take 3.5 - 4qts.
    Once you're at 3.5, you can pull the hose out and see if fluid drains out
    of the filler hole. If not, add a little more (?pint?), then check again.
    Drain and refill is all you need to do. Use the Toyota fluid. It is the best thing for it.
  4. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    The car must be level when you drain and refill.
    Before you drain, open the fill plug first. You don’t want to drain and then discover that the fill plug is stripped or seized. We have a big box of leftover pee pads from when our dog was a puppy. They are fantastic for putting on the floor when you’re doing a fluid change. Highly absorbent. Recommend you buy a Mityvac fluid extractor for filling the fluid. The little $28 hand held one will do although the $100 floor mount one is even better, especially if you have an assistant pump while you watch the fill from underneath the car.
    Use painter’s tape to attach a bubble level to the door. You put some tape on the door, put the level on the tape so it won’t scratch, then tape the level to the door. This way, you’ll know that you have the car level when the rear is jacked up.
    Be certain that the car is firmly raised and secure. Shove it to make sure it won’t come off the stands. I like to remove all four tires and stack two beneath each side of the car, so if the jack stands fail I’ll still be safe.
  5. SB6
    SB6 Member
    324
    71
    No other maintenance related to transmission that I know of, but if you're planning on doing anything that involves removing the CV shafts, now's probably a good time. If I'm not mistaken, on this car, removing a CV shaft will drain some transmission fluid
  6. CR94
    CR94 Senior Member
    2,761
    1,210
    Northwestern S.C.
    If you have a suitable slight hill available, you can get the car adequately level by draining with the rear of the car higher up on the hill, and the front wheels on ramps. That's how I did it.
    My manual says the capacity is 3.6 quarts.
  7. mhdriver
    mhdriver Member
    162
    61
    florida
    Looks a lot easier on a lift in the Youtube channels. I think I'll call a local shop and see how much they'd charge to put the fluid in.
  8. mhdriver
    mhdriver Member
    162
    61
    florida
    How high off the ground do I need to get this? I found the Mityvac on Amazon for about $30.
  9. Mendel Leisk
    41,951
    Not quite. If it's sloping, front significantly higher than back, due to the fill plug being toward the back of the transaxle the fluid's going to spill out sooner. Get a floor jack and a pair of safety stands, raise the rear (jacking point shown in owner's manual), settle it onto the safety stands, roughly level, and you'll be good.
    There's a link in my signature (on a phone, turn it landscape to see signatures) with info on this.
  10. mhdriver
    mhdriver Member
    162
    61
    florida
    Called a mechanic I know, he'll do it for $70 if I give him the fluid. Since I won't think about it for about 3 years, it's worth it to me. I'm an RN, have had mechanics that were working and had a car fall on them. Not pretty.
    xliderider, Rebound and ASRDogman like this.
  11. bisco
    52,417
    that's a good price
  12. Mendel Leisk
    41,951
    This is the repair manual instruction:
  13. douglasjre
    douglasjre Senior Member
    2,206
    737
    Null, NL
    If you drive it up a ramp you'll under fill it because of where the fill plug is. Put a jack under the back end and put this thing level. I've used Max Life LV 1 gallon jugs from Walmart and more than a dozen Priuses without a problem so far. That said, it's better to get WS trans fluid from the dealer and pay more for it. I've been taking this chance without a problem but it's up to you
  14. Rebound
    3,996
    2,645
    Portland, OR
    Not Safe. My life is worth more than saving a few bucks.
    Grit likes this.
  15. Mendel Leisk
    41,951
    Front on ramps and rear just on jack, yes: not safe. But going an extra step, settling the back onto safety stands, would be quite safe.
    douglasjre likes this.
  16. ASRDogman
    7,844
    3,997
    It is SAFE to do it you use good equipment.
    But, if YOU do not feel safe doing it, do not do it. No matter what anyone says!
  17. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Do it! #YOLO
  18. Mendel Leisk
    41,951
    With safety stands under the car, I still like to put this big block of tree trunk (aka chopping block) under, before getting under myself. Whenever practical. It's minimum dimension is 13"~14", thicker than me.
  19. Rebound
    3,996
    2,645
    Portland, OR
    Parking on a hill and putting only one end of the car on jack stands: NOT SAFE. The car can definitely roll off those jack stands.
    Doug McC and Mendel Leisk like this.
  20. Paladain55
    Paladain55 Active Member
    410
    169
    The South
    Man if you are an RN I would just work an overtime shift and get it changed by a local mechanic. It's as easy as a manual transmission fluid change. My friend here makes $40 base so overtime at $60/hr would cover that oil change. If not you can always do what I did in college. Go to the local oreillys and change it in their level parking lot. Lol
    Zaza 13 likes this.
