Reduced MPG and Acceleration
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by JRC1981, May 7, 2023.
  1. JRC1981
    JRC1981 New Member
    Hi
    Last November my brake booster AND accumulator failed at the same time.
    There were some hydraulic(?) noises for a while, which got worse over time, then one day a warning light came on and the brakes were hard, though the car was still able to stop.
    At that same exact time, there was an obvious reduction in acceleration and MPG. Prius was sluggish during acceleration and MPG dropped to 30-35 MPG.
    No codes for the battery.
    I fixed both brake problems, BUT the MPG and acceleration problems persisted.
    I replaced the 12v battery, but the problem still persisted.
    On a possibly related note, 4-5 months later the head gasket goes.
    My theory is the engine was working harder than it should have and eventually a HG issue formed. No one has been able to confirm or even entertain this idea.
    I'm thinking about fixing the HG or replacing the motor. But won't if there is a deeper hybrid system issue.
    Does this sound like a battery or hybrid issue for anyone else?
    52,382
    how many miles on her?
    how many miles of ev range are you getting?
    maybe a dragging brake?
  3. Doug McC
    Doug McC Senior Member
    1,081
    420
    Midwest
    2022 Prius
    I’m no expert on the Gen 1 Prius Plug-in by a long shot, but could the problem be related to the regenerative braking system? Reduce regenerative braking and you reduce fuel efficiency. Your problem started with the brakes, so maybe the repair wasn’t complete.
    Just my initial thoughts (and again, I not that knowledgeable about your car).
  4. JRC1981
    JRC1981 New Member
    around 210K
    Not sure about the range. I never really charge it since I was traveling for work.
    I'm having my guy look.
  5. JRC1981
    JRC1981 New Member
    That's a really good guess. I'll pass it onto my guy.
    Doug McC likes this.
